Question about Nikon Cameras
My flash on mt d60 camera is way to bright
Changing settings
    Top Expert:
  • Nikon Master
  • 6,702 Answers
Could have different causes. If you are using an Nikon flash, you should put it on TTL and your camera on automatic to check everything is working correct. Then you can change to all other modes and the camera should also tell the flash when to stop.
If you are using an other brand, or a wireless trigger, you have to adjust the camera settings yourself. Not knowing what flash you are using, and not knowing what settings you have dialed in on your D60, this is the first thing I can think of.
Perhaps if you keep having trouble, you give me some more details and I hope to be of any help then. Just a quick question. How is the light on the pictures when you shoot normal? (Without flash)
Posted on Dec 02, 2014
D60 flash won't pop up
Please set the MODE to P (Programmed Auto) In this mode YOU control the flash, not the camera. Inside where it is not bright. Set your ISO to 800 and take a photo indoors with low light. Then pop up the flash and do it again. P lets you take a photo with the flash down or UP it is the only mode I suggest most people should use. :)
Jan 15, 2017 | Nikon D60 Digital Camera
Nikon d60 flash will not popup
turn camera on keep the lens cap on and push the button on the side of the camera with the image of a lightening bolt at the same time help the flash door up if that doesnt work go to menu then custom setting then go to braketing/ flash toggle right and turn on builtin flash
Aug 06, 2014 | Nikon D60 Digital Camera
Turning flash off on Nikon D60
Based on what you said, it appears that you want to know how to turn the flash off on your D-60.
On my D-90, you do this by rotating the mode switch on the top center left side of the camera one click counterclockwise, from the green automatic setting, to the white automatic with no flash setting.
You can also change flash settings from the menu. For my D-90, the manual says you use custom setting "e2." Check your manual for the D-60.
I never turn my flash off from the menu because it takes too long to turn it back on when you need it. Another alternative is to simply hold the on-camera flash in the down position while you shoot.
Apr 19, 2014 | Nikon D60 Digital Camera
I have a nikon d60 and cannot get the pop up flash to flash, any suggestion
Go to menu then custom setting menu then turn your built in flash on problem solved
Nov 13, 2012 | Nikon D60 Digital Camera
How do I get the flash to work in bright conditions
Switch to one of the MASP exposure modes then pop up the flash by pressing the flash button on the front of the camera.
Jul 27, 2012 | Nikon D60 Digital Camera
Nikon d60 When I try to take a picture with the
That is a problem that has to do with the Flash...make sure your flash settings are not turned on. If the flash can't find an image...it rotates and usually never finds the image. It's reading in a Flash mode.
Mar 25, 2010 | Nikon D60 Digital Camera
Need to change language on Nikon D60
Within the menu items that can be viewed on the back of the camera, there is a language option that you can set. You may have to scroll through all of these to get the correct setting. Nikon tends to change the menu layout from camera to camera, so it may not be the same in your D60 as it is in a D300 or other model.
Jun 03, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Imagines are dark even in bright light
the flash settings should have been kept in auto mode.if you want the flash always.normally, there is a button near the lcd screen, with the symbol of a lightning flash. when you press it once it sets the flash mode to auto, second time it sets it to "flash always on mode", third time "flash always off" mode.you can refer this process in instruction manual also.thanks for using fixya! please dont forget to rate my solution.
May 29, 2009 | Canon PowerShot EOS D60 Digital Camera
Cameras Logo
32 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
