Question about Amana Kitchen Ranges
How do i bypass the system diagnostic Amana big oven ACF4205A
The F9 code is showing and we can not correct the problem..As a result we can not use the oven. I wondered if there was a way to disconnect the door latch from the systems self diagnostics?
    Sergeant:
  • 409 Answers
I would not recommend bypassing the diagnostics, as it's designed to check for errors to identify part failures. Please consult a professional to solve this problem. They have the training necessary to help you and they also guarantee the work.
Posted on Jan 13, 2015
  • 38 Answers
SOURCE: Cancelled self-clean, F9 code came up, door lock light flashing, can't use oven
HI,
your model number confirms that your range was manufactured by WCI (Frigidaire). although this doesn't help you now, it may help if parts are needed.
now, there is an indepth guide online to fixing this common problem and I would like you to go through it and see if it helps you solve your problem.
http://www.applianceaid.com/clean-lock.html
If you have found this site previously then I apologise, if you still need help, by all means post again and someone more qualified may help.
Hope this is of use to you ;)
Phil
Posted on Oct 28, 2008
SOURCE: F9-6 fault code on maytag gemini double oven range
I waited until the next morning and hit the cancel button. It cleared the error
Posted on Sep 17, 2009
mrbobfixit
  • 259 Answers
SOURCE: Oven sef clean latch locked but door is open and I
Ok. Open the door and find the oven light switch(es) (some models had two switches). Press the switch(es) in and see if the latch goes back to the home position. If not enlist a volunteer to turn on the self clean cycle while you are holding the switch(es) in. Just after the self clean starts have them hit cancel and wait until the lock comes back to it's "home" or unlocked position.
Good luck!!
Posted on Jun 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore oven self cleaning oven dispalys F9
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
SOURCE: amana Oven Door won't open. Latch to lock it is broken.
After pressing Self Clean, Adjusting the Time and Pressing Start, the self cleaning cycle shows the # F57_ on the read-out. I tried to cancel and now the door opens, but I can't get the Bake to begin when I press Start. No matter what I press LOC flashes on and off, but the door is unlocked and the heat is off.
Please help!
Susan, PR
Posted on Dec 18, 2010
On my new stove i got a F9 code what can i do to get my stove to work
Possibly incorrectly wired. Often these codes are make specific.
F9 or F9 E0 - Whirlpool Home Appliances - Whirlpool® product help
producthelp.whirlpool.com/...Guides/...Ranges/...Code%2C...Code.../F9_or_F9_E0
Apr 22, 2017 - Reset power to the product: This code will most often indicate that the appliance is wired incorrectly at the home electrical supply, or at the hard wire connection. If your oven was installed recently (within approximately 3 months), contact a qualified electrician to verify the electrical supply. During a power ...
What does the F9 error code mean on my Kenmore range Model 790 ...
https://www.shopyourway.com/questions/1074065 Apr 6, 2010 - Door locked started blinking, door never locked,..pressed clear button caused "dr" code, pressed clear again and "f9" and beeping occurred. ... This was extraordinarily helpful...we got this oven from my mom in law when our old one died and she bought a new one, we knew nothing about it but thanks to ... How do I get rid of F9 error code on range?
18 Dec 2011
Why does my Kenmore oven display the F9 error code ...
1 answer
29 Oct 2009
How do I reset an F9 on Frigidaire oven?
1 answer
26 Oct 2009
What does the error code F9 mean on my Maytag ...
1 answer
11 May 2008
More results from www.shopyourway.com
going to clean the oven but got a f9 error had to reset it for it to work ...
? 1:49
https://www.youtube.com/watch?v=cgGKxTxxf4E May 17, 2016 - Uploaded by mike webb
going to clean the oven but got a f9 error had to reset it for it to work mike webb po box 408 stryker ohio 43557.
F9 Error Code - Whirlpool , KitchenAid & Kenmore Range - Repair ...
? 1:01
https://www.youtube.com/watch?v=MXMDjZRNDnw Oct 31, 2014 - Uploaded by ApplianceVideo.com
Visit us at http://www.appliancevideo.com Do-it-yourself diagnostic and repair videos brought to you by ...
stove got F9 code Google Search
Mar 18, 2018 | Kitchen Ranges
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
Error code F9 shows on screen, oven is inoperable.
See service manual or contact manufacturer.
Nov 18, 2013 | Ovens
F9 CODE OVEN WILL NOT HEAT.
Hi
Thanks for using FixYa. Error F9 means door latch failure. To resolve this issue you’ll have to check the door latch and replace the door latch and/or assembly. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 12, 2010 | Amana AOES3030 Electric Single Oven
Amana oven model ACF4225AC the big oven power ...
have and Amana oven/stove model ACF4225AC that is 8 yrs old. Middle glass (thick tempered) part # 32028101 completely shattered. Oven was not on for at least a week, noone was near it,was not hit,and at 9 AM while I was in other room it just shattered into a million pieces. Went to dealer- looked up part and found it was no longer available. I have been checking internet appliance part companies, and e-bay to no avail. Cannot find replacement glass. Any suggestions? Thanks, Jim
May 21, 2010 | Ovens
My oven will not stay on .F9 code appear whats the problem?
Hi healinghe445,
It has something to do with a motorized door if you are getting this error code F9. The most common thing that needs to be checked is the latch. If you find it faulty you will need to replace it with a new one. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Mar 07, 2010 | Amana AER5725QA Electric Kitchen Range
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
F9 code
F9 is a Door latch failure need to replace door latch or check wire or latch motor
Dec 13, 2007 | Amana AOCS3040 Electric Single Oven
Kitchen Ranges Logo
87 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
