Question about Frost Refrigerators
My Bosh Intelligent Frost Free 44 fridge keeps freezing up the pipe down the back of the fridge which keeps the fridge cool. We keep defrosting it by blowing hot air down to melt the ice and that wor
My Bosh Intelligent Frost Free 44 fridge keeps freezing up the pipe down the back of the fridge which keeps the fridge cool. We keep defrosting it by blowing hot air down to melt the ice and that works for a couple of weeks then it ices up again. I rang 2 repairers and one said the heater fan and defrost switch need replacing and the other said the insulation must have totally worn away which means its not repairable. Any advice from people with similar situation??
You can not get advice over the phone or here really
You need knowledgeable folks to be there & see the issue
It may not be getting enough air across the condenser coil to
remove the heat
It may have a refrigerant leak & is boiling off too soon & freezing
the evaporator coil
Or the other suggestions on fan control,switches & such
Posted on Dec 02, 2014
peyton32034
  • 410 Answers
SOURCE: Kenmore Coldsport freezer drain repeated freezes
probably the easiest fix for this is install a drain probe to transfer heat from the defrost heater into the drain hole to prevent ice build up. take a peice of 10 or 12 guage solid copper wire and wrap one end around the defrost heater pretty tight and put the other end down in the drain line 2-4 inches.
Posted on Dec 15, 2007
  • 105 Answers
SOURCE: Kenmore C978-66792-1 fridge: defrost ices and stops fan
It should just be your ice maker wires and wouldn't be the issue with this fridge
Posted on Feb 10, 2009
aasc
  • 1606 Answers
SOURCE: GE refrigerator, ice melts in ice bin
Since your refrig is cooling , I would replace the # 4 AND # 5 thermistors . The # 4 thermistor , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
Posted on Nov 16, 2009
arikrom
  • 528 Answers
SOURCE: GE Side By Side "frost free" fridge, Freezer keeps freezing over!
it is easy your thermostat is bad or your heating element is bad and it is very easy to check and replace ... what is your model # ?
contact me at www.911servicetoday.com
Posted on Dec 30, 2009
SOURCE: Bosch intelligent frost free 88
We have the same and I think it is because the freezer door bounces open when we shut the fridge door. Then the freezer compartment ices up, the fan clogs up with ice and cannot blow cold air into the fridge, and the fridge gets warm and the milk goes off.
Solution? We have bought one of those child safety clips (search for fridge safety clip or lock) to hold the freezer door closed.
Simple design error. Expected better from Bosch :-(
Posted on Feb 24, 2010
Bosch intelligent frost free 44
the fridge might have iced up in the coil due to a defrost problem. one way to check it is to leave the fridge off for a few hours and leave the door open. turn the fridge back on after the few hours and see if the performance is any better. Let me know how it goes
May 22, 2014 | Refrigerators
I have a fridge freezer and for some time now the fridge keeps freezing and now the freezer seems to be leaking water?
If it is a frost free freezer, is is probably your defrost assembly that is bad. The leaking water might be associated or another problem. Is the refrigerator section staying cool?
Jun 01, 2011 | Refrigerators
Water leaks inside
It's due to wrong temp setting and malfunction of defrost cycling. Keep thermostat setting at 5 degree or little less. And don't keep it in minus,as defrost cycle will take longer time. And also you will get less cooling in fridge compartment and also water leaks.Check drain line hose may freezed. And also freezer tray get blocked due to over frosting around freezer. Defrost manually by unplug your fridge and after defrost all ices, plug again and keep correct temp setting. Thanks.
Feb 01, 2011 | Whirlpool 21.0 Cu. Ft. Frost-Free...
My C373 Fridge only should be frost free but it keeps Freezing up and then doesnt keep anything cold anymore
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 04, 2011 | Fisher and Paykel Refrigerators
Frost and freezing in the fridge
its warm damp air getting into the fridge causing the frosting if it builds up to much the fridge will find it hard to keep things coold down and you will need to "de-frost" it,,to do this rap all your food up in a blanket to keep it cool them switch off the fridge and put a tub of boiling water in side it leave the door open the frost will soon fall away,,wip out the fridge with "by carb" and switch it back on for an hour or so before you put your cold food back in it
Jun 29, 2010 | Liebherr KELB 2840 Premium biofresh...
Fridge/freezer not working
check the condensor fan if that aint it unit may be low on charge
Apr 24, 2010 | Freezers
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Candy frost free fridge freezer .freezer working ok
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
May 12, 2009 | Freezers
Bosch intelligent frost free 40
The small drain pipe on the back of the fridge gets clogged, hence no drainage when defrosting, hence ice blocks the airflow between the freezer compartment and the fridge compartment.
Remove the rubber stop from the drain pipe and clean (can be found above the motor)
Defrost the fridge for a few days (it takes at least 48 hours). During this time, if you are not brave enough to remove the internal panels of the freezer and continually clean the water, check for water coming out and clean.
If during the defrost there is no water coming out the drain pipe, use about 2m of flexible and strong wire to clean the pipe.
The aim is to unblock the pipe once the ice has melted.
Jul 27, 2008 | Bosch Refrigerators
Jenn-Air Refrigerator
Might be icy. First, fully defrost by either removing the rear panel and using a hair dryer (dangerous) or leave it off and open for two days. Check door gaskets and clean or repair. Clean condenser coils under the unit. Now, take off the back lower panel and find the compressor. Largest pipe is what we're interested in. Start unit. It will frost the pipe. After 5 minutes, frost should be replaced by ice, dry or wet...not frost. If still frosty, you need freon. Hard to know what the right price would be.
What else could it be? Thermostat, defrost timer. Try my stuff before going on.
Nov 27, 2007 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
101 people viewed this question
Top Frost Refrigerators Experts
jdthefixer
Charles T Nevin
Charles T Nevin
Mike
Are you a Frost Refrigerator Expert? Answer questions, earn points and help others
