Question about Marcato Atlas 150 Wellness Pasta Maker Red
Handle stuck in Marcato Atlas pasta machine. How do I pull it out?
Tried pulling gently and not so gently but it the handle is still stuck in the machine so I can't pull it out.
Breadman Ultimate can't remove bread pan
Have you tried giving it a little anti-clockwise twist? :)
Jul 21, 2017 | Breadman Kitchen Appliances - Others
How to remove handle or shank from
just pull the handle from right to left, if is tight just hit gently from right side of the handle. to detache the filter if it is stuck just put the handle under hot flush water and gently try to turn it until it comes out.( there are two inserting tips that match with the handle) if it is very stuck, usually because of the coffe that "glue the filter to the handle body try to pull the filter gently off the handle body using a no-sharp tool ( spoon handle tip for example)
Aug 12, 2014 | Ariete Cafe Retro Espresso Machine
Detergent dispenser is stuck and cannot open on LG Tromm washing machine
There is a small tab that one has to press down to unlock the retainer clip.
Press this down while pulling the tray outward.
Aug 06, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
No washer fluid spray
try to gently clean the jets and insert a tin needle while someone pulls trigger. hole might be dirty...i did this to mine and it worked...good luck
Jan 20, 2014 | 2001 Audi S8
Unfix a 2003 F150 Tailgate
try spraying the latches with wd40. have someone hold handle up and gently kick the inside of the gate to see if it opens.
Jan 02, 2012 | Cars & Trucks
Cannot remove lamp from mitsubishi HD1000
Hello
The proceedings to take out lamp are:
1. Reverse the projector gently.
2. Loosen the screw (a) using a Phillips screwdriver (+), and
remove the lamp cover (b).
3. Loosen the screws (c) using a Phillips screwdriver (+).
4. Pull up the handle.
5. Pull out the lamp box by the handle while holding the
projector.
• Pull the lamp box out of the projector slowly. If it is
pulled out quickly, the lamp may break scattering glass
fragments
It must come out easly. There are only three screws to seccure it in place.
Oct 29, 2011 | Office Equipment & Supplies
Delta monitor shower handle. Took off set screw and can't pull off handle. It is stuck. Ideas
If your handle has a lever, then lightly tap it with a rubber mallet till it moves a little. You should tap it towards the wall. Once you moved it a little, pull it back with your hands. Repeat this till you are able to get enough play to wiggle with your hands and pull off. Be gentle. Hope this helps!
Nov 26, 2010 | Home
The touchscreen went out on my samsung SCHU960(Rogue). Verizon is sending me a new phone but I want to erase my data before sending it back. Is there any way I can do it without going through the phone`s...
I had the same problem. I was able to gain temporary use of my touchscreen by placing a piece of tape (folded to make a handle) on the dark spot on my screen. This is where the layers were stuck together. I rebooted the phone while gently pulling on the tape handle to separate the layers. I was able to navigate to the restore screen and hit the yes button. There were points when it stopped responding. All I had to do was gently pull on the tape handle again to get the screen to respond again. I'm sure you have already solved your problem, but hopefully, this will help someone else.
May 27, 2010 | Samsung SCHU960 Cell Phone
The handle on our Marcato Atlas 150 keeps getting stuck and is difficult to pull out for storage. Any ideas?
I opened the rollers to the widest setting (Zero), and placed a folded business card between the rollers. I then turned the dial down so the rollers were "pinching" the card, and while keeping tension on the dial to gently squeeze the card, I gently shook the handle for a few seconds and it came out!
Jan 12, 2010 | Atlas Translator Marcato Atlas 150 Handle...
Stem Valve is frozen on my 3175 Legend.
Here is a possible solution for you. First go out and buy a Moen cartridge puller tool like this:
Next follow these steps:
  1. Turn off the water to the valve.
  2. Install puller and rotate cartridge several times.
  3. Gently pull on cartridge while slowly turning.
This should work. If the center of the valve pulls out continue below with these suggestions:
  1. Remove center piece from tool.
  2. Place the brass feral to the end of the tool as shown.
  3. Insert this part of the tool into the valve all the way as far as it can go.
  4. Turn the tool until you hear a click or tool feels like it turns the valve.
  5. Pull on the tool gently while turning.
This should get the job done.
Also here is some information for you about your valve:
Moen 3175
Hope this helps and please rate this suggestion.
Dec 08, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Marcato Atlas 150 Wellness Pasta Maker Red Logo
208 people viewed this question
Top Marcato Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Marcato Kitchen Appliances - Other Expert? Answer questions, earn points and help others
