What is triglycerides? And what is they functions?
  • 3,957 Answers
A good discussion can be found here: http://healthyeating.sfgate.com/function-triglycerides-9618.html
Posted on Dec 02, 2014
HDL & LCL & Triglycerides
fats in the blood or arteries still bad to have high numbers
if you want to live a bit longer
medications and diet control required to manage this condition
our total cholesterol score is calculated using the following equation: HDL + LDL + 20 percent of your triglyceride level. HDL (good) cholesterol. With HDL cholesterol, higher levels are better. Low HDL cholesterol puts you at higher risk for heart disease.
explained
http://www.webmd.com/cholesterol-management/guide/understanding-numbers
May 19, 2016 | Cars & Trucks
Tip
How To Convert Vegetable Oil Into High-Grade Biodiesel Fuel
This tip will help you learn how to convert new or used vegetable oil into high-grade biodiesel fuel that can run in a standard diesel engine. Anybody can make biodiesel. It's easy, you can make it in your kitchen -- and it's better fuel than the petro-diesel the oil companies sell you. Your diesel motor will run better and last longer on your <a href="http://www.diversesolutions.org/detail/B0014FKHZ8">home-made fuel</a>, and it's much cleaner -- better for the environment and better for health.<br /><br /><a href="http://www.diversesolutions.org/detail/B0014FKHZ8">Biodiesel</a> has some clear advantages over straight vegetable oil, or SVO: <br /><br /> <ul> <li>It works in any diesel, without any conversion or modifications to the engine or the fuel system -- just put it in and go. </li> <li>It also has better cold-weather properties than SVO (but not as good as petro-diesel<a href="http://journeytoforever.org/biodiesel_vehicle.html#winter"></a>). </li> <li>Unlike SVO, it's backed by many long-term tests in many countries, including millions of miles on the road. </li></ul> Biodiesel is a clean, safe, ready-to-use, alternative fuel, whereas it's fair to say that many SVO systems are still experimental and need further development.<br /><br /><span style="font-weight: bold;">Instructions:<br /><br /></span> <ol> <li>Purchase a <a href="http://www.diversesolutions.org/detail/B0014FKHZ8">Biodiesel Processor</a>, such as the <a href="http://www.diversesolutions.org/detail/B0014FKHZ8">Fuelmeister II Biodiesel Processor available here.</a></li> <li>Follow the included instructions and you will be on your way to creating your own Biodiesel fuel!<br /></li></ol><br />Biodiesel is made from vegetable and animal oils and fats, or <b>triglycerides</b>. <a href="http://www.diversesolutions.org/detail/B0014FKHZ8">Biodiesel</a> cannot be made from any other kinds of oil (such as used engine oil).<br /> <br /> Chemically, triglycerides consist of three long-chain fatty acid molecules joined by a glycerine molecule. The biodiesel process uses a catalyst (lye) to break off the glycerine molecule and combine each of the three fatty-acid chains with a molecule of methanol, creating mono-alkyl esters, or Fatty Acid Methyl Esters (FAME) -- biodiesel. The glycerine sinks to the bottom and is removed.<br /> <br /> The process is called <a href="http://www.diversesolutions.org/detail/B0014FKHZ8">transesterification</a>.<br /><br /> <b>System Includes: </b> <br /> <ul> <li>Processor Tank and Stand</li> <li>Pump Assembly</li> <li>Oil Drawtube Kit</li> <li>Oil Titration Field Test Kit</li> <li>Operator Safety Kit</li></ul><br /> <b>Specifications:</b><br /><b><br /></b><br /> <ul> <li><a href="http://www.diversesolutions.org/detail/B0014FKHZ8">Biodiesel</a> Output: 43:5 gallons (max) per batch</li> <li>Mix Rate: 330 gallons per hour</li> <li>Operator: 1 1/2 hour per batch (typical)</li> <li>Tank Material: Chemical grade polyethylene</li> <li>Tank Stands: Welded steel frame with levelers</li> <li>Plumbing Materials: Chemical grade steel valves</li> <li>Processor Capacity: 55 gallons (maximum)</li> <li>Processor Size: 54" high x 26" diameter</li> <li>Footprint: Set up in a 30" x 30" space</li> <li>Shipping Weight Processor: 98 lbs.</li> <li>Shipping Weight Pump Assembly: 27 lbs.</li></ul><br /> <b>Other Features:</b><br /> <ul> <li>Handles most used vegetable oils</li> <li>Makes 2-40 gallon batches in 24 hours </li> <li>Industrial-grade materials</li> <li>Easy draining cone-bottom tanks</li> <li>90 minutes hands-on time after understanding the system</li> <li>Turbine pump blends and mixes</li> <li>Full-draining single tank system</li> <li>Special Modular Direct Catalyst Injection Lid (Patent Pending)</li> <li>Steel Methanol Pump</li> <li>Quick disconnect hose fittings throughout</li> <li>NEMA box with Solid-State control timer</li> <li>Steel valves No thru-tank ports</li> <li>Interchangeable Lid System</li> <li>Large diameter glycerol drain hose</li> <li>30" x 30" footprint, very compact</li> <li>Platform allows for modular upgrades</li></ul>
on Jan 14, 2011 | Kitchen Appliances - Others
How do I get the blood test results
Please ask this the lab you were. Not Fixya. we try to answer questions, but don't do blood tests.
Check the URL on top of the page, before you press post or send.
Jan 28, 2015 | Cardiochek Portable Blood Test System
Is it true that honey & cinnamon is very good health wise
Some of the health benefits of Honey and cinnamon are:
1. Regularly intake of honey and cinnamon can cure chronic arthritis.
2. It destroys the germs in the bladder and reduce the risk of bladder infection.
3. It can reduces the level of cholesterol in the blood within 10 minutes.
4. Cure most chronic cough, cold, and clear the sinuses.
5. If Honey is taken with cinnamon powder the stomach is relieved of gas.
6. Relieves acidity and digests the heaviest of meals.
Mar 03, 2014 | Computers & Internet
Is glycerin of vegetable origin?
Glycerin is produced from fats. The fats - vegetalble, animal or fosill based are triglycerides - three saturated or unsaturated hydrocarbone chains connected together to the grycerine molecule. After alcaline treatment these molecules are broken down to the glycerine and the different hydrocarbone chains form bio-disel fuel. Since the type of the fat is defined entirely by the differences in the hidrocarbone chains, after their removal, noone can tell where the glycerin originated from vegs or animals.
Jan 09, 2014 | Computers & Internet
Is coconut oil good for heart related diseases?
In moderation, it can be very good for preventing heart disease, but moderation is key here. Read this article for more helpful information.
Sep 18, 2013 | Computers & Internet
What are the health dangers of high fructose corn syrup that is used in many soft drinks?
High fructose corn syrup has several health risks that people should be aware of:
According to many studies, compared to fruit sugars, high fructose corn syrup makes you gain more weight.
In the long run, consuming large amount of high fructose corn syrup can lead to diabetes.
It elevates triglyceride and HDL levels, which are the "bad" cholesterol levels.
It is unhealthy for your live.
It contains a large amount of mercury, which is very bad for babies.
Feb 04, 2013 | Wine & Spirits
Need codes for ht3916 to chage remotes
Description=Durabrand Home Theater System (HT-3916)
Remote.name=URC-6131nwB00 PVR Remote 2K
Remote.signature=PVR0PVR0
DeviceType=Amp
DeviceIndex=3
SetupCode=1568
Protocol=00 5a
Protocol.name=NEC2
ProtocolParms=24 null null
FixedData=01 e7 e7
Function.0.name=Power
Function.0.hex=c7
Function.1.name=Mute
Function.1.hex=e7
Function.2.name=Source
Function.2.hex=d7
Function.3.name=Channels
Function.3.hex=67
Function.4.name=Reset
Function.4.hex=cf
Function.5.name=Front (-)
Function.5.hex=6f
Function.6.name=Front (+)
Function.6.hex=5f
Function.7.name=Center (-)
Function.7.hex=57
Function.8.name=Center (+)
Function.8.hex=df
Function.9.name=Rear (-)
Function.9.hex=47
Function.10.name=Rear (+)
Function.10.hex=ef
Function.11.name=Subwoofer (-)
Function.11.hex=77
Function.12.name=Subwoofer (+)
Function.12.hex=ff
Function.13.name=Master Volume Down
Function.13.hex=4f
Function.14.name=Master Volume Up
Function.14.hex=f7
Button.8=Mute'null'null
Button.3=Power'null'null
Jul 23, 2011 | Durabrand HT-3915 System
WHAT IS TRILIPIX
Trilipix is mainly used to treat high cholesterol and high triglyceride levels. It is sometimes given together with other cholesterol-lowering medications.
May 05, 2011 | Kavapoint Drugs & Medications
What are the ingredients in the Sonia Kashuk hidden agenda concealer palette? I'm afraid it will have mineral oil or bismuth!
Here are the ingredients==no mineral oil and all good except for the aluminum starch in the powder:
FULL INGREDIENT LIST:
Cream concealers and neutralizer: Titanium dioxide, triisostearin, octyldodecanol, hydrogenated polydecene, cetearyl ethylhexanoate, polyethylene, microcrystalline wax, silica, bis-diglyceryl polyacyladipate-2, squalane, cholesteryl hydroxystearate, simmondia chinensis (jojoba) seed oil, phenyl trimethicone, euphorbia cerifera (candelilla) wax, retinyl palmitate, tocopheryl acetate, prunus armeniaca (apricot) kernel oil, C10-18 triglycerides, methylparaben, ascorbyl palmitate, lecithin, tocopherol, citric acid, aesculus hippocastanum (horse chestnut) seed extract
Translucent powder: Talc, aluminum starch octenylsuccinate, dimethicone, silica, cornstarch, cetearyl octanoate, perfluoropolymethylisopropyl ether, zeolite, polyglyceryl-3 diisostearate, sorbic acid, methylparaben, zinc stearate, lauroyl lysine, PCA, lauryl alcohol, propylparaben, tetrasodium EDTA, butylparaben, BHT. May contain: Mica, titanium dioxide, iron oxides, ultramarines, ultra marine blue, manganese violet, ferric ferrocyanide, D&C red 7 CA lake, D&C red 30
Feb 13, 2011 | Sonia Kashuk Hidden Agenda Concealer...
43 people viewed this question
jasbo
jasbo
