Question about McCulloch Fuel Gas Line Filter Titan 50 57
Find where the oil lines go on a titan 50 chain saw
To fit but no success
  • jeromekj Dec 06, 2014
    NEW OEM McCULLOCH MANUAL OIL PUMP 222783 TITAN 50 & 57 CHAINSAWS
    http://www.ebay.com/itm/NEW-OEM-McCULLOC...
    Problem Solver:
  • 7 Answers
Being around chainsaws for 40 years I can make an educated guess.. I believe this is a manual oiled saw where your thumb provided the oil as it was pumped from the reservoir to the bar. Again an educated guess says that the thumb pump, pressurized the reservoir. Newer models had gear driven but still with the thumb assist oil pump.
After just 15 minutes of use you had 2 side effects from use of this saw, tingling hands and a ringing in your ears. I'll be with a friend tomorrow that had one, if I can correct or add to this I will.
Good luck
jeromekj
Posted on Dec 06, 2014
3 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: I'm looking for A service manual for A McCulloch
This is an IPL for a Titan (11-600152-03):Please ensure this is your saw
http://www.ordertree.com/modelinfo/MCC/11-600152-03-TITAN-50-05%2F88-to-02%2F95-IPL-222956/139.11-600152-03-TITAN-50-05%2F88-to-02%2F95-IPL-222956.1.59.1.html
There are others here (IPL #11-600152-03 - just above this one. There may be others 12- etc.) :
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
This is an international collection of chainsaw enthusiasts, sellers/mechanics. There are McCulloch threads where repair and overhaul are discussed.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
This thread is where to request a service manual:
Beg for manuals thread (ArboristSite) (free to join)
http://www.arboristsite.com/showthread.php?t=72322
one was requested here:
http://www.arboristsite.com/showthread.php?p=1342509&highlight=titan+50#post1342509
with no answer published. Good luck
Lou
Posted on Jan 24, 2010
Testimonial: "Thank you soo much the IPL was just the ticket. pokeydell"
  • 1514 Answers
SOURCE: what is the oil/gas ratio for a McColloch "Titan
40:1 is the ratio for modern saws so I expect it's the same for the older ones. Use good 2 stroke oil like Husqvarna or Stihl brands rather than the cheaper stuff you can buy at car service stations which don't really protect a saw.
Posted on Jan 05, 2011
Testimonial: "It was a helpful suggestion but somewhere in the back of my mind going back to when I first bought the saw, 32:1 keeps popping up in my mind. Thanks"
What is the oil/gas ratio for a McColloch "Titan
Jan 05, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
The chain oil is not feeding to the chain/bar
Release the chain brake and remove the bar and chain. Clean the engine area where the bar fits up to, and start the engine--oil should ooze out of the side port there. If nothing, then the oil pump, oil line, or oil filter in the tank may have failed. If it oozes ok, then clean the drive end of the bar--especially the two small passages that run from the large holes out to the chain groove on each edge of the bar. Re-assemble everything, then run the saw bar-tip near some cardboard for several moments--it should throw off a thin line of oil. There should be an oil volume adjustment screw head under the case near the chain return area--turn CCW to increase flow. Hope this helps!
Dec 22, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
No local Ryobi dealer; what other brand chains will fit my 18" Ryobi ?
Any saw service dealer can fit a chain to your saw. 'Oregon' saw makes bars/chains for about any saw made in the last 50 years or so. Just take the chain itself in to get a replacement. Good luck!
Nov 18, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Chain is not getting oil
Remove the bar and chain--clean the port area where the bar fits. Run the saw at speed for a few moments--it should ooze oil out of the port. If it doesn't, then you need to check the pump, lines, and tank for plugging or other problems. If the oil came out ok, then clean the bar drive-end small oil passages that run out to the chain groove on each side. Clean the entire chain groove as well. Reassemble the bar and chain (the teeth cut toward you on the lower run), and adjust the chain so that it just pulls up to the bar, but not so tight that you can't pull it by hand. Run the saw tip at speed near some cardboard--it should throw off a thin line of oil. Hope this helps!
Jul 09, 2010 | Echo CS400 18" Chain Saw
Oil is not coating the chain?
Remove the bar and chain after releasing the chain brake. Clean the cover and the area where the bar fits to the engine. Start the engine and watch for oil oozing out of the side port where the bar fits. If ok, clean the bar end oil passages including the two small channels that go from the large holes out to the chain groove on each side. Clean the entire groove and check the tip sprocket if equipped. If no oil came out of the port, then you need to inspect the oil pump, lines, and tank filter for plugging or damage. When oil comes out as specified, insert the bar, push back, and fit the chain over the sprocket then work it over the bar. Make sure the teeth cut toward you on the bottom run. Pull the bar out to tighten the chain, then back off the chain adjustment screw several turns. Fit the cover, making sure the adjustment tang fits into one of the large holes in the bar, the run the fasteners down finger tight. Adjust the screw till the chain pulls up to the bar, but allows the chain to be moved by hand. Tighten the mountings and recheck the tension. Run the saw tip near a piece of cardboard at speed for a few moments--it should throw off a thin line of oil onto the cardboard. Make sure the chain is properly sharpened. Hope this helps!
Jun 19, 2010 | Troy-Bilt Troy Bilt 18" Chain Saw Repl...
Where can I find a replacement bar and chain for my saw?
Remove the bar and chain from the saw. Take these parts to a saw servicing dealer who can match the bar and chain. Be sure to clean the area where the bar mounts. Run the saw for a few moments--the oil port in the side of the case should ooze out oil. Install the bar first, then thread the chain onto the sprocket, then work it over the bar. Pull the bar out until the chain is fairly tight, then fit the cover, but leave the mounting nut(s) finger tight. Turn the chain adjuster until the chain doesn't droop from the bar, but still be able to turn the chain by hand. Tight the mounting nut(s) and recheck tension. Run the saw at full speed with the tip near some cardboard--it should throw off a thin line of oil onto the cardboard. Hope this helps!
Jun 10, 2010 | Desa International 100089 06 Electric...
Chain will not stay oiled
Remove the bar and chain and clean the side of the engine where the bar fits. There is an oil port there that should ooze oil out when the engine is running fairly fast. If it does, then clean the drive end of the bar (large oil holes out to the chain groove on each side. Also clean the entire groove and oil the sprocket on the outer end (if equipped). If oil did not ooze out of the port, the oil pump, oil filter, and any intervening lines should be inspected. Once you have oil proceeding from the port, reassemble the bar and chain. Check for proper oiling by running the outer tip of the bar (at speed) near to a piece of cardboard--it should throw off a thin line of oil onto the cardboard. Hope this helps!
May 31, 2010 | Husqvarna 16" Chainsaw Chain Saw Bar...
My Poulan E300 Electric Chainsaw stop oiling the chain and bar
Hello JK; I am hesitant to answer this, these are all Poulan electric chainsaws that appear when the parts source is searched for Poulan Electric Chain Saws:
400E Poulan Pro Electric Saw
http://www.ordertree.com/modelinfo/PWE/400E-Poulan-Pro-Electric-Saw/75.400E-Poulan-Pro-Electric-Saw.1.59.1.html
400EX Poulan Pro Electric Saw
http://www.ordertree.com/modelinfo/PWE/400EX-Poulan-Pro-Electric-Saw/75.400EX-Poulan-Pro-Electric-Saw.1.59.1.html
ES400 Electric Saw
http://www.ordertree.com/modelinfo/PWE/ES400-Electric-Saw/75.ES400-Electric-Saw.1.59.1.html
PP250E Electric Saw
http://www.ordertree.com/modelinfo/PWE/PP250E-Electric-Saw/75.PP250E-Electric-Saw.1.59.1.html
PP300E Electric Saw
http://www.ordertree.com/modelinfo/PWE/PP300E-Electric-Saw/75.PP300E-Electric-Saw.1.59.1.html
All are plumbed the same to my eye. I assume you cleaned and tested the oil pick-up within the tank. If everything you say is true if the pump is driven it should oil.
1. What causes the pump to pump? I cannot tell from the IPLs. If gas and not gear driven, an impulse line (pressure/vacuum) from the crankcase drives it. There can be no impulse line on an electric and I see no gear. Does it rotate to pump oil? What imparts the rotation?
2. What purpose does item 27 (pinion) serve? Is it supposed to drive the pump? Is it missing teeth?
3. What is the purpose of item 44 (check valve). If it is an oil tank vent, and not opening, you are creating a vacuum in the tank if the pump is operating. Loosen the oil cap and see if it oils. If yes replace the check valve.
I think Joe Schmoe is saying Poulan redesigned the oil system to eliminate all the hose couplings. It makes sense, one hose from oil pickup (filter on hose end in tank) to bar is much less likely to leak, also no restrictions for any particles in the hose to form a clot on. I see nothing on my research to support Poulan doing that. There are a couple of new models that I cannot find an IPL for so it is possible. I have headache JK. If this does not solve it is not because I did not give it my all. Please post back (below) with success or failure. If successful what was the cause. TIA
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 29, 2010 | Poulan Pro Chain Saw 46cc 20"
McCulloch IPLs
Lou
Jan 23, 2010 | McCulloch Garden
Gas/oil ratio
Usually its 50 for 1 for most chain saw...
Sep 07, 2009 | Garden
McCulloch Fuel Gas Line Filter Titan 50 57 Logo
124 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
