Why do my flame on my dyna glo gas burner go out on model RMI 80ng
I light it and after a short time it goes out
    Scholar:
  • 146 Answers
Here are instruction for cleaning your thermocouple.
http://www.allpartsinc.com/mmALLPARTS_NEW/Others/Reseating%20Instructions.pdf
Posted on Dec 03, 2014
  • 3280 Answers
SOURCE: Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Posted on Feb 07, 2009
techline
  • 39 Answers
SOURCE: I have a Dyna-Glo vent-less wall mounted natural gas heater
If it is a few years old, it could be the thermocouple. These are usually available from Lowes. Take your model/serial # and if you can, take the old part too.
Posted on Dec 11, 2009
TheMobilian
  • 8220 Answers
SOURCE: cant find set screw on pilot burner. model no. rmi 70ng
Set screw for what? To raise the flame? Not one. What you gotta do is clean out the pilot. Least bit of dust makes the safety think oxygen is low and shuts down the heater. I flush the pilot with a drop of rust busted then I use the long spout on it to blow out the pilot. You could use a straw tubing or shop air. Take a look at the demo HERE
A great page that shows where to clean the pilot and has links to more good stuff: HERE
Posted on Dec 31, 2009
FurnaceGuy
  • 74 Answers
SOURCE: The brick does not glow red you see the flame all
Both repairable and dangerous. The burner need blown out with a air compressor. This should take care of it. The unit not glowing red will create CO. Which will make you sick or even can kill you.
Posted on Jan 06, 2010
SOURCE: I have a Dyna-Glo unvented
MAKE SURE THERE IS AMPLE FRESH AIR IN THE ROOM, SOME MODELS ARE MADE TO NOT LIGHT IF THERE IS NOT ENOUGH FRESH AIR. RON G.
Posted on Dec 01, 2010
I have a dyna glo 30,000btu lp ventless wall heater. I know it needs the ingniter replaced. I have tried to light it by hand and can not. It seams like their is know gas getting thru,is this possible
yes you have to get the thermo couple hot in order to get the gas valve to open to ignite the main flame
You are probably trying to light the main flame and not the pilot
light
Hold the pilot light button down and put flame to the pilot light opening
You need to be very careful depending on the type of flame you are using to light with the thermocouple could get hot enough to open the main burner flame and it will ignite
I suggest replacing the igniter rather than doing the above step
Oct 13, 2013 | Dyna-Glo Heating & Cooling
I have a dyna-glo model rmc-40lpt, the pilot light is hard to light up, most of the timr I must use a match to light it....after its lit , the burner bar will fire up just fine , high or low but the flame...
are you saying it lights back to the orfice ?? if so i would say the pilot needs cleaning out a long with the burner which could be blocked with dirt or fluff and at the airports to the burner , and the ignition could need cleaning ,
Sep 26, 2010 | Dyna-Glo Heating & Cooling
Pilot will not light- rmi-80ngt-30,000 btu
if it wil light and wont stay lit replace your thermal coupling
Jan 23, 2010 | Dyna Glo "" Natural Gas Heater Mn200tba
The brick does not glow red you see the flame all the time, goes up pass the brick. Is this repairable or dangerous? (Dyna glo gas wall heater -model RMI-70LP)
Jan 06, 2010 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Cant find set screw on pilot burner. model no. rmi 70ng dyna-glo wall gas heater.
Dec 31, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
I have a Dyna-Glo vent-less wall mounted natural gas heater model number RMI-60NG Pilot light ignites.However no gas will supply too the burners.Causing them to be inoperable.What might be the cause of...
Dec 11, 2009 | Dyna-Glo Heating & Cooling
I have a RMI-70LP Dyna-Glo 18,000 btu unvented room heater. Can it be converted to natural gas?
These can be converted by changing the orface on the heater and also the regulator. Best to contact your gas company or Dyna Glo to obtain the correct orface for that particular heater.
Oct 08, 2009 | Dyna-Glo Heating & Cooling
Dyna-glo parts
Feb 03, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
The pilot light won't stay lite
Flame is way too high on pilot . blocked injector or hole on injector is too big . Being sucked off by main burner .
Jul 04, 2017 | Dyna-Glo (PPH16-LP) Utility Heater
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
