Question about Vizio VT420M LCD TV
Hi I have a vizio vt42om the logo lights up then goes off is that the inverter board or the power supply or just the fuse
I turned it off for about an hour then held the power button for 1 min still did the same thing
    Top Expert:
  • Vizio Master
  • 74,377 Answers
Sounds like main board fault. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Dec 02, 2014
  • 191 Answers
SOURCE: VIZIO LCD 26 INCH model# VW26L HDTV10F NOT TURNING ON
unplug ur backlight inverter plug &power on to see ,if it doesnt on , change ur mainboard
Posted on Nov 10, 2008
  • 718 Answers
SOURCE: Vizio L37hdtv10a fails to fully turn on
You will have to isolate the main board and Inverters.
Unplug the inverters and turn on the set.
If it "turns on" then try re-connecting each inverter seperately to see if only one is causing the problem.
Posted on Mar 07, 2009
djchillsnyc
  • 151 Answers
SOURCE: Power is there, but TV won't turn on
stored voltages are high no touching these circuts becuase they hold charges and alot of screws.
fualty capacitors you say after a while it stays on theres a full charge in the unit theres some type of discharging effect on the set after its off for a while. voltage goes to low or unstable after it is off for a while. your better off getting the service docs for this set if you want to diy..other wise get a tv tech to check it for you. hope this helps
Posted on Jun 25, 2009
  • 27 Answers
SOURCE: Vizio VX42L LCD TV died?
it is the power supply. in the given scenario like yours, the PSU is the suspect in 90% of the cases.
Posted on Apr 09, 2010
Testimonial: "alteans is very helpful."
budmrtn
  • 11361 Answers
SOURCE: Vizio SV470XVT1A has no backlight
The 24vdc is turn on by the signal from the main logic board, it is not always on, the standby 5vdc is always on. So yes it can be the power supply board is bad, but just to besure we need to find out if it is getting the turn on signal from the main board first.
You can have 24vdc at the inverter board and it will not light up the CCFL until it gets the signal from the main logic board to turn the lamps on (this is the STANDBY condition, the TV is on but the screen in not lit up util it see the video signal).
Send me good clean and clear pictures of the power supply board, budmrtn@aol.com, connectors of the Power supply, bottom side of the board, then I may be able to tell you which pin is a control input pin. Most people will just throwing parts in and hope that they one of the parts will fix the problem. Used Power supply module for this TV is over $100. http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=delta+DPS-379AP&um=1&ie=UTF-8&ei=USsxTKn3J6TonQfFlJGEBA&sa=X&oi=product_result_group&ct=title&resnum=4&ved=0CCsQrQQwAw
http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+SV470XVT+
Posted on Jul 05, 2010
Testimonial: "Bud helped me fix my TV! It was only 1 1/2 years old. I was looking at a repair bill close to $300 - $500 and I fixed it with a $60 board! Thanks!!!"
Sound but no picture. Vizio E470i-AO
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.....
Jul 18, 2016 | Vizio Televison & Video
TV turns on, lights up, but no menu, logo or any other picture. There is sound though. Wondering what board to replace. thanks
Jul 04, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
The power button on the corner of my TV lights up but when I turn on the TV the VIZIO logo lights up but immediately turns off and the screen stays black. What could be the problem?
http://electro-medical.blogspot.com/
May 27, 2016 | Vizio M190MV 19 in LCD TV
How do I fix problem with Vizio m550vse LED TV? Flashlight test reveals picture and no back lights are visible.
Nov 20, 2015 | Vizio 55" Class LED 1080p 120Hz HDTV,2.49"...
How to fix my vizio tv that has power but no picture
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 09, 2015 | Vizio Televison & Video
Getting 120 v to white plug where it first plugs into board should i have power reading at fuse?
yes after to the fuse you must have a reading of 120vac if none the fuse get busted. if the 120v is present then it will goes through the rectifier bridge diode and primary capacitor of the power supply board to have an stand by voltage at the power supply board. when you press the power button it will send signal voltage coming from the main board to turn on the power supply board. the you will need to get an output voltage at the power supply board of 5v dc, 12v-16vdc and 24v to turn on the all the circuit, the main board sound amplifier and the inverter board for screen back light.if you can get those supply the tv unit will not turn on.
Nov 09, 2012 | Vizio L37 Television
I hae a vizio E320VL, i have replace main board and the power suplly, and it still won't stay on.
hi. you sure your replacement -- power supply & main board in good condition???? lcd present 5v , 12v, &24 v ??? if no you need going back power supply. if yes. you need to replace inverter board as possible. good luck!
Sep 01, 2012 | Vizio L32 32 in. LCD HDTV
Where is the backlight inverter located in vizio sv471xvt?
Larger sets such as the one you have, will have two inverters. They usually are attached to the backside of the LCD panel on the left and right sides. If you don't see them there, then your inverters are built into your power board. If your power boards are either one of these below, then that is the case. If your inverter circuit is at fault, you will have to replace the entire power board.
http://www.shopjimmy.com/vizio-0500-0407-0800-power-supply-unit.htm
http://www.shopjimmy.com/vizio-0500-0412-0800-power-supply-unit.htm
May 20, 2012 | Vizio SV471XVT 47 in. LCD TV
I have no power in my Vizio VO22L LCD TV. I replaced the power board and still nothing. The Vizio logo in the front does not light up when plugged in. What else can it be. One expert said the cable or...
you have to make sure voltage is getting to the Power supply board, if you know how to check for the 110-120v ac at the board and that there is no line fuse in between. If you are getting power at board then I would make sure the PS are good. You also can check to see if you have voltages going to other boards, Inverter boards go bad in this set alot, but you should still have logo light up white or amber, To get it right you must check voltages, carefully.
Jan 19, 2011 | Vizio VO22L 22 in. LCD TV
Vizio VT420M LCD TV Logo
157 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
