Question about Garden
<!-- from fixya rte -->Find the oil line schismatic for titan 50 - Garden
Fuel ratio on a titan 50?
books say 50.1 ratio is best
use the correct 2 stroke oil as normal engine oil is not the best oil to use.as it dilutes too quickly and doesn't provide proper lubrication to the moving parts
A proper ratio is when you can just seek blue from the exhaust
no smoke is too lean on the oil
Mar 29, 2015 | McCulloch Garden
My 2005 nissan titan oil pressure gauge just jumped to high. I turned the motor off and turned the key on without starting the motor and it went to normal. Soon as I starred the motor, it jumped right back...
When you say it was "normal" with the engine off and the key on, do you mean normal as 40-50 psi, or normal, as 0 psi since the engine was off and there should be no oil pressure? This is important because if you are reading 40-50 psi with the engine off, it is not surprising that the gauge goes "too high" once you start the engine. If the gauge is at 40-50 psi with the engine off and the key on, then there is a problem with the gauge or the sensor. It is not an overpressure issue. As long as the engine seems to be running normally otherwise and is not clacking internally or other such things that would indicate oil pressure issues, I would feel safe using the vehicle until I could have the oil pressure circuit diagnosed and repaired.
Mar 12, 2015 | 2005 Nissan Titan
Find where the oil lines go on a titan 50 chain saw
Being around chainsaws for 40 years I can make an educated guess.. I believe this is a manual oiled saw where your thumb provided the oil as it was pumped from the reservoir to the bar. Again an educated guess says that the thumb pump, pressurized the reservoir. Newer models had gear driven but still with the thumb assist oil pump.
After just 15 minutes of use you had 2 side effects from use of this saw, tingling hands and a ringing in your ears. I'll be with a friend tomorrow that had one, if I can correct or add to this I will.
Good luck
jeromekj
Dec 02, 2014 | McCulloch Fuel Gas Line Filter Titan 50 57
18hp titan outboard 2 stroke with outside tank.its a 25ltr tank.want to know proper mix or if i use 5ltr fuel the proper mix
50 to 1 oil gas mix on 99% of all outboard engines. 1 pint to 6 gallons.
I like Quick Silver oil or Sierra oil. Hope this helps.
Oct 08, 2013 | Boating
High oil pressure alarm on titan
titan engines are pretty bullet proof. we dont see any issues with those. what oil grade are you using?? it calls for 5w30. If you are ok there, than i would look at the oil pressures sending unit first. about $40 piece. nothing expensive. i would rool out engine issue or oil pump problem.
Nov 18, 2010 | 2006 Nissan Titan
After installing my titan N100 the breaker keeps tripping went from 50 amp breaker to 60 and still keeps tripping how do Isolve this problem?
You had an instant heater there before? Or a different type? Your breaker numbers don't mean anything to me, I need amps and volts, what is the amp? 30? and the volt is 220? Or are you in Europe?. And you had the four wires in there before? And you have all 4 wires on the heater line? And the heater is grounded? It should work. Unless it is not getting enough juice, but you already upped the amp. Let me know what you got.
Jul 03, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
I have to change the oil pump of my 2004 titan
BEHIND THE TIMING COVER ON THE CRANKSHAFT
Mar 14, 2010 | 2004 Nissan Titan
I'm looking for A service manual for A McCulloch
This is an IPL for a Titan (11-600152-03):Please ensure this is your saw
http://www.ordertree.com/modelinfo/MCC/11-600152-03-TITAN-50-05%2F88-to-02%2F95-IPL-222956/139.11-600152-03-TITAN-50-05%2F88-to-02%2F95-IPL-222956.1.59.1.html
There are others here (IPL #11-600152-03 - just above this one. There may be others 12- etc.) :
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
This is an international collection of chainsaw enthusiasts, sellers/mechanics. There are McCulloch threads where repair and overhaul are discussed.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
This thread is where to request a service manual:
Beg for manuals thread (ArboristSite) (free to join)
http://www.arboristsite.com/showthread.php?t=72322
one was requested here:
http://www.arboristsite.com/showthread.php?p=1342509&highlight=titan+50#post1342509
with no answer published. Good luck
Lou
Jan 23, 2010 | McCulloch Garden
Gas/oil ratio
Usually its 50 for 1 for most chain saw...
Sep 07, 2009 | Garden
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
