Question about HEWLETT-PACKARD Hewlett Packard HP ProBook 6555b - Turion II P520 .3 GHz - 15.6in. TFT (S7840144) PC Notebook
I have a HP Probook laptop 6555b and last week while using it , it displayed that it was not charging. I checked the connector with a multimeter and found it was damaged.I replaced with a spare one t
I have kept restarting but the battery charge light only flashes but the laptop does not start. Checking the battery with a voltmeter shows that it has a charge of 10.8 volts which is the correct rating according to the manufacturer.
    New Friend:
  • 8 Answers
Check your Adapter Cables properly connected or take your battery from the Laptop and put it back. Then try restarting. If nothing helps check your Adapter with another same model Laptop. If the Adapter working well then your Battery is dead!.
Posted on Dec 02, 2014
rommelalilin
  • 2178 Answers
SOURCE: battery shows 100% charged,but as
Check the Control Panel - Power Options and see if it's in the High Performance mode, if not set it to that.
Posted on Oct 28, 2010
bendarden
  • 984 Answers
SOURCE: HP probook 4520s battery shows: 0% available,
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave', for today.
I suggest that you click on the following link and and utilize the FREE Microsoft Fixit software: CLICK HERE
All the best
Ben
Posted on Oct 07, 2011
eng_darwish1
  • 233 Answers
SOURCE: Battery light on my hp probook 6550b flashes when i try to charge it but it will not turn on!!! How do i fiix it?
flashing battery light is normal when the battery is empty ,and the orange led should become steady when you insert charger then it should turn to blue and after the battery is fully charged the led is turned off, i think the problem is that no charging happens check your adapter and the DC input
Posted on Feb 09, 2012
  • 11 Answers
SOURCE: hp probook 4530 ac connected indicator flashing. will not power up
Remove the battery, Plug in the AC charger. Push and hold the Power on button for 45secs. If this doens't reset. The fault is most likely the System/Motherboard. If the unit is under warranty, contact HP and arrange a repair.
Posted on Sep 01, 2012
  • 11 Answers
SOURCE: hp 4510s not charging
Okay, if the unit boots okay, and only getting to 80% charge it could be a Windows 7 issue not reporting the charge correctly. Check the Microsoft Knowledge base for a resolution.
Otherwise it could be a faulty mainboard.
Screen pink vertical lines
Probably the tft screen, this can be easily tested by plugging an external screen in. If they both give the same issue, you have a GPU issue.
Dec 14, 2013 | HEWLETT-PACKARD Hewlett Packard HP ProBook...
Error 0xc000000e comes up and i cant do anything
With a laptop that becomes completely un-responsive to all keys even the power key, then you last resort is to un-plug the laptop and gently remove the battery. This will power down the machine. Leave the battery out while you are troubleshooting the problem.
If you are still having trouble with this, Lawrence has many fine PC repair company's like UniComputers on 23rd st.
Jan 13, 2013 | HEWLETT-PACKARD Hewlett Packard HP ProBook...
4710 hp monitor cable replacement
The problem is most likely the video cord running from the LCD screen to the motherboard that has come loose from the plug socket, or there is a intermittent issue in the cord itself.
Mar 13, 2012 | HP ProBook 4710s Notebook
New to get instructions for replacing Black Keyboard for Hp Probook 4510s Series laptop.
Here is a pdf site manual for that.(but this is site is kind a slow in loading)
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01905586/c01905586.pdf
Here is a video tutorial on how to replace a hp probook keyboard (But this is for 4710 model, i think you can get some ideas from here)
And finally if this all doesnt help you here is a site containg instructions on how to replace your keyboard .
http://www.sparepartswarehouse.com/blog/post/how-to-replace-the-keyboard-on-the-hp-probook-4510.aspx
hope I helped you, please rate my solution thanks.
Jun 30, 2011 | HP Computers & Internet
I have now Win XP (SP2) on my HP ProBook 6555b. It dont wona shut down!
Hold down the Ctrl key and the Alt key then press the Del key. This will then bring up the Task Manager. Then click on Shut Down then click Turn Off.
This will then shut down your laptop properly.
May 25, 2011 | HEWLETT-PACKARD Hewlett Packard HP ProBook...
Screen is black; cannot get anything to display Have tried to reboot several times; pressesed Fn+f4 Any suggestions? Thank you! Nancy
Turn it off, take out the power supply and battery. Now open it and take out the button battery. With those things out, press and hold the power button for 10 seconds to drain residual charge. try to boot it up. It should work now
Mar 30, 2011 | HEWLETT-PACKARD Hewlett Packard PROBOOK...
I have ProBook 6555b for just a few days and my mute button is stuck in orange. No matter if sound is mute or not, button doesn't change to light blue..
I'm not totally sure with the specific model you mention, but I DO know that many of the HP 6xxx series laptops, the light board above the keyboard are touch sensitive, have you tried actually using your finger to touch the amber light itself and see if it changes to blue? (or the volume bar?)
Try tapping a few times with your finger and see if that helps.
Good Luck
Mar 14, 2011 | HEWLETT-PACKARD Hewlett Packard HP ProBook...
HEWLETT-PACKARD Hewlett Packard HP ProBook 6555b - Turion II P520 .3 GHz - 15.6in. TFT (S7840144) PC Notebook Logo
73 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
john smith
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
