Question about BT Lands Phones
How do I find redial the last number I dialed on my BT 8500 call guardian telephone
SOURCE: programming numbers into telephone
to store a speed dial on the kx-t7730 with the Advanced Hybrid System KX-TA624 you press the following keys
<pick up the receiver>
<the number you want to have as speed dial>
<the number you want to dial>
<press the square shaped key next to 0 and 9>
<wait for dial tone to return>
<hang up>
To call using the now saved speed dial, press the square shaped key and then the number you have saved to speed dial
For example
<pick up receiver> 2*1555555555<square key> <wait for dial tone> <hang up>
This will mean that when you press the square key and 1, it will dial 555555555
Posted on Jan 25, 2008
  • 112 Answers
SOURCE: Redial for 10 digit dialing
You have to setup ARS. Not easy if you don't Know how to program Toshiba system. What Toshiba system do you have
Posted on Jan 11, 2009
SOURCE: when I redial a number outside of my area code, how do I set up my phone to redial an automatic 1 before the number I want to dial?
I can't redial.. How do I set up my phone to redial an automatic 1 before the number I want to dial? i have a GE digital 5-8
Posted on Aug 14, 2009
cnavarro
  • 2460 Answers
SOURCE: Automatic redial malfunction
It's been a long time since I have used Panasonic analog phones, but the redial function in them used to be mechanical. It dialed 15 times with a 45 second pause between attempts. The key was, it expected you to pick up the handset, cancelling the redial if you got an answer.
If you got an answer and didn't do anything, it hung up and redialed again until you picked up the handset!
Could that be what your system is doing?
Carl
Posted on Sep 14, 2009
SOURCE: my phone dials too fast.
I had the same problem with a model 6325-4. Worked fine for the first week. Then, tone dial with redial, directory, etc was too fast for system to register the number.
Called Vtech support. After a 15 hold, 5 minute explanation and tech listening to a reproduction of problem over the phone, she asked that I perform a complete system reset (I called via my cell).
I unplugged power from base first, then removed battery from all hand sets. Powered down for ~3 minutes (with tech waiting on line the entire time).
I powered up base first and then reconnected all handsets. Selected a handset at random and performed the same dial from directory test I had done just before power down. The thing worked again. Call went through just fine. Tried several other selections in directory with same positive results. Now, if the system just stays stable and working.
Hope this helps..
Posted on Feb 12, 2011
How to trace caller numbers on my BT telephone?
Dial *69 and that should give you the last caller, some phone company's will charge you for this service...
Feb 14, 2014 | BT Hudson Plus 1500 Trio Dect Cordless...
Automatic redial phone option
On most cell phones, to redial the last phone number dialed, press the green phone icon when the keypad is displayed on the screen. You can only redial the last number dialed. To obtain a copy of the user manual, follow this link and download the pdf. http://www.gsmarc.com/huawei/ascend-g610/manual/
Nov 14, 2013 | Huawei Cell Phones
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
Where is the re-dial?
Hi, Hope this helps.
Making a call using the redial list
The last 5 phone numbers dialed are stored in the redial list.
  1. 1 {REDIAL}
  2. 2 Press {^} or {V} to select the desired number.
  3. 3 phone icon.
I have also inserted a link to the manual below: http://service.us.panasonic.com/OPERMANPDF/KXTG5631S.PDF
Hope i have helped, ALAN
Jun 28, 2011 | Panasonic KX-TG5632 Phone
LOOKING FOR A MANUAL FOR lucent 9510 WIRLESS TELPHONE
Hi, Click this link for more data : http://www.vineland.org/tech/phones.pdf Regards, vote please, Jay
Lucent Telephone User's Guide (All Models) For corrections to this document, contact Steve Dantinne at sdantinne@vineland.org or 856.794.6700 x 2350 VoiceMail Welcome to Audix! The first time you use Audix you must record your name and create a password! To Log In: 1. ON Premise Dial 2099 OFF Premise Dial 856-794-6700 extension 2099 You may also dial the main school number to access the voice mail system 1. The system will ask for your extension number followed by the # sign. Note: Teachers will use their voicemail number followed by the # sign It is not the classroom extension number. 2. Enter First Time Password # sign. Record Name As you use Audix, your name will be heard by you and other Audix users. Press 1 Speak your name Press 1 when finished Press # to approve Create Password You will be required to enter a new password with a minimum of 5 digits followed by the # sign. The maximum length of a password is 15 digits. Reenter your password for confirmation followed by the # sign. To Create a Personal Greeting This is what callers will hear when they reach your mailbox. Press 3 anytime you wish to do anything concerning your greeting Press 1 to create your greeting Press 1 to indicate the greeting number you are going to record then speak your greeting Press 2 then 3 to replay the greeting Press # to approve Press 1 to activate for all calls **X or **9 to hang up. To Get Messages 1. ON Premise Dial 2099 OFF Premise Dial 856-794-6700 extension 2099 You may also dial the main school number to access the voice mail system 2. Enter your extension or voicemail number then press #. Note: Teachers will use their voicemail number followed by the # sign It is not the classroom extension number. 3. Enter your Password then press # You are now Logged in. Press 2 (You will hear the day, date and time the message was left and the length of the message. If the message is from another extension you will also hear the person's name and extension number) This is the header To play the message press 0 To listen to header again Press 2 then Press 3 To listen to message again Press 2 then Press 0 To Delete message Press *D To skip to next message Press # To forward Press 1 then Press 2 (record your comment) Press # when done recording. Enter the extension numbers you are forwarding to followed by #. Press # when done addressing. Press # to send. Call Handling Features Volume Control The volume control button will adjust three items. 1. If you are not using the telephone, it will adjust how loud or how softly the telephone rings. Press the up arrow to make the telephone ring louder. Press the down arrow to make the telephone ring softer. 2. If you are using the handset or receiver, it will adjust the sound of the incoming voice. The up arrow will make the voice louder. The down arrow will soften the voice. 3. If you are using your speakerphone, the volume control will adjust the sound on the speakerphone. The up arrow will make the sound louder. The down arrow will make the sound softer. Each item is independent of the other, depending on the device being used. That it what the volume bar will adjust. Hold The hold feature puts a call on hold until you can return to it. To keep a call on hold while you answer another call or perform another task. Press HOLD. The green light next to held call will blink. To return to the held call Press the call appearance button of the held call. Redial The Redial (or last number dialed), feature automatically redials the last extension or outside number dialed. To redial the last number that you dialed. 1. Press REDIAL. The last number you dialed is automatically redialed. Note: The redialed number can be an outside number, an extension, or a trunk or feature access code. Transfer The Transfer feature allows you to transfer a call from your telephone to another extension or outside number, if allowed. To send the present call to another extension or outside number 1. While on a call, press TRNSFR. (Dial Tone). Present call is put on hold, and the green light next to the held call blinks. You are given a new call appearance. 2. Dial the number to which the call is to be transferred. 3. Remain on the line and announce the call; if the line is busy or if there is no answer, return to the held call by pressing it's call appearance button. 4. Press TRNSFR again. Call is sent to the dialed number. 5. Hang up. ...............
Jan 21, 2011 | Cell Phones
I have Toshiba dkt2010-sd telephones and need to update our speed dial directory, but the person who did this left. How do I reprogram the numbers?
it depend on the system, but usually on the main phone Ext:10 or 200 press redial then speed dial then "BIN" number ( 10-49 for user 60-99 on system dials or 600-699 for large system dials) then type the number with 9 in front if you dial that to dial out .. finish by pressing redial.
Dec 22, 2009 | Toshiba DKT-2010 Corded Phone
How do you set the timeand date on a toshiba dkt
Please try this..
  1. From main console phone (lowest extension number i.e. x100) pick up handset and dial following codes:
  2. For Date: 651 YYMMDD Redial ----(YY=year, MM=month, DD=day)
  3. For Time: 652 HHMMSS Redial ----(HH=hours in 24hr clock, MM=minutes, SS=seconds)
  4. For Day of Week: 653 X Redial ----(X=day of week 1=sunday, 2=monday....etc.)
If won't work, try this
From Extension port 00 (usualy station 200)
  1. Lift Handset Dial #652
  2. Enter Correct Time HH MM SS
  3. Press Redial
  4. Replace Handset
Regards,
Jeep Brainy
Aug 10, 2009 | Toshiba DKT-2020-SD telephone
Program and use speed dial numbers
speed dial must set at port ' 00 ' or 000
to check, use display phone, press #402 or #401
speed dial code are from 60 to 99
to set press speed dial , redial , speed dial code eg. 60, press 9 follow by destination number asn redial to confirm
to use speed dial to call press speed dial short key follow by speed dial code or *60
May 26, 2009 | Toshiba Lands Phones
SPEED DIAL
station speed dial:
redial, speed dial 10-49
telephone number
redial
info@ameritelnj.com
Tony
Jan 22, 2009 | Toshiba DKT2010SD Phone
HS820 won't activate 'voice dial' on Blackberry Pearl
Did you find a resolution.  This is the same problem I am having with the Curve.
May 22, 2008 | Motorola Mobility HS820 Consumer Headset
Lands Phones Logo
207 people viewed this question
Top BT Lands Phones Experts
Steve Sweetleaf
Steve Sweetleaf
ptpumpman
Are you a BT Lands Phone Expert? Answer questions, earn points and help others
