Question about Canon DR Office Equipment & Supplies
Does error P07 on a Canon DR-G1100 indicate that there is a paper jam or that a counter needs to be reset?
  • 24 Answers
P007 indicates that a document has jammed before exiting the registration post sensor. Make sure the path is clear and no staples are stuck in the rollers. I like to use a microfiber cloth, with a small amount of 50/50 alcohol on it, to wipe down the entire feed path; top and bottom. The microfiber cloth will grab staples that may be wedged between the rollers/roller openings. Beyond that, it could be a timing issue from a bad/loose drive belt. Actually, there are quite a few things that could cause a paper jam before exiting the post registration sensor. Wipe it down and let me know.
Scan-R-Store
Posted on Jan 24, 2015
mohanchennai
  • 490 Answers
SOURCE: iDoc scanner Canon DR-9080C has a P00 error when not paper jam found?
There are sensors in the paper path. Just blow air to ensure that there is no shreds of paper is blocking the sensor.
S. Mohan, Chennai
Posted on Jun 30, 2008
SOURCE: Canon Dr-9080C scanner
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
Posted on Jan 31, 2009
  • 32 Answers
SOURCE: Canon DR-3080cii paperjam
The 3 paper sensors are located along the center of the paper path. They are: Registration (lever type) on the bottom between separation & registration. Look for lever damage or torn paper. Scan Start (reflective) on the top between registration & front reading roller. Clean the sensor window with qtip & alcohol. Delivery (lever) at the eject roller. Same as reg, but harder to see due to location.The feed roller exchange kit is 6915A001. The rollers in this machine are not considered user replaceable.
Posted on Apr 07, 2009
SOURCE: My Canon DR-2050C keeps jamming when I try to scan more than 1 page???
I finally solved my problem. Now it works like new.
Cause:
- The spring that returns the next sheet detector (small black plastic rocker arm between the two rollers on the back side) came off. So the scanner cannot detect transition from one page to the next. This spring is located inside the device and you cannot fix it from the outside.
- You know if you have this problem if you don't hear a "click" sound after each page is scanned. Without the spring attached the rocker will not return on every page. When it doesn't return the scanner think it is still on the first page and will not scan the next page. The "click" after each page is NORMAL. Without the click is the first sign your spring came off.
Solution (Only recommended for people handy with hardware and the unit is no longer under warranty)
1. Turn off power and unplug the device.
2. Pop off the plastic cover to the back of the scanner
3. Remove the screws that holds the plastic cover to the back.
4. Remove the screw by pushing on the retainer clips. DO NOT loosen any gears or motors.
5. Locate the rocker arm and re-connect the (very small) spring
6. Warning - if the LED light pipe falls out be careful how you put it back. This is a transparent widget at the top to route a LED light to the top of the device to indicate the power on status.
Sorry I didn't take pictures. If this sounds too complicated, send it to Canon for repair. Took me about a day to figure out exactly what was wrong and how to disassemble the scanner to fix it.
Good luck.
Posted on May 26, 2009
mohanchennai
  • 490 Answers
SOURCE: Paper tray at front of scanner will not lift.
Disconnect the scanner from the Comp, Try 'page counting'. If the papers go through, then you know feed mechanism is okay. if the tray is not lifting, then you have a problem. Use Qumatool software and check if the tray is lifting. If the scanner tray if lifting then the motor is okay, if not, the lifting motor may need a check.If the motor is okay, but tray not lifting means the sensor in the paper tray is faulty. Check this out.
S. Mohan, Chennai, India
Posted on Jul 28, 2010
My Cannon pixma 280 printer wont print it says error 5B00 What can I do?
How To Fix P07 or 5B00 Error On Canon MP Series Printer - YouTube
? 1:38
https://www.youtube.com/watch?v=HvBpioLPm3M
Jul 17, 2012 - Uploaded by Internet-Ink
This video from Internet-ink.co.uk will instruct you on how to cancel the P07 error on the Canon MP series ...
Canon PIXMA MP280 ERROR 5B00 - YouTube
? 2:39
https://www.youtube.com/watch?v=sYhpW2UgEVw
Jul 4, 2016 - Uploaded by Ozone Spot
Coment? el error 5B00, cualquier pregunta no duden en mandarme un correo. Lo responder? ... Canon PIXMA ...
How to Fix Canon Pixma iP2770 error 5B00 - YouTube
? 6:18
https://www.youtube.com/watch?v=Ypi6wgoMo04 Nov 20, 2014 - Uploaded by ishadi aplus
Canon Pixma iP2770 error code 5B00 mean the waste ink counter reset (yellow and orange light ...
How to repair error 5B00 or P07 on Canon printer MP280 ' MP287
acer-mini-laptops.blogspot.com/2015/04/how-to-repair-error-5b00-or-p07-on.html Apr 16, 2015 - Error type 5B00 or P07 on Canon MP280/287 printer can be caused by several reasons. To solve this problem, you need to do some simple ...
How to get rid of the 5B00 error message on canon printers ' en ...
www.en.rellenadodecartuchos.com/.../how-to-get-rid-of-5b00-error-message-on-cano... This post will teach you three different ways of solving the 5B00 error message on regular and multifunction canon printers.
How reset the full pads in Canon PIXMA MP230 error 5B00 ' en ...
www.en.rellenadodecartuchos.com/.../how-reset-full-pads-in-canon-pixma-mp230-err... Learn here how to eliminate the error 5B00 Canon PIXMA MP230 printer, follow all the steps and solve your problem.
error 5B00 in Cannon 280 printer Google Search
Jul 11, 2017 | Cannon Office Equipment & Supplies
Canon DR-G1100 Intermittent scans half of page vertically. Sometimes half of page is very light vertically?
first off all change your cartage drum and after that you can chek it and post your question again dear
Nov 20, 2014 | Canon imageFORMULA DR-G1100 Production...
Canon mp258 error p07
This seems to be an issue will a full ink absorber. This guide shows how to reset the counter and if the comments are to be believed it works a treat.
Aug 15, 2012 | Canon Office Equipment & Supplies
How solve error p07 in canon mp287
First Step : Set The Canon PIXMA MP287 To Service Mode. To do that, follow this step, it's so easy.
  1. Turn off the printer without pulling the power cord.
  2. Press and hold the RESUME button (Green button), keep holding it and then press the power button, do not let go yet.
  3. Keep holding the power button, now release the RESUME button and then press theRESUME button for 5 times and quickly release the POWER button.
  4. When the printer entered the Service Mode, all LED will stop blinking.
Second STEP : Reset Canon PIMA MP287 Using Resetter. Open the mp287.exe, and then follow this step.
  1. Insert some A4 paper, the printer will print the result.
  2. Look for "Clear Ink Counter" section, press the "Main" button and wait for the message "A function was finished" and then press "OK" button.
  3. Press the "Platen" button located beside the "Main" button.
  4. Look for "Print" section, press the "EEPROM' button, select "Rear Tray" and pres "OK" button.
  5. The printer should printout the result. That's all, you may turn off your printer now. Sometime you need to press the POWER button several time in order to turn off the printer.
source:http://stepblogger.com/tutorial/tutorial-how-to-reset-canon-pixma-mp287-using-resetter-tool/
Jul 05, 2012 | Office Equipment & Supplies
Canon Pixma 210 series has an error code 6000, won't print or scan
Hope this helps
With thanks to a canon tech
Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
May 22, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error code 5010 and 5C20
on't know this error code, but this info might help
With thanks to a canon tech Ok Well again I will repeat this answer with a titch more detail.
button pressing
Error Code :
E3-3 = Paper jam
E4 = No ink
E29 = EEPROM error
May 14, 2009 | Canon PIXMA MP610 InkJet Printer
P00 Error with no paper jam
See this link:
Look for reference to P00 error
http://74.125.47.132/search?q=cache:CSQKZT0GyBEJ:downloads.canon.com/cpr/software/scanners/5080QRG.pdf+DR-5080C+p00+error&hl=en&ct=clnk&cd=1&gl=us
Jan 23, 2009 | Canon DR 5080C Path-Through Scanner
Apr 14, 2008 | Canon DR-9080C Path-Through Scanner
IDoc scanner Canon DR-9080C has a P00 error when not paper jam found?
S. Mohan, Chennai
Mar 13, 2008 | Canon DR-9080C Path-Through Scanner
261 people viewed this question
old marine
old marine
