Question about Dell Inspiron 14R Laptop Computer (Intel CORE I3 370M GB3GB) (fndom13b1) PC Notebook
Where is wireless card in a dell inspiron 14r?
Removing wireless card
    Top Expert:
  • Dell Master
  • 26,243 Answers
Under one of the covers on the base.
Posted on Dec 02, 2014
Testimonial: "Ummm, the only cover on the base is for the DDR3 memory. No other hatch is present. I have since checked Dell's site and found a script explaining that it is under the palm rest to one side of the touchpad. Thank you so much for responding to my question, though."
  • 10 Answers
SOURCE: Dell Inspiron 6000 not picking up wireless signal
There are lots of problems of using wireless LANs in metal buildings, especially if you are trying to go outside the building and into another building. What I have had to do where I work is put an external antenna on the wireless router and use that to transmit the signal beyond the metal shell of the building.
If that still does not yeild satisfactory results, you can set up another wireless router in the "home" location with an external antenna to act as a recieving point for the other router in the office ... essentially this is setting up a site to site network. With both routers working together you should resolve the wireless drop out issue.
Bestbuy also sells a Wireless Booster, this works the same way as I explained with using two routers however if you go that route be sure you have the option to either add an antenna or you can place it near a window (glass cuts down on your signal than steel).
If this fails look at replacing the wireless card; this setup will still provide benefical even if you need to replace the card as it will provide stronger signals in stormy weather as well.
Posted on Dec 31, 2008
kamal1984
  • 1383 Answers
SOURCE: Getting wireless to work on my Dell Inspiron 1000
find switch on laptop it is wi fi network adapter switch on laptop turn on it.
Then also check your wi fi drivers are installed.
if driver are not install for wi fi downlaod from here in netwrok
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_CEL_1000&os=WW1&osl=en&catid=&impid=
then install wi fi then check.
Posted on Jul 14, 2009
johnhercus26
  • 104 Answers
SOURCE: install internal mini-pci wireless card,dell inspiron 5100 laptop
open bottom of laptop where ram and cpu is located usully in middle 2/3 screws there should be a slot arouns an inch long on board that this slots into however does your laptop have the wireless cables that run from motherboard to hinges that hold screen in place usually black1 and grey 1 which are main and aux grey is usually main
Posted on Oct 02, 2009
  • 1481 Answers
SOURCE: dell inspiron 6400 Vista : the wireless card turns off
is ur WIFI connected thru USB ?
then ur USB is losing power...
check if ur USB setting...
go to Device Manager/USB Serial Bus/USB root hub...
go to each ports one by one....right click on each check properties...check Power Mgt tab....
remove the Tick in the box that says "Allow computer to save power'....
close Device Manager/ Shutdown and restart....
Posted on Dec 25, 2009
  • 8 Answers
SOURCE: Wireless problem with Dell Inspiron 2200
First of all make sure you have the most up to date driver for your wireless card from the manifacturer..
Posted on Jan 04, 2010
Looking for a fix for my sound card
goto dells website and help and support type in your model and it will bring up drivers and downloads you will find what you need there
Jul 27, 2014 | Dell inspiron 14r-n4110 laptop intel
How can i fix error code 2000-01 42 Validation 51532 Msg: Hard Drive 0 - S/N WD-WXM1A61M4533
Dustin Larmore,
The error means that the hard drive is defective or broken You will need to have it replaced.
The Inspiron N4110 / N4120 / 14R system uses Serial-ATA II(SATA II) hard drives.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 01, 2014 | Dell factory recertified inspiron...
I have a laptop of dell of model 5420 14R inspiron and it have problem with screen, sometimes screen are fades with white and after few second it automatically removes
That is just a video driver problem, go to support.dell.com and download the latest driver for your video card and install - should fix this problem for you.
if you are unsure of what drivers to download, Dell has an auto-scan for drivers - that can help!
Aug 27, 2013 | Dell "Inspiron 14 R *Switch* Laptop Intel...
Dell inspiron n4010
Hi Martha,
Here is the Dell Drivers download site for your Laptop.
http://www.dell.com/support/drivers/us/en/19/Product/inspiron-14r
Select the Network Drivers and find the one you need.
Make sure select the correct OS also.
If you need further assistance, please don't hesitate to get back in touch with me.
Thanks, and please rate
Gary
Jul 19, 2013 | Computers & Internet
Inspiron n4010 bios needs reset
Here are 2 links to your model laptop. The first link is the Setup Guide and the second link is the serve manual.
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-14r-n4110_Setup%20Guide_en-us.pdf
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-14r-n4110_Service%20Manual_en-us.pdf
Unfortunately if there is a problem upgrading the BIOS and it fails, your system board that has the BIOS chip on it is toast. That means you will have ship it back to Dell or another company that can program your BIOS chip again.
Feb 17, 2013 | Dell Inspiron Computers & Internet
INSPIRON 14R
Tes you can provided you have a Windows XP installation CD and the Product Installation Code.
May 15, 2012 | Dell Inspiron 14R Laptop Computer (Intel...
Inspiron-14R-N4010-XP-Drivers
Hi! Actually the laptop you mentioned only ships with Windows 7 or vista. For XP drivers, try to install the drivers bundled with your laptop, or go to www.support.dell.com
Jul 03, 2011 | Dell Inspiron 14R Notebook
Iam using Dell inspiron 14R (intel corei3-370M) laptop.This laptop working is very good.Is my laptop XP supported.? Pls tell me the in my laptop XP loaded.?
Yes you can use Windows XP . It will run fine in your Laptop.
But first you need to download the proper driver for XP.
Thanks for using FixYa.
Jun 04, 2011 | Dell Inspiron 14R Laptop Computer (Intel...
I replaced the laptop screen on my DELL Inspiron 14R and I tried turning on the laptop.But when I did so,there was a series of 8 beeps on the laptop and there was a blank white screen.Can you please tell...
8 beeps indicates a video card problem. Do you see where your monitor plugs in? Is it a seperate card and is that card seated well or is the cable coming from that card plugged in where it needs to go?
May 06, 2011 | Dell Inspiron N4010 Notebook
Dell Inspiron 14R Laptop Computer (Intel CORE I3 370M GB3GB) (fndom13b1) PC Notebook Logo
56 people viewed this question
Alun Cox
