Question about Garden
My lawn mower have problems with spark plugs I have to change them every day or two . What would be the problem?
I have kept on replacing them every time they give problems
What is wrong with them?
Why not clean them?
What lawn mower?
What motor?
Is it worn out & using oil-if so there
is no fix
Posted on Dec 02, 2014
steve_baldam
  • 52 Answers
SOURCE: no spark but everything replaced new. still wont run
Doesn't sound like a coil pack fault i'd say either a bad earth or a cam/crankshaft sensor. have them both checked out by an auto electrician. Or you could be sleeping in your garage for months trying to sort the problem.
Posted on May 13, 2009
  • 297 Answers
SOURCE: Replacing Drive Cable on 05 Troy Bilt Self Propelled Lawn Mower
It is a pain in the ***!!! but not impossible to do it your self.
Posted on Aug 16, 2009
  • 202 Answers
SOURCE: engine dies when idling
this is more common on high mileage cars. you should probably replace all the coils as it's common for them to go bad on this model car
Posted on Nov 17, 2009
  • 1584 Answers
SOURCE: How do I change the lawn mower blades?
If they are riveted then replace the disc....if bolted simply unbolt.
Posted on Jan 14, 2010
agent91
  • 2100 Answers
SOURCE: having problems keeping the van running sounds
If you have water in the oil, check to see if you have oil floating in the top of the radiator. Does it blow steam out the exhaust when it is running? You probably have a blown head gasket, a radiator shop can give it a compression check, will tell you exactly what cylinder it is, and even quote you on repair. It is a common problem with a lot of cars. Expensive to fix. Hope this helps.
Posted on Jul 22, 2010
Where is the spark plug
Where is the spark plug In the cylinder head. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Tips Replace Lawn Mower Spark Plug
How to Change Push Mower Spark Plug
How To Change Spark Plug on John Deere LA 105 Lawn Tractor or Riding Mower
How to change spark plug on craftsman LT1000
Mar 27, 2016 | Garden
Kawaski 661D no spark to plugs
sounds like ingition switch is bad replace it see if it fixes it it should or check for bad safty switchs first then replace switch
Aug 28, 2014 | Encore Garden
How do i change a spark plug on Craftsman lawn mower
Mine takes a three quarter socket and disconnect the spark plug wire take the old one out and install a new one. Putting the wire back on after putting in the plug.To do it right check the spark plug gap but usually it is factory set anyway.
Jun 30, 2014 | Craftsman Garden
Ive replaced my transmission on my walk behind lawn mower it was almost upside down for 2 days ive replaced the gas and oil but it wont start
The gas and oil weren't in the mower when it was upside down were they?
If that's not the issue, then the problem could lie in the fact that neither tank was fully drained before being put upside down. What happens is that the oil and fuel mix and will drain into the wrong area.
My best suggestion would be to leave the mower upright for a few days before trying to start it If need be, drain the oil and gas and let both tanks dry out completely before refilling.
Clean the spark plug and change the filter.
If none of these ideas work, then you will need to take your mower in to be serviced.
Aug 13, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Keep having to change the spark-plug due to heavy black sooty build-up. Think the problem is old oil, therefore would like to know how to change the oil please.
there should be a drain plug in the bottom of engine warm lawn mower up take out drain plug drain oil out check your air filter replace it even if it looks clean replace it
Jul 24, 2011 | Briggs & Stratton Garden
My mower will run for about 30 minutes then die and then have to wait for awhile and process starts all over. i have changed oil, spark plug, plug wire and coil, fuel filter, air filter and screen,...
Try this.
When the mower is about to die, loosen the gas cap.
My mower gas cap vent holes plugged up and kept stalling the mower.
If it works, drill out the vent holes.
Gary
Jun 27, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn Mower will not stay running then will not restart
I think we all understand the frustation penaone.
I noticed u didn't clean the fuel tank, water, dirt, and rust in it can give u problems. But u need to clean the lines and carb. again also. One of the kids filled my mower gas tank with driveway gravel once, and after I cleaned things out, the mower never run so good. Also your spark may be grounding out somewhere before it gets to the spark plug. Check for a bad spot in the wires from the magneto. Some of that may be behind the flywheel though.
ballping
Jul 28, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
My lawn mower srarts than dies its not out off gas or oil
There are a few popular solutions for your problem. You can try changing out the old gas completely, with new fresh gas, you can try changing the spark-plug and air-filter. You can try cleaning the carburator or replacing it if you find it is broken. And you can try removing the spark-plug wire and putting in-line, a spark tester. The ark should be blueish white Not dull orange or yellow. If the spark is insufficient then you can try removing the pull-string cover and lightly sand the magnet that is on the fly-wheel and passes by the ignition coil. Good-luck.
May 21, 2010 | Craftsman Push Rear Bag Lawn Mower w High...
How to change a spark plug on a club cadett model # 959435
Hello. Changing the spark plug requires a couple of tools, all available at any auto parts store, and the right replacement plug. Regarding the plug, look in the manual or take the old plug to the auto parts store and have the clerk cross reference for you to be sure you get the same one or a comparable. Look at the links below to learn more about changing spark plugs in lawn mowers than most people know. Have fun with it.
Here is the link to a video to show you the steps. http://www.ehow.com/video_4426873_changing-spark-plugs-lawn-mower.html
http://www.oneprojectcloser.com/how-to-change-spark-plug-in-a-lawnmower-example-briggs-stratton-engines-in-craftsman-and-murray-mowers/
Apr 16, 2010 | Poulan "" Push Mower
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
