Question about Sharp Televison & Video
I have a sharp tv. the problem is when i turn on the unit it shows a single horizontal line then immediately relays clicks then turns to stand by mode. i already change the vertical ic.
    Top Expert:
  • Sharp Master
  • 74,383 Answers
Vertical scan output failure. That is the reason for this horizontal line, right across the center of the screen. Check and replace damaged component/s at it vertical scan output section circuit. Check the solder terminals of the vertical scan output IC; for any loose solder points. Contact any service technician, if you're not handy in electronics.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to TV screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Dec 02, 2014
  • 77 Answers
SOURCE: JVC AV-27790 - single horizontal line
Since Intermitant always inspect the vert ckt for bad solder connections. If not replace the output IC they're cheap and most likely the problem If you still have lines on the top or bottom I would replace all of the electrolytic capacitors in the vert ckt also. Without much test equipment rebuilding the whole little ckt is the best way to go.
Posted on Apr 24, 2007
  • 556 Answers
SOURCE: missing vertical deflection on philips TV
TDA 8362B IC which have vertical freq.output is at pin no.43. (vert.osc) caution for fixing this problem minimise brightness to avoid crt burn. proceed as follows 1 if you are getting sawtooth at output of ic tda 8362 pin 43 then check 1 supply at vertical output ic from eht. 2 yoke connector loose . 3 check vertical output ic parts. 4 finally vertical ic. please check for normal output from power supply even though fault gets rectified just for protection. good luck.
Posted on Sep 23, 2007
  • 556 Answers
SOURCE: Sharp 27G-S60 no vertical picture
your problem is due to vertical section failure.
 as you say it was intermittent for a while, but now is permanent
please check the followings as given
  • remember you should keep brightness as low as possible to avoid crt burn.
  • there might be loose contact in print or connector loose for deflection coil.
  • check supply to vertical output section
  • check components in vertical output section like electrolytic capacitors & low value resistirs.
  • check verical outout ic .
  • hope this will help
  • good luck.
Posted on Oct 15, 2007
  • 9 Answers
SOURCE: mitsubishi cs27403c tv problem
kindly...see first the flyback and adjust the screen if the horizontal line still there adjust the fucos....
Posted on Jan 08, 2008
SOURCE: orion tv problem
tv flipping colors and verticle alignment not straight
Posted on Feb 10, 2009
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
I have a tv set problem is when i press the secondary power the pilot lit turns green but turns back to red (in stand by mode) imediately. theres a clicking sound from the relays.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 17, 2014 | Aiwa Televison & Video
I have a sony wega trinitron, when the tv is turned on, (no visual, or sound) the red stand by light blinks 7 times, and you hear the tv click off? Please help
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Jun 06, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv screen is black except for 1 horizontal line of color
The line is there because the vertical deflection unit - the one that spreads that line across the entire screen to form the image - has failed. Replacing it is a job for a professional, or at least an experienced amateur, and the parts will be quite difficult to find for such an old tv .
May 28, 2010 | Panasonic CT-36DV60 36" TV
I have a sharp tv 21" if i turn it on or change channel,pink display will appear with red horizontal lines about half inch intervals dn a few seconds it will turn normal but the red horizontal lines remain...
my sharp tv was like that to but our tv color was blue with also gray horizontal lines i did cheack all d caps resis... etc dont know what to do LoL.
Feb 07, 2010 | Sharp Televison & Video
I have a KV27FS210 sony wega trinitron tv. It turns on and has a single horizontal line across the center of the screen then buzzes shows a continuous zigzag line from the top to bottom of the screen with...
The single horizontal line is a problem with the vertical circuit. Look for a small flat id attached to a heatsink that should be marked LA7837 or something similar. Try resoldering the pins of this IC first. If that does not resolve it, replace the IC.
Keep us posted.
Dan
Feb 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Mitsubishi CS-31303 will not power on.
I have Mitsubishi TV CS-31303. It has transient issues. At turn on, it shows horizontal fringes for some time along with picture, then single horizontal line only and then after some time finges at the 1/3rd bottom and then clear full picture. After some more time the clear picture turns into horizontal fringes at the bottom 3rd of the picture and picture rolls and then again the picture is very clear. Some one said that there is an issue in the signal PCB. Where is it and what componets are at fault. I do have service manual which shows circuit diagrams.
Oct 28, 2008 | Televison & Video
Stand by light blinks 6 times, wont power on
Here you find sony blinking codes
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
Aug 10, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Panasonic CT-32G6E Intermittent single horizontal line
I would suggest to locate a part that looks like the one on this link and re solder all the pins, also check for any high power resistor nearby the IC295890 and put some fresh solder.
Let me know if you need further assistance.
Aug 07, 2008 | Panasonic CT-32G6 32" TV
Televison & Video Logo
67 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
