Question about Passport Computers & Internet
I have a WD Passport External Drive. (WD1600ME-01) I know it works but all the wires I have that fits the Drive don't seem to work. When I connect the wires, I can hear the Drive go on and shortly aft
I keep trying the wires I have, and once in a while, the Disk opens. It contains all my Music.
  • 21 Answers
You may first want to try disconnecting any other USB devices, to guarantee that the drive is the only power-drawing device. Drives typically need all 500 mA that a USB port normally provides.
Cables do wear out, especially those handled often. Mini-USB cables are pretty common and can easily be replaced.
WD Support Downloads My Passport My Passport Essential
Posted on Dec 02, 2014
Low format free software win7
There shouldn't be a need to do a low level format on a drive. Just use the built-in format in windows. If you really need one though, download the hiren boot cd and burn the iso to a disc. It has several low level format tools.
Dec 23, 2012 | Western Digital WD Passport 250GB Portable...
I have a WD1600ME-01 hard drive passport. It was working fine but suddenly my laptop is no longer recognizing it neither my PC
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Mar 28, 2012 | Western Digital WD Passport 250GB Portable...
When I connect my wd passport, this massage appears "usb not device recognized". although the cable is working with other devices and the wd passport is also working on other computers (not my...
there is NO problem on you external hard drive..the problem is in your own computer USB port..try to uninstall the driver of your usb port.then try it again.
Jun 15, 2011 | Western Digital My Passport Essential 160...
I have a WD1600ME-01 hard drive passport. It was working fine but suddenly my laptop is no longer recognizing it neither my PC. when I connect it the drive light starts to blink and I hear a continuous...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jan 02, 2011 | Western Digital WD Passport 250GB Portable...
I have a 1tbexternal hdd drive and it stopped working. i tryed to switch the plug and put it on other computer but nothing.....
The Passport has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the W.D. web-site, and use "check warranty status", to see if W.D. will replace the Passport, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
Nov 07, 2010 | Western Digital Passport 160GB External...
MY PASSPORT ESSENTIAL WD1600ME-00 is not recognized by plug-and-play in either of my HP Desktop Windows computers (One with XP, one with VISTA). Power light comes on when attached to any USB port. Device...
You run MS Windows Update to download and install the latest OS updates. Your WD external HDD should be detected after OS update.
For non updates system, try to connect WD to the USB Port where it worked before. If you have 4 USB ports for instance, try to connect it to these ports one try at a time. Windows XP might have assigned one USB port for your device before when it was working just fine.
Feb 02, 2010 | Western Digital WD Passport 250GB Portable...
Problem accessing WD Passport Elite drive
The solution to this is associated with the power supplied by your laptop to the drive. It seems the passport drive needs about 1000mA of current which will be supplied by two USB ports on a laptop. It should be fine with a desktop USB port though is what I was told.
Feb 24, 2009 | Western Digital Passport WDXML800UE...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I had a similar problem with my WD passport 320GB. When I connected it to my laptop it never showed up on My Computer even though the blue light on the hard drive came on.
Here is what I did:  Right click on "My Computer" and click on "Manage" and then "Disk Management",. you should see your WD hard drive listed. then click on "change driver letters and paths"  and change it from the listed to another drive. I changed mine from G to F drive and it worked for me.
Jul 29, 2008 | Western Digital Passport WDXML800UE...
Computers & Internet Logo
144 people viewed this question
Top Passport Computers & Internet Experts
ka4iup
ka4iup
janman
john h
Are you a Passport Computer and Internet Expert? Answer questions, earn points and help others
