Question about Dell XPS Computers & Internet
Dell error code 2000-0142
I run self test and get error code 2000-0142 validation 80576 MSG: harddrive 0- s/n s1e1jqg4 Does this mean my harddrive crashed and is there still a way to get my info off of it?
Yes, cloning is the best way to get your data from the corrupt hard drive, but if you feel its a little too much for you to understand and do them, then you could get a USB to SATA/IDE connector or a external Hard drive casing suitable for your hard drive (laptop/desktop) and connect it to any working PC on the USB ports and it will work like an external Hard drive so that you can retrieve all your important data. Hope this helps.
Posted on Dec 05, 2014
  • Sibin Simon
    Sibin Simon Dec 05, 2014
  • 21 Answers
Any error code for a hard drive isn't good, and should be reason to get a new one right away. So long as the drive is still able to be accessed, you have a chance of retrieving your data. There are free utilities to help you 'clone' the data to a new drive, but you may want to ask a tech-minded friend for help if you've never done it before. It sounds like the drive isn't dead yet, but is definitely on its way out. Good luck!
Posted on Dec 02, 2014
Cytherian
  • 109 Answers
SOURCE: Dell GX270 Maxtor 7Y250M0
If you are getting bad block reports on your hard drive, it means that your hard drive media has suffered some degradation. It could very well be that some system files are being affected by this, thus continually triggering the problem. You may not like the suggestion I have, but it looks to me like the most solid solution (saving you hours and hours of troubleshooting).
Backup all files from your hard drive, save all of your browser shortcuts to backup files, then perform another Windows XP installation with a low level format of the hard drive. I know a PC specialist with many years of experience that says hard drives develop faulty areas over time and that every 5 years or so, it's just best to back up data from the hard drive and perform a low level format. This resets the device completely. If there are any faulty areas on the disk, they are skipped over--to the operating system, the drive will be perfectly fine.
This is not a guaranteed solution, but it sounds to me like it will eliminate a lot of possible culprits for you. Good luck.
Posted on Dec 30, 2008
appman67
  • 33 Answers
SOURCE: c0000218 error code.cannot boot dell 8400 to troubleshoot problem
It sounds like you've had a fatal error - you can reboot the PC back to factory setting - this is called a hard reset - but before you do that - unplug you tower and clean it out (dust & dirt) - once you're done with that - restart you computer and press &hold down the "Ctrl" and "F11" button at the same time - this will let you reset the PC to the original factory configuration.
Posted on May 03, 2009
SOURCE: error code 0f00::065d msg:IDE failed
its simple:
1. Get Windows XP Booteble CD from a friend or simple download it
for example "WINDOWS XP PRO sp3 x86 32 BIT"
2. Burn it on CD
3. Switch on your Laptop/PC
4. Press F12
5. Put your Windows XP to your CD/DVD drive
6. Choose from a manu DVD/CD
7. Press any key to start instalation
8. wait a couple minutes and pres R for Repair
9. wait until you will se C:\
10. and finally type "chkdsk c:"
11. after all restart laptop/pc
12. Enjoy
Posted on Aug 11, 2009
  • 17 Answers
SOURCE: Error code 0F00:137B
GO TO BIOS SET UP VERIFY WHEATHER HARD DISK IS DETECTED OR NOT IF NOT CHANGE ID CABLE OR PLUG TO ANOTHER ID PORT ONCE GOT DETECTED TRY TO BOOT IF NOT BOOT IN SAFE MODE
Posted on Sep 07, 2009
  • 3940 Answers
SOURCE: Inspiron One. All in one desktop Running a System
that is a hard drive read failure, replace the hard drive
Posted on Mar 11, 2011
Dear sir , i have a dell inspiron 1464 laptop.i have a problem during window installation.in a diagnostic test there are a error generate. the error code is, Error code 0146 Msg:Error...
Dear questioner after going through couple of posts on dell support forum I found that this problem occurs if your hard drive is not functioning well
If you laptop has warranty please visit the nearest dell store
Aug 06, 2011 | Computers & Internet
Comoputer: DELl precision T5500 Workstation Problem: cannot start normally Error CODE 0142 Msg: Error Code 2000-0142 Msg: Hard Drive 0-Self-test unsuccessful Status: 72
sounds like a bad hard drive. Press f12 during the dell logo on startup and choose "diagnostics" from the boot menu, see if more failures relating to the hard drive are returned.
Feb 23, 2011 | Computers & Internet
Hi, In my dell optiplex 380 desktop showing blue dump error which describes that ecode : 051 msg : 2000-0151 msg: Hard drive-1-incorret stats:3E no addition
Most cases the harddrive is faulty if with code the PSA+ 2000-0151 code means Hard Drive (d): - Incorrect status: (x) (s) etc...Caution:Remove any and all power sources Including but not limited to: AC Adapter, Battery, or Desktop Power Cord, before you remove or reinstall an item in your computer." So Run the Drive Self Test (DST) from the Utility Partition also known as the 32 bit diagnostics to determine if the previous error has been corrected. If the DST from the Utility Partition does not indicate a failure of the drive, we consider the error to have been corrected and the drive does not need to be replaced.
Aug 11, 2010 | Dell OptiPlex 380 MT Desktop Computer...
How to fix a error code 0142 msg 2ooo-o142 msg unit:prive self test failed.stuaus for a dell labtop
Ok well I have a Dell Inspion 1525 and I have been having problems with it the last little while so I ran a diagnoses tests and I got this:
Error: 0142
Msg: Error code 2000-0142
Msg. Hard drive 1- self test unsuccessful status: 79
Just wondering what exactly it is, and how to fix the problem?
Or if I have to reformat my whole computer
  • 1 year ago
Mar 22, 2010 | Computers & Internet
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
D610 DST Short Status Test Fail
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Feb 17, 2009 | Dell Latitude D610 Notebook
No bootable device
Error Code 0141 means no drive detected.
If that's your problem then you should take out the harddrive out and try it on another laptop or buy an external enclosure.
You can get them for $10
If it won't run on another computer that means the harddrive is bad but if it does run then it means you have a serious issue within the laptop componants.
Dec 24, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 1420 freeze at starting
This is an easy one.
You hard drive has DIED.
Call or chat with Dell tech support and get a replacement drive
http://support.dell.com/support/topics/global.aspx/support/chat/hardware_chat?c=us&l=en&s=gen
Since the system is less that a year old, you can request a replacement drive witht eh factory image on it too.
Jul 14, 2008 | Dell Inspiron 1150 Notebook
DST Short Status Test (Error detected)
DST stands for Drive Self Test, it means your drive is failing.
I would get a new hard drive and USB enclosure, install new drive in laptop and install windows, then take the old drive and install it in the USB enclosure so you can connect to your laptop when windows is running and restore your files, assuming the drive is not completely dead.
thanks for rating
Jan 10, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
128 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
