Http://www.motorola.com/mdirect/manuals/t50-t55_userguide.pdf
Contact Motorola Solutions. Consumer Two way Radios Walkie Talkies
Mark
Motorola Mobility Support
SOURCE: the talkabout t5500 and the t5725
Hello bella-9,
The T5500 is a 2 channel radio and the T5725 is a 14 channel radio. However, the radios should be compatible with each other on FRS channels 1-14 as long as both radios are using the same Quiet Talk code. If the Quiet Talk settings are different the radios will not be able to communicate with one another.
Assuming all settings are the same (as you say) and the units are within range of each other (typically less then a mile over clear, level terrain) they should work just fine.
Best Regards,
Ken
"Go Ahead. Use Us."
SOURCE: MOTOROLA TALKABOUT TWO WAY RADIOS WONT TRANSMITT- BOTH CAOME ON
Here is the manual for the T5720. It may be very similar to the model you have.
http://lib.store.yahoo.net/lib/starbattery/T56XXusersguide.pdf
SOURCE: Need instructions for Motorola TalkAbout 101
http://www.scribd.com/doc/2825102/Motorola-T5100-T5200-Two-Way-Radio-User-Manual
i know it isnt the same but..it cud help atleast a lil
Thanks for using Fixya
Have a nice day!
SOURCE: i have a motorola T5725 talkabout and i want to disable the roger
Press and hold the + while you turn your radio on. Here is a link to the manual http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
