Question about Whirlpool Washing Machines
Whirlpool wfs1276aw error F06
How to fix it myself?
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
open the machine and use a dry paint brush
give the motor a good clear off of the carbon dust spent from the brushes
you should while your there take the brushes out and check there condition is ok
they should be long ie longer than 1/2"
if not replace them
as your getting issues i would replace them
and dont forget to brush off the bad carbon dust
it gets everywhere leading to motor issues
as most sensors are low voltage leakage of current accross the dust can upset low voltage stuff easy
and also leed too your homes mains tripping etc
just from dust
i find most often brushes have some life left
but treat it too a new set
as its a bit upset by the old ones anyway
perhaps they have delaminated also
Posted on Dec 02, 2014
  • 87 Answers
SOURCE: Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
Posted on Jun 08, 2007
Benimur
  • 6966 Answers
SOURCE: whirlpool front load washer GHW9100LW
Appreciate the "Ask Me".
My compliments that you have determined that error code F06 indicates drive motor tach error. This relates to the controller board not sensing that the motor is spinning. This could be attributed to three (3) possibilities:
  • motor is not really turning/stuck, a replacement is required;
  • motor is turning but the sensor attached to it is defective and therefore not sending signals to the controller board. Pls check the terminals/connectors/wirings; and/or
  • the controller board input circuitry is defective. It does not register any input from the motor's RPM sensor. This could be a diode, resistor or logic IC. This would be component level repair requiring familiarity with electronic circuitry and components, use of a DVM and a soldering iron. It wold be easier to replace the entire controller board..
In some instances, it could just be the motor's capacitor that is defective. The capacitor provides the initial kick for the motor to start running. Failure on the capacitor will not kick start hence motor will not start hence RPM sensor says to controller board motor not running.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 16, 2008
jsrock516
  • 5911 Answers
SOURCE: F06 whirlpool duet error
"F06" is a motor speed error. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
The link provided will give you the necessary steps to diagnose the problem yourself (yes, this a DIY project). All you need is a simple multimeter. I would begin by checking all the wiring to ensure you have nothing loose or broken. Then, I would recommend checking the motor windings. This would potentially rule out the first two possibilities by confirming whether or not the motor and wiring harness are good. That would leave the Motor Control Unit to troubleshoot. More commonly, the MCU fails causing this error. I'm not saying this is your problem, however. You will need to follow the steps provided to rule out all possibilities.
I hope you find this information helpful. Let me know if you require additional assistance.
PS If you do require parts. You can order on line at searspartsdirect.com. Repairclininc.com also carries parts for your washer if you would like to do some comparative shopping. There are other web sources out there, but I have found that these two have good service and are usually the lowest priced.
Posted on Nov 18, 2008
  • 1525 Answers
SOURCE: error code f06
hello fo6 means drive motor techometer error check wire harness connections between the drive good luck
shaun
Posted on Mar 22, 2009
  • 949 Answers
SOURCE: F06 error message with flashing remaining minutes
Here is what the manufacture says about F06 - my comments will follow these.
DRIVE MOTOR TACHOMETER ERROR
high-speed spin, the door will be unlocked after three
minutes.
Possible Causes / Procedure
1. Verify the shipping system including shipping bolts,
spacers and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive
motor and the Motor Control Unit (MCU), and between
the MCU and the Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive
motor.
6. Check the drive motor for powered rotations.
Phil's comments--->
If you just set the machine up be sure the shipping bolts have been removed, this is the most common reason for F06.
Other than that there is some type of communication error between the three main components (motor, Motor Control Unit and Central Control Unit) or the wire connectors between the three.
If you have had the unit a while and it is not related to the shipping bolts I would recommend calling Whirlpool
Posted on Apr 19, 2010
Error Code 01 F06
Your fault is mentioned here.
An F06 fault code in a Whirlpool Duet washer (the Kenmore HE3/4t's are also made by Whirlpool) usually means a motor-related problem. It usually pops up when the drum won't rotate at all or only very sluggishly. Here's the excerpt from the Whirlpool Duet Service Manual on this:
http://fixitnow.com/wp/2008/10/28/whirlpool-duet-washer-with-an-f06-fault-code/
May 10, 2015 | Maytag Dryers
I have a whirlpool wfs1276aw. It suddenly stopped working displaying the error F06.
pl.check the current and voltage with the meter and continuity test after unplugging the mains chord,which may give some iferrence
Dec 02, 2014 | Whirlpool Washing Machines
Whirlpool awod error f06 flashing. how do i find it.
tacho feedback error...the sensor for the drum is not picking up the speed of the drum
Mar 25, 2017 | Kenmore Washing Machines
Whirlpool duet front load washer, F06 error
FROM WHAT I CAN FIND OUT YOU HAVE A DRIVE MOTOR PROBLEM,
IF YOU TYPE IN YOUR SEARCH BOX (WHIRLPOOL FAULT CODE F06) there are several several sites that tell you how to fix it
Nov 25, 2012 | Whirlpool Duet GHW9150P Front Load Washer
The washer will start as normal then start beeping and flash F06. we had a tech look at it and he claimed the two boards weren't communicating as they should. he never fixed it and it's still doing the...
F06 is a drive motor tachometer error. this error code really needs hand on diagnostics because their are many wiring and component checks ..This is usually a drive motor concern but could also be a machine control board, or the wiring associated with both components .This could become a very expensive repair without a proper diagnosis.. Sorry I couldn't be of more help
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
minutes.
motor.
Phil's comments--->
Apr 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F06 and F14 error codes
Before you replace the control panel use a tester on the cable to check continuity .. if the cable is faulty you will get this fault
Aug 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f06
shaun
Mar 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
May 23, 2007 | Whirlpool AWM8163 Front Load Washer
Washing Machines Logo
64 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
