Question about Refrigerators
My drinking water dispenser is dispensing very little or no water on the hot tub side
    Master:
  • 755 Answers
Clogged filter ?
Posted on Dec 02, 2014
Testimonial: "It's not a refrigerator, it's a water dispensing primo machine,if it's clogged, how can it be opened?"
Ld and sd on a kenmore washing machine
Liquid dispenser and softener dispenser are clogged. Pour some hot water into both dispenser tubs and try to run thru a small load. The hot water should loosen the clog. Try again if necessary. GOOD LUCK FRIEND.
Nov 19, 2014 | Kenmore Washing Machines
Why does My Samsung VRT front loader leave the soap dispenser full of water at the end of the wash cycle. I have to empty it in order to add detergent for the next wash cycle.
there are 2 components to the soap dispenser, 1 using liquid soap has a little tub that you dispense soap into and 2nd you remove the tub when using powder soap. I assume that you are talking about the little tub is filled with water. How this works is by adding water to the tub the level rises and siphoning empties the little tub. If any water remains it is due to water being added after the little tub has already emptied. That is not a big issue and will happen. Just empty the water or add some water to start the syphon process.
Oct 11, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
I have a Neptune stack washer that leaks water out the door on the 3rd rinse cycle on the side where you put in the fabric softener. When the wash is done and I open the door the fabric softener...
Hi, thanks for using FixYa.com. I suspect the dispenser may be plugged up a bit or the hose from the dispenser is plugged. Remove the dispenser insert and clean out the tray with hot water. After that, open door and remove the 4 phillips screws, 2 on each side of the door opening. Once removed, pry the front panel away the machine and set aside. Find the rubber hose coming from the dispenser assembly to the tub ring and remove it. Clean the hose and the inlet on tub ring of softener build up, reassemble and enjoy a properly working, non leaking washer!
Sep 16, 2010 | Maytag Washing Machines
The water dispenser stopped working but the ice dispenser still works just fine on my KitchenAid Superba KSRG25QFB side by side
First Question, Have you changed the water filter???needs to be done every 6months. dirty water filter can keep water from flowing through system......also nasty to drink.........
Jan 09, 2010 | KitchenAid Superba KSRG25FK Side by Side...
The dispenser for fabric softener overflows all the time and does not go down.
Its clogged ... probably ... I have had success putting hot water down the hole ... but expect lots of spillage before it clears.
Oct 10, 2009 | GE WSXH208A Front Load Washer
In my GE Performance refrigerator side-by-side Ice is being made, but no water is dispensing. The GE Smartfilter is atleast 5 yrs old (I never used/never changed) because we always bought water from...
The water that goes to the door actually is routed through the hinge on the freezer door. Take a look and see if you can't find where the tube comes out and goes into the water dispenser. I bet it has come loose and is rerouting the water down the side of the fridge and onto the floor; hence the puddle.
Also, just because you don't drink the water doesn't mean you don't drink the water! If you use ice from the ice dispenser then you ARE drinking the water. The water that feeds the ice trays comes through the filter, so you might consider changing it every 6 months rather you use the water dispenser or not.
Hope this helps, I have one too and its causing a different set of problems...
May 11, 2009 | GE Profile Performance 25.2 cu. ft....
I have a Kenmore top loading washing machine that is 7-8 years old. (model # 110.92575110). It has a fabric softener dispenser that sits on top the agitator. It has stopped dispensing properly. Most of the...
pull the dispenser of turn it up side down now move green clip around dispenser down..take a little screw driver and remove all that wax build up...turn dispeser right side up and let hot water hot as possiable..now you should be find...if not add a little bleach with the hot water rinse out..if your getting fabric softner around tub ring ,,its to thick,,instead of dripping down its flying up...fill dispenser to top with water than add fabricsoftner ..it will even it self ,,water first...
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
The water dispencer dribbles the water out.
The water hose coil is to chill the drinking water coming out of the dispenser. If the water drips out it could be a bad solenoid valve since the water dispenser requires power to dispenser water. If the Ice maker is working fine then check the dispenser water solenoid valve.
Dec 27, 2008 | Frigidaire FRS23H5AS Side by Side...
Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Aug 08, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
