My top load water dispenser stopped dispensing on the hot tub side, what do I do?
  • 3,287 Answers
I'd follow the hot water supply hose to the back of the washer and and then - after unplugging it from the power - begin check to make sure hot water is available to the hose by disconnecting it and aiming it into the washer - and turning the water on. If it flows, check for debris clogging the strainer screen at the input to the washer. Then if ok - check the hot water valve solenoid with an ohmmeter. Compare it to the value of the cold water solenoid valve and if not within 10 - 15% - replace it. If you can check for 120 volts to the hot water solenoid SAFELY - do so - otherwise, stop and call a pro.
Posted on Dec 02, 2014
  • Marcus
    Marcus Dec 02, 2014
    This is useful info only that I'm having trouble with a drinking water dispenser and not a washing machine as it came out. Thanks though.
  • Steve Dec 02, 2014
    It would help a great deal if it wasn't under the "Question about Washing Machines" heading. Additionally, you might want to repost under a more accurte heading so that people familiar with them might be able to help you out.
  • 3 Answers
SOURCE: LG Front Loading Washer overflows at detergent dispenser
you mean where you put the regular HE soap in? That slot is normal to overflow. The water carries the soap down (Lift the little doohickie up, it's removable for powder deterg.), and it carries it all the way to the tub...Unless i don't get it...but I'm reading the phrase "Its like the water will not go down to the tub.", and it makes me think the whole tray is overfilling with water..if this is the case, I can't help you, but filling over of the Main HE Soap tray is normal. (Just a little, if the whole thing starts filling uncontrollably, hit the power button.)
Posted on Mar 14, 2007
jsrock516
  • 5911 Answers
SOURCE: Fabric softener doesn't dispense
Fabric softener dispensers are notorious for getting all gummed up and clogged. Remove the dispenser cup and soak in some hot water to dissolve all residue. While you have the dispenser removed check under the dispenser cap in the agitator for gummy residue as well. Clean with hot water. There should also be an agitator seal cap under the dispenser. Make sure the cap and rubber o-ring are seated properly. Last of all, if the dispenser has a cone shaped cup inside, make sure it is inserted cone-side UP. The cup is designed to allow fabric softener to roll down the sides of it, NOT hold it. I hope this helps.
Posted on Apr 29, 2007
SOURCE: Water in detergent dispenser
Remove dispencer again, remove conditioner syphon assembly and clean up the little tube. Should then go okay
Posted on Jul 11, 2007
SOURCE: Top Load Kenmore Elite Bleach Dispenser Leaking
I have this same problem today and did not need to take off the top panel or remove the front panel/housing. The bleach and frabric softener dispenser snaps right out and you can check the tubing and clamp from there. You will need to remove the top panel if you need to replace the tubing. In my case, there is a crack in the dispenser itself which has ruined several loads of laundry over the past year...now I realize it wasn't the clamp and hose, but the dispenser itself. Check them all while you are at it.
Posted on Dec 27, 2008
robocop
  • 90 Answers
SOURCE: Whirlpool bleach dispenser not dispensing properly
It sounds like the bleach dispenser is clogged or has a crack in it. What we do, is when we bleach our clothes and I know that this is extra work, but we wait until the washing machine is full of water, then add the bleach directly to the wash.
Posted on Jan 19, 2009
Ld and sd on a kenmore washing machine
Liquid dispenser and softener dispenser are clogged. Pour some hot water into both dispenser tubs and try to run thru a small load. The hot water should loosen the clog. Try again if necessary. GOOD LUCK FRIEND.
Nov 19, 2014 | Kenmore Washing Machines
Water is still in my liquid bleach dispenser after load is finished. is this normal?
If it is just water then it could be OK. Most companies use a water stream to flush the bleach and also the fabric softener out of the dispenser systems and into the washer tubs. Some water left over is probably normal as long as the bleach or fabric softener has dispensed.
Sep 19, 2014 | Kenmore Oasis153; Agitator 4.5 cu. ft....
Water is leaking out the soap dispenser.
Remove the soap dispenser and clean it throughly, next check the tube from dispenser to the tub to be sure it is clear of blockage. Run the washer with hot water to clear any residual buildup that may be left in it.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
LG front load washer is leaking a lot of water from the soap dispencer
Remove dispenser drawer by pulling out to it's stop, then pressing in tab at back to allow you to pull it free from machine. Look for a build up of fabric softener in the filler area. If that is clean, remove washer top by taking screws of out back side and sliding top back 2 inches and lifting it off. Remove rubber connector from dispenser area to top of tub and check for obstructions. (mouse nest?)
Oct 02, 2010 | LG WM-2277HW Front Load Washer
The softner dispenser will not empty. then has bad smell.
if this is a front load washer you need to raise the top and check all the dispenser hoses for clogged, hardened fabric softener. if you only wash in warm or cold water, the hoses will get built up with soap and fabric softener. you need to do at least one load of hot every month to keep the hoses cleaned out, the hot water disolves it better. as for the smell you can buy a product called AFRESH and follow the directions on the package and routinely use one tablet every month for the odor. if there is a lot of water in the tub, you may have something caught in the impeller of the drain pump. hope this helps.
Nov 07, 2009 | Kenmore Washing Machines
The dispenser for fabric softener overflows all the time and does not go down.
Its clogged ... probably ... I have had success putting hot water down the hole ... but expect lots of spillage before it clears.
Oct 10, 2009 | GE WSXH208A Front Load Washer
How do i clean the Whirlpool Gold american collection top loading washing machine? I can see no filter to remove and the inside of the tub is getting dirty. The holes inside the tub at the top seem to be...
Dumped even more HOT HOT HOT water while poking around inside dispenser. Softener dispenser suddenly became unclogged and water began running out of the opening showing me that the dispenser was indeed clogged with softener buildup.
Sep 20, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Kenmore top loading washing machine that is 7-8 years old. (model # 110.92575110). It has a fabric softener dispenser that sits on top the agitator. It has stopped dispensing properly. Most of the...
pull the dispenser of turn it up side down now move green clip around dispenser down..take a little screw driver and remove all that wax build up...turn dispeser right side up and let hot water hot as possiable..now you should be find...if not add a little bleach with the hot water rinse out..if your getting fabric softner around tub ring ,,its to thick,,instead of dripping down its flying up...fill dispenser to top with water than add fabricsoftner ..it will even it self ,,water first...
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
There is a water leak coming from the front of the washer...its leaking from where the water dispenses during a wash cycle. What could have caused this?
are you sure it's dispenser and not pump if your sure it's the dispenser try cleaning it out ..if's it has a bleach dispenser on right side pull the outer cover off and clean the holes underneath it i assume it's a top load ..if it's a front load remove dispenser completely clean it and inside of housing also ck the line into the tub just above door opening than can become plugged especially with dry detergent
Aug 23, 2008 | Whirlpool Washing Machines
Apr 09, 2007 | Kenmore 24982 Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
