Is the Suspension Kit still available if so from where?
The tub is jumping all over the place so suspension needs renewing.
    Master:
  • 755 Answers
Not nessassarly one of the rods that hold the tub up could have came off , easy fix, look real good , I think there are only 3 of them
Posted on Dec 02, 2014
2004 Lincoln navigator air suspension all the way down front and back if I was to jump the relay to turn compressor on should the truck start raising up unless compressor not pumping or a leak
no it wont. the air suspension works as a complete system. each air spring has an electric solenoid, each corner has an electric height sensor and then the compressor itself. just energizing the compressor will not open the solenoids or sensors both of which are needed to raise the vehicle. what is probably happening is a failure in the computing system for the suspension system. expensive to repair.
Jan 18, 2017 | 2004 Lincoln Navigator
The tub hits the wall of washer during spin cycle an a suspension rod will come off at the top, it has four suspension rods.
There are plastic cups that the rods set in are they all in place and you have little springs that come from the rod to the tub top. The rods could also be bent causing the tub to hit the wall.Hope this helps!
Jul 27, 2015 | Washing Machines
My WTW7600XWO washer stops with 11 minutes left to go and UL comes on
The UL code means that the load is unbalanced. With the Cabrio washers, frequently this is due to the failure of the suspension rods that hold the tub. To check this, use a putty knife to separate the clips that hold the top of the washer at the front of the unit. Then lift up the top. Check the suspension rods and balls. Also check the wiring at the motor and the control panel, just to rule out any electrical cause for the UL error. You probably only need to replace the suspension spring kit, W10247710, is available from several sources, including: http://www.appliancepartspros.com/whirlpool-suspension-spring-kit-w10247710-ap4411122.html . There are videos showing the the replacement procedure available online.
I hope this helps.
Jul 09, 2015 | Washing Machines
Front air suspension not working
Or for under $400 you can buy a coil spring conversion kit from a company like
Arnott. Look for coil spring conversion kit exclusively designed for the Lincoln Mark VIII. The kit converts the entire vehicle to a reliable coil spring/strut suspension system. Also look for a kit the required no special tools and comes with detailed installation instructions.
http://www.arnottindustries.com/part_LINCOLN_yid2_pid7.html
Aug 26, 2012 | 1998 Lincoln Mark VIII
Wtw6600sw2 unlevel load with every wash. what could be broken?
Whirlpool has a suspension rod kit available for your washer that does wonders for the out of balance load problem. I have installed many of the kits and it makes a big difference. If you order one of the suspension rods it automatically subs to the new style rod kit with all 4 rods and the other components to fix your problem. Also with your washer empty open the lid and reach inside the washer, use both hands to lift up on the basket where the clothes go. It should slide up and down a couple of inches and be able to slide very easily. If it does not slide up and down your tub and basket will have to be replaced. If it can't move freely up and down it cannot balance itself. Hope that helps.
Aug 29, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
How do I locate the water pump on a Roper top loading washing machine?
Check the four suspension rods suspending the outer tub to the top of the cabinet and the counterweight at the bottom front of the tub. Make sure the four suspension rod assemblies are intact and no sign of damage and the counterweight is in place.
Sep 26, 2010 | Roper RAX4233PQ Top Load Washer
I have a 1995 Town Car Signature Series. The rear
Sadly, there is no way to turn the light off. I had the air suspension on my Lincoln replaced with the spring kit, and the light is still on. I had a friend take the instrument panel apart and place a small piece of electrical tape over the "check suspension" light. Also, be certain to turn the air suspension pump switch off. It is located in the trunk on the right side.
May 29, 2010 | 1995 Lincoln Town Car
After putting on a shock suspension conversion kit.... what do i have to disable on my 1998 Navigator as far as fuses and sensors?
The manufacturer of the suspension kit will have allowed for this when they designed the kit to fit your vehicle, refer to the kit information or the manufactures customer service and this type of information is available from reputable suppliers.
Cheers, Timo.
Apr 29, 2010 | 1998 Lincoln Navigator
My front load machine is out of balance. What do i need to fix this problem
May be the suspension springs are weak or broken, the tub will move excessively and the machine will be off balance and shake.
Also, make sure the suspension pads or suspension arms are properly in place.
Hope this helps.
Aug 14, 2009 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
