Question about Pioneer AVIC-D2 DVD Nav/6.5" Screen/AM/FM/CD Player Car Video Player
I changed the language for my gps and now it wont work
I changed the language to spanish and now all it says is insert disc
A disk in a series of exercise discs plays only in Spanish. My young daughter had the remote and, in a few quick buttons, made the language and writing change to Spanish only and I cannot, no matter what I...
The problem is not the disc itself but your DVD player. If other discs still play in English, and it is just this one disc that plays in Spanish, then your player is using some sort of stored setting to recognize your preference for spanish on that particular disc.
Forgive me if you've already done this, but try turning unplugging the DVD player for a period of ten seconds or so, and then plug it back in. If there is a reset button, press it. See if the disc still plays in Spanish after that.
If so, you may need to navigate the DVD menu of the offending CD to turn off the language setting your daughter selected. If you don't speak Spanish, try navigating to the language settings on one of the other discs with the English menus. Memorize how you got there, and take the same path through the Spanish language menu. Return the language setting to English, and exit.
Hope this helps.
Jun 09, 2011 | Koss KS4110 DVD Player
Change Spanish to english
Use spanish equivalent of 'Tools > Setting > Language > Text language' menu item - 'Herramientas > Configuraciones > Idioma > Texto'.
Jun 23, 2010 | Garmin nuvi 750 GPS Receiver
Rosetta stone problem installing language discs
I just had the same problem. Rosetta Stone TOTALe French Level 1. I just ran it in Windows XP Service Pack 2 and it installed right away.
Apr 07, 2010 | Rosetta Stone Spanish (Latin American) -...
I just received my garmen. The language is
go to the flag sign, click it and select english
Mar 05, 2010 | Garmin nuvi 255W GPS Receiver
I input the wrong language(Spanish) instead of (English), when setting up my TomTom GPS. How do I Change the Format to English?
press the top part of the screen, now click the icon next to the arrow on the bottom line which is change preferences, then click the blue arrow three times and then click on the icon next to the arrow on the bottom line which is change languages, sorted.
Jan 01, 2010 | Tomtom ONE GPS Receiver
How do i change the language to spanish on my magellan roadmate 1200?
Maggie
Now, based on what you told me I understand that:
· You want feature information.
· You want to know how to change the system language
Maggie
RoadMate 1210, 1220, 1340, 1440, 1470
  1. From the main menu screen select the Settings icon (has a wrench and a screwdriver in an X formation)
  2. Select the option labeled "Sistema"(Spanish)/"Systeme"(French)
  3. Select the optino labeled "Lenguajes"Spanish)/"Langues"(French)
  4. Select your preferred language setting
  5. Confirm your selection by selecting the Back Arrow on the bottom left hand corner of the screen
  6. Unit will restart to make the language change
Jul 13, 2009 | Magellan Roadmate 1200 Car GPS Receiver
I want to change language from spanish to english on garmin 265
use settings language and scroll left or riht until ENGLISH appears in the box
izquierda is left right dirreccio
acceptar is the one to accept
Jun 19, 2009 | Garmin nuvi 205W GPS Receiver
Want to change language from Spanish to English
Just kept fiddling around, finally found it was easy to do. I just was not patient enough. Thanks
Jun 04, 2009 | Garmin nuvi 255W GPS Receiver
I need to change from Spanish to English on my new Garmin 260W
That's funny. Guess you need to brush up on your Spanish!
Here's how to fix assuming you have a 260 or 260w:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This may be a result of a previous software version on a device or possibly some one changing the settings. If a device does power on with a foreign language that you can not understand it can be corrected by going through the settings to change the text language.
To change the text language:
  1. Touch Wrench icon on the screen with the Magnifying Glass and Map icon
  2. Touch the Gears icon
  3. Touch the down arrow
  4. Touch the second option from the top1
  5. Touch the middle blue box on right
  6. Touch the up arrow until American English appears2
  7. Touch American English
  8. Touch OK
  9. Touch Back
The device should be in selected text language.
Note 1 - In some cases, if there are Custom POIs loaded to the device then it may be the first option at the top.
Note 2 - If American English is not the language needed, please selected the desired language
Mar 01, 2009 | Garmin nuvi 260W GPS Receiver
Cannor CHANGE language from Spanish to English.
You didn't say what manufacturer your device is, but usually if you co to their web site youcan down load the language. I had the same problem on a iQue3600 and just did a hot sync with the language I wanted. Worked fine.
Nov 28, 2008 | GPS
Pioneer AVIC-D2 DVD Nav/6.5" Screen/AM/FM/CD Player Car Video Player Logo
60 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
