Question about Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
I have a Sony KDL-52S5100 tv. Is there any way to have it turn on using a timer? Internal or external.
I do not want to have to use the remote to turn on.
    Top Expert:
  • Sony Master
  • 74,251 Answers
Off timer function is there with this TV menu. Refer its user manual for details. No external timer should be used. Electro help
Posted on Dec 02, 2014
Bravia TV has pink screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 01, 2015 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
Atv will turn on but stays on one channel and menu button and channel button will not work, and there no picture.
Most TV's require to be set on channel 3 with the TV remote again I say with the TV remote then if you get a screen run the channel lookup command from the TV remote, that should do it for you. In addition make sure the TV is set to the correct AV input with the converter box remote, your ISP can help with that part
Good Luck Ed Pinero
Feb 05, 2013 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
Need a base for a display model i bought at wal-mart
If you are looking for base stand fo Sony KDL-52S5100 then I might help you to provide you part number info to buy it.
All I need is exact model number of your tv that would be written at rear to provide you correct part number of required base stand.
Thanks.
Aug 09, 2010 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
Volume on tv is locked volume wont go up or down and not even able to put on mute
Go to Menu from remote.
Select "Audio" and confirm "Internal" speakers vs. "External". Internal is the built in speaker sna external is when you are using a surround sound or reciever for audio.
Check this and follow up.
Jun 29, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
KDL-52S5100 Picture settings always revert back to "vivid" mode after 5 mins or so.
More than likely the TV is in the "retail" mode which intentionally reverts to the "vivid" mode after a short period of time on the other settings, deemed best for retailer display puposes.
Follow the "return to factory settings" instructions found in the operators manual, pg 21 of KDL52S5100. Only the first half of the instructions are needed to put the TV in "home" mode, the 2nd slection to make after "language. After you have slected "home" I do not beleiev you need to any go further into the setup menu.
"Turn the TV on. Press and hold the "^" (up arrow) button on the remote and then push the "Power" button on the TV. Release the "up" arrow."
You should now be back to start, select langauge and home mode and then exit.
You now should be good to go and your picture mode selections should now stay put.
Sony has live tech help "chat" and I would suggest using them if this doesn't get it done - but I'm 99.95% sure this is your fix.
Jan 05, 2010 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
My Sony KDL 52S5100 52 inch is great except for
Check the  user manual.  You have the Auto dark enabled.
Or so it sounds. Disable that.
Selvol
Dec 06, 2009 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
My remote for bose 321 does not work while having sony bravia 52 in same room. I purchased a brand new remote but still same thing.
this may sound strange , but htis is a service not on the sony site place a piece of scotch tape over the sensor on your TV and this should do the trick
Carxy i saod the same thing but it works
Dec 04, 2009 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
I cant watch tv after setting my bravia tv to hdmi and watching blu ray thru the PS3
change the input to your cable box or coaxial input. check your remote to see if there is an input or source button, and press it. you might have to press it a few times to cycle through all of your inputs.
good luck
Nov 16, 2009 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
I have a sony kdl-52S5100,and every so often when i switch channels i get only half a screen,{on the left side of tv}i can channel up and down abd it stays that way untill i push the input button on my...
I work for comcast have seen 2 kdl 5100 with same issue changed to component cables issue resolved
hdmi input is the problem. Yes I did try 3 different hd boxes same issue problem is with tv .
You are obviosly the third customer with this problem
May 17, 2009 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
Sony BRAVIA KDL-52S5100 52 in. LCD HDTV Logo
54 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
