Question about Palm Tungsten Computers & Internet
Operate my old palm pilot? :)
Fading memory
  • 3 Answers
Just put palm pilot instructions into google, preferably with your pilots model number and it'll take you to the Palm Piolt site where you can download a pdf of the relevant manual. Its easier to do it this way than me explain, besides you can then work through it at your own speed. Hope this helps. Happy Christmas
Posted on Dec 15, 2014
Lost the password for an old Palm pilot. Is there a way to unlock it?
Likely the only way to access would be a hard reset which would wipe out the address book you are hoping to recover.
May 29, 2015 | Palm Pilot Tungsten T5 PDA
Wont work with a windows vista laptop??
you need to install the software that is the interface to the hardware. also depending on how old the hardware is it might not be compatible with vista
Apr 25, 2009 | HP iPAQ rx4240 Pocket PC
M515 Palm Pilot
here is your manual in PDF form
www.palm.com/us/support/handbooks/m500series_ug.pdf
if the unit was new then you would charge it for about 10 hours .. but since its not likely new then it doesnt hurt anything to just leave it on charge ... you can even operate the palm while its charging .. over night charge should be enough to get pretty close to full ... the palm internally automatically turns off the charge when the battery is full .. so you dont have to worry about over charging .. if the unit wont come on then you can do a "reset" (back at top)
Apr 01, 2009 | Palm m515 Handheld
I bought a refurbished Tungsten E. Because there was some incompatibility with the software version of my other Tungsten (which is on its last leg), I downloaded new software off the internet. In the...
Are you syncing the new device to the same username in Palm Desktop as an older device?
If you are, this will cause problems on the new device. When you sync the device, it saves the device settings, 3rd party apps, preferences, etc. in the backup folder in the username folder on the PC. When
you sync the new device it copies the contents of the backup folder for the old device to the new device. This will cause corruption in the settings for the new device thus causing erratic behavior of the new device.
Looks like you may need to hard reset your device and rename your backup folder
Go to http://www.palm.com/cgi-bin/cso_kbURL.cgi?ID=887 and follow the directions to do a hard reset. Next before you hotsync your data back over you will need to rename your backup folder, to do that go here;
XP
C:\program files\palm or palm one\[hotsync username]\ and rename your backup
folder to backup.old
Vista
Start-->documents\Palm OS Desktop\[hotsync username]\ and rename your backup
Then hotsync to your current hotsync name and all your contacts, calendar,
tasks, and memos will come back over.
Show file extensions for XP or Vista
XP
If you can not view file extensions on your PC I would like you to open a
folder go to Tools-->Folder Options--> View (tab) and under show hidden
files and folders uncheck hide file extensions for known file types.
Vista
Open control Panel go to Folder Options--> View (tab) and under show hidden
Mar 28, 2009 | Palm Computers & Internet
I need software to be able to use my Palm Pilot
www.handango.com and www.freewarepalm.com. are some sites that you can get the software with that date1997 itll be very hard to pick out the right software.
goodluck
Jan 23, 2009 | Computers & Internet
Sync Palm Pilot Contacts to Blackberry Pearl
generate a file from the palm pilot program. I think there is a application within palm pilot specifically for that purpose. Once you have generated the file move it to your blackberry manager program and sync the phone
Dec 24, 2008 | RIM BlackBerry Pearl Smartphone
Region unlock code.
hopefully this will help
Converting the player to Multi-Region:
Requires the use of a Palm Pilot w/Palm OS 3.0 or later and the OmniRemote Pro from http://www.pacificneotek.com/
(Other PDAs using Palm OS and compatible with the OmniRemote Pro from http://www.pacificneotek.com/ can also be used).
1. Program the Palm Pilot/OmniRemote. For instructions on programming the Palm Pilot/OmniRemote click How to Program the Palm Pilot.
2. Power on the DVD player without any DVD in the tray.
3. Keep the programmed Palm Pilot close to the IR port of the DVD player.
4. Start the OmniRemote program.
5. Place OmniRemote in TV mode and tap the "0" button on the OmniRemote.
6. The DVD player will power off.
7. Power the DVD player on again. Check the Region-free status by playing a DVD.
Dec 18, 2008 | Pioneer Televison & Video
Can't open palm pilot IIIxe on computer (Vista)
VIsta does not support your early generation Palm Pilot.
It barely supports the current TX but there are workarounds.
Hope you kept your old computer for a backup. :+) but its understandable if you didn't.
They recently released a more stable version but plenty of users still have difficulty. The workaround is to load files for any third party product (docs, videos, images) via the SD memory card.Users reported they could update via bluetooth or wi-fi for the Palm's own software. However, this is not an option for your model.
Later models with an SD card option still have to be initialized and prepared for the Palm from an older XP computer first. It's a workaround, not a match. I'm not up to date so users may have a stable sync system/method now with Vista. Check the forums.
Your model does not have an SD option this as it is an early generation model. You may continue to run this older model on older computers.
I am not recommending you buy a new personal device until you research on Brighthand and other user forums. Take advantage of other peoples experiences re: Vista. It will save you a lot of grief and help you decide when and whether to upgrade.
from Wicki and product info:
The first two generations of PDAs from Palm were referred to as "PalmPilots" which upgraded to external memory slots and firmware-upgradeable flash memory after the Palm III series.
The next versions of Palm used Palm OS 3.1. These included Palm IIIx with 4 Megabytes of memory. Compare this to the TX which has 128 MB of non-volatile storage and current OS of 5.4.
The TX released in October of 2005, as part of Palm's Fall 2005 product cycle. It features 802.11b, Wi-Fi and Bluetooth wireless connectivity. It was priced at $299. It runs Garnet, version 5.4.9. It largely replaced the earlier, costlier T5. <In my experience, It usually runs as low as $200 during Black Friday (Thanksgiving time). With discounts and indirect rebates, it can go as low as $150. FYI, With the move to Smartphones, this model will not have continued development from the company. >
On top is a slot for SD expansion cards. The slot is also SDIO and MMC compatible. 2 GB cards are usable directly.
<in my research, Only SD, not SD HC (high capacity) cards are compatible. 4GB SD only cards are difficult to find now that SDHC are the norm. It's not a issue for me since those also use more power. 2GBs can be had as low as $6 with creative dealing.>
Jul 18, 2008 | RIM BlackBerry Pearl 8100
Unlock codes for Pioneer DVD player
Pioneer DV-667A
Dec 13, 2007 | Televison & Video
Computers & Internet Logo
95 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Raj Patel
Andrew Taylor
Andrew Taylor
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
