<!-- from fixya rte -->How do i remove the red sensor light? - Televison & Video
Remove the back TV Panel & keep
removing items until you get access to it
Posted on Dec 02, 2014
Paper jam indicator light is on but I can't see a jam, how can I reset, I have tried turning off and on, and pressing red and green on start up but it does not cure the problem
Hi Terry
Use a Flashlight and check carefully.
There is probably a simple Infra Red Light source shining across a gap and being blocked from the sensor.
The wires on the back of the Light source & IR Sensor are the giveaway.
It thinks it's blocked!.... They can't really think, just a switch!
Could be a switch also but a IR Detector is more likely.
Remove the toner cartridge and use a source of high pressure air to blow out.
Obviously the sensor could be broken... Usually Not the case!
Mar 06, 2015 | HP LaserJet P2015dn Printer
Red and green light turn after first run
Its common problem in T Series Plotters:
Cause of malfunction: These plotters having separate sheet path as well as roll path for print media. After initializing plotter its verify the available media(sheet or roll). If sheet path is occupied by the media it wont allow the roll media, means first priority is for sheet.If sheet path paper sensor dusty or malfunction, printer will say "remove paper from sheet path" even no paper in sheet path..
How to shoot this problem:
You need to clean sheet path sensor located at sheet loading area.(black 'U' shaped part) Applying the pressured air at sensor is the best method to clean.. If problem remain you need to remove the sensor & clean or replace it.
Follow the snaps:
Need to open roll feed right side portion
dadb8b23-32b2-4d8a-952b-038117715d5b.jpg f7392b92-295a-4144-8387-b83355c6889e.jpg 6f066468-8698-4d24-94d4-af1703c40407.jpg 6ed46665-db38-4ccc-8522-c52ae9c50dbf.jpg 37e6b4f2-cc2e-438b-849e-9911bd553c7e.jpg
Clean the IR sensor...
Fix it back..
Note: Technical knowledge required to understand the remedy..
Jan 26, 2014 | HEWLETT-PACKARD CP1025 Laser Printer
We have a motion sensored light with two lights and the motion box. 1 black wire and one white per light but the middle has 1 black, 1 white and 1 red. We are hooking it to the porch light and dont know...
You are replacing porch light with light fixture with motion sensor device.
Each light has 1 black and 1 white wire.
The motion sensor has 1 black 1 red 1 white:
Copy following link for motions sensor wiring illustration:
http://waterheatertimer.org/How-to-wire-switches.html#motion
Oct 17, 2012 | Hardware & Accessories
How do i remove the sensor for the rear tailgate?
1) Locate and remove sensor.
The sensor is located under the drivers tail light. Unclip it from the body and then unplug it.
2) Bypass the tail light circuit.
Connect the tail light signal wire (Green) to the tail light wire (Green w/ Red Stripe). I recommend using wire tap in squeeze connectors that way you dont have to cut any wires.
3) Bypass the brake light circuit.
Connect the brakelight signal wire (Green w/ White Stripe) to the brake light wire (Red w/ Blue stripe) and the the 3rd brake light wire (Red w/ White Stripe). Again all three of these wires are to be connected together.
4) Throw away your broken Tail Lamp Failure Sensor
Do not plug your sensor back in. Doing so will cause the annoying orange lamp failure warning light on your dash to stay on. Leave it unplugged ant the light will stay off.
5) Test your work
Turn on your lights and make sure your tail lights work properly. Have a friend step on the brake pedal, and make sure your brake lights work properly as well. Dont forget to check the Third brake light.
Sep 20, 2012 | 2002 Chrysler Voyager
Ice maker stopped making ice. Red light is flashing. Temperature is below freezing. We've already replaced icemaker and the refrigerator is not even 6 years old.
Ok open your freezer door and observe the flashing red light now push the flapper inwards keeping your finger and hand out of the way of the infa-red sensors you should observe the light it should not flash but glow steady if it does not a fairly simple attempt would be remove the 3 screws on that assembly pulling it away from its location and unplug the harness, now go to the other side and remove those screws and unplug the harness reassemble both sensors and screw back into place push the flapper back in is the red light steady? No then you will need a infa-reds sensor kit I believe they are now well over 100.00. I do hope clearing the pcb on the sensor by unplugging the harness works but if not you now know how to replace the infa-red sensor.........And if the light is working steady and no ice is in the imkr then fill with water and off you go....
May 14, 2011 | KitchenAid Superba Architect KSCS25INSS...
My Brother HL 2170W printer has red error light on. It was printing something over and over and I wanted to stop it so I pulled (oh, no!) the paper out and then I guess the red error light went on. I...
There is probably still part of the sheet in the fuser at the back of the machine. The fuser will need to be removed and checked for scraps of paper and/or damage to the temperature sensor and v likely a dislodged paper sensor arm.
Oct 15, 2009 | Brother HL-2170W Laser Printer
Red light on odometer comes on.... And f1 light also
That is the Suzuki equivalent to a "Check engine light"
Turn your key on and verify the FI light is on and that your red kill switch is set to 'Run'
Remove your seat and behind the battery area you should find a white 6 pin connector (likely with a black rubber boot on it) Using a paperclip connect the white/red striped wire to the black/white striped wire.
Your display should Now read whatever codes are active.
If it reads C00- then there are no active codes. Note that when you turn the key off, the memory is erased so if you have an intermittent fault you should not turn the key off until you pull the codes.
Codes are as follows:
C11 - CAMSHAFT POSITION SENSOR
C12 - CRANKSHAFT POSITION SENSOR
C13 - INTAKE AIR PRESSURE SENSOR
C14 - THROTTLE POSITION SENSOR
C15 - ENGINE COOLANT TEMPERATURE SENSOR
C21 - INTAKE AIR TEMPERATURE SENSOR
C22 - ATMOSPHERIC PRESSURE SENSOR
C23 - TIPOVER SENSOR
C24 - IGNITION SIGNAL #1
C25 - IGNITION SIGNAL #2
C26 - IGNITION SIGNAL #3
C27 - IGNITION SIGNAL #4
C28 - SECONDARY THROTTLE VALVE ACTUATOR
C29 - SECONDARY THROTTLE POSITION SENSOR
C30 - SECONDARY THROTTLE CONTROL UNIT
C31 - GEAR POSITION SENSOR
C32 - INJECTOR SIGNAL #1
C33 - INJECTOR SIGNAL #2
C34 - INJECTOR SIGNAL #3
C35 - INJECTOR SIGNAL #4
C36 - SECONDARY INJECTOR SIGNAL #1
C37 - SECONDARY INJECTOR SIGNAL #2
C38 - SECONDARY INJECTOR SIGNAL #3
C39 - SECONDARY INJECTOR SIGNAL #4
C41 - FUEL PUMP CONTROL SYSTEM
C42 - IGNITION SWITCH SIGNAL
C46 - EXHAUST CONTROL VALVE ACTUATOR
C49 - PAIR CONTROL SOLENOID VALVE
C60 COOLING FAN CONTROL SYSTEM
Sep 09, 2009 | 2007 Suzuki GSX-R 1000
Where are the cam sensor and crank sensors located on my car?
Crank Sensor: Passenger side of transmission just to right and above the differential cover. Has 3 wires:
Light Blue/Dark Blue stripe - Signal
Dark Red - 8v supply
Black/Light Blue stripe - Ground
If the car runs or cranks, you can test this sensor by first checking for power on RED wire with key ON. Should be 8-9.5 volts DC. Furthermore, connect a dwell meter to the signal wire by probing the back of the connector. Dwell reading should be 49-51%. If not, its likely bad.
If you remove the sensor, you MUST replace the paper spacer on the end of the sensor or you risk damaging the sensor or even the torque converter drive plate otherwise. Also make sure O-ring is in good shape and positioned properly.
Cam Sensor:
Facing Engine, it is on the driver side timing case housing, on top of the round part, just to the right of the fuel rail pipe where there is a capped fuel valve.
Has 3 wires:
Tan/Yellow stripe - Signal
Testing is same as for Crank Sensor.
May 14, 2009 | 1994 Dodge Intrepid
BLINKING LIGHTS ON fURNACE
had same problem, first you need to find the location of ignitor double black wires from plug on board and flame sensor.single red wire. 4 red flashes means ground fault, I removed ignitor, cleaned with some scothchbrite, cleaned around screw holes(2) to reestablish ground, I even ran a wire from one of the mounting screws to a ground elsewhere. then I went on to the flame sensor witch will give you flashing yellow light. single red wire to sensor that has one screw holding in. Remove sensor carefully and do the same as the ignitor, clean with scothbrite. I did this a year ago and is still going!
Jan 21, 2008 | Dishwashers
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
