Question about Music
How do I turn and off the beat indicator light on my TD8 - KV drum kit.
Just check in the manual, no luck
    Sergeant:
  • 272 Answers
Doesn't it turn on and off by itself?
like:
on.off.....on.off.....on.off.....on.off?
Beyond that, there's always black electrician's tape.
Posted on Dec 02, 2014
2 Suggested Answers
guitarmanjoe
  • 336 Answers
SOURCE: Roland TD8 has no power
I would try another ac adapter. Plug in that one and stick it on your tounge and see if it bites. It should only be 9-12 volts, just to see if it works. It may have a fuse inside but I doubt it, if you have to replace the adapter, there is a diagram on the back below the plug showing polarity and specs. Voltage must be the same and mA must be as specified or higher. NOT lower except for checking for lights or signs of power. Normal usage would need its requirements or higher. Make sure the + and - are correct to avoid damage.
Posted on Feb 21, 2013
Feb 20, 2013 | Music
Drum kit won't power up
Get a voltmeter and check the power to see if it is working at the plug. the voltage should be 12vdc. If you don't have a meter, just take the power adaptor to radio shack, or any electronics supply house.
They'll check it for you. below is a copy of the manual. Good Luck!
Download Yamaha DTXPLORER User manual
Sep 01, 2011 | Yamaha DTXplorer 5 Electronic Drum Set
Alesis DM6 electronic drum kit module sound problems: The mix in, display and sensors are working on the module but no drum sound is produced through the monitor or through headphones (but an ipod can be...
It appears that you have to select a "Kit" of drums when using the external triggers. It appears that the volume level for the kit and that for each voice MAY all have to be set, especially after new firmware download. Read manual about KIT volume level and selecting voice and volume level for those. Manual is NOT very clear about these things and you have to try them as this is where the probllem is.
May 08, 2011 | Alesis DM6 Electronic Drum Set
I have the Simmons SD9K electronic drum kit. I really love it, but I have two seperate issues. First, I sometimes get a snare pop out of the blue while playing a beat and sometimes just after I stop...
With the sensitivity set very high, you might be getting false triggers from static discharges. It sounds like your snare trigger is either bad or possibly the cable from it may have a problem as you should NOT have to set the sensitivity so high.
It will take an oscilloscope to test the pad unless you can find a system to do a sensitivity comparision. The second problem regarding the recording/overdubs I cannot help you solve.
Mar 27, 2011 | Simmons SD9K Electronic Drum Set
I have a electone FC 20 all indicator lights are working and the ensemble section is working drum beat is ok its just the piano keys are not working could it be a fuse blown
Not likely iit is a fuse. The keys are likely scanned as a matrix with two contacts per key. You need to get a maintenance manual for thee organ. Contact Yamaha America parts for music products. They may have the service manual on CD... they used to get $15 for the CD of the manual. Unless you can find something simple like a cable knocked off this could be hard to troubleshoot.
Feb 24, 2011 | Yamaha Music
Hooking up two roland brain modules.
No need to connect via MIDI. Just connect the pads to whichever and run audio out of each into seperate mixer input.
Unless you were going to use built in rhythms there is no real need to synchronize the units.
Apr 25, 2010 | Music
Hooking up Electronic drum kit to mider
sorry ...you haven't enough channels to mix all the kit ... you will have to run a stereo pair from the td8 to mg82 and mix it from the td8
Feb 01, 2009 | Yamaha Mg82cx Stereo Mixer
Guide on RC-50 won't turn off
First, you need to select one of the patches called "init patch", it won't have a drumbeat on it. Then, turn the guide on again, then all the way off. Even if the knob's in the off position when you go to the patch, it'll turn itself on again by default. There's a light there that says "beat quantize" that you want to be off, or it'll cut your loop to the length of whatever beat it's set to. If you want to change the default, turn the beat quantize off, then press "write" and write the new patch. Hope that helps.
Dec 01, 2008 | Boss Rc 50
Music Logo
27 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
