Question about ASUS Tablets & eReaders
My Asus memo pad hd 7 says my battery is overheating while I'm using it and the charger is not connected. What's going on here?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
Sounds like a hardware issue. I'd get a replacement.
Posted on Dec 02, 2014
  • Daniel Cardenas
    Daniel Cardenas Dec 02, 2014
    also check and see if there's a update for the device.
4 Suggested Answers
chadmanquake
  • 193 Answers
SOURCE: my asus memo pad loads for hrs without coming on
http://support.asus.com/download.aspx?SLanguage=en&m=USB%20Charger&os=30
this might help
Posted on Oct 21, 2013
  • 183 Answers
SOURCE: I have an Asus Memo Pad HD 7 which I purchased 3
the more programs you install and run in the back ground the more the battery is drained. It comes to a point where there are so many programs running the gadget cannot run & charge at the same time. It might charge better if you uninstall a lot of programs or do a factory reset but that is drastic
Posted on Oct 30, 2013
Testimonial: "I did do a factory reset but the icon is still not showing and it still is slow at recharging. I didn't really have many programs anyway, a few simple card games, crossword puzzles and some weather apps. Right now, I think I have maybe 4 simple apps on the tablet and it is still not charging when on. I checked the battery status in settings and it says "not charging". However, if I turn it off and then plug it in, a red battery indicator shows it as charging."
  • 71 Answers
SOURCE: My new Asus memo hd 7 will not turn on whatsoever.
Remove the rear cover...use your fingernails, or something thin and plastic (like a guitar pick) to get it started, then work your way around unsnapping it until it is off. Now unplug the battery, the battery connector pulls up towards you to unplug, it snaps in. Now, you have to put the rear cover back on..because as you will notice there is foil on it, and pins on the board that ground through that foil. After the cover is back on...press and hold the power button for 30 seconds or so to completely discharge the energy from the board. pop the back cover off, plug the battery back in, put the cover back on...and plug the tablet in. Now when you push the power button you should see a battery charging icon...let the tablet charge for an hour or so...then boot it up if you would like, but let it charge to 100% before unplugging. Good luck!!
Posted on Feb 15, 2014
Why does the battery in my Asus memo pad hd 7 overheat?
You should be very careful charging any battery that heats up to the point that seems like it is overheating. Newer batteries are lithium ion or polymer and can cause fires when they get too hot although the polymer is supposed to be less susceptible. You should get a new battery if you're sure you're using the correct charger made for your device.
Dec 01, 2014 | ASUS Tablets & eReaders
Asus MeMO Pad HD 7 won't turn on or charge.
Ah ASUS. I have a Memo 10. Had the same problem when it was 6 days new. Asus has a UI that is bad.
1. First try to charge via USB to your computer. If you get any result good, leave it a bit.
2. Leave it plugged in and see if it will turn on. If you can get it to turn on ... do this.
3. Find the back up and restore/factory reset. Back up your data, pics, music. etc.
4. Do a factory reset... it will say everything of yours will be delted. Proceed.
5. Restart the tablet.
6. Go into settings and TURN OFF Asus's UI. On my Memo 10, under settings is a menu called "Asus Customized settings" in the sub-menu turn OFF "Use ASUS Quick Setting" yours may say something a bit different.
7. Restart. The look will be different but no worries. On the upper right see if your tablet it charging. It will be a battery with green and black and a lightening bolt in it. If it is charging try your wall wart charger.
Jul 20, 2014 | ASUS MeMO Pad HD 7
Asus Memo Pad HD 7 won't turn on or charge.
1. how old is your tablet 2. have you tried another charger such as a phone charger. My blackberry charger works fine for my tablet. Also with your tablet you should have had a usb cable that connected from mini usb to the asus plug in transformer.
What do you do when memo will not come on?
I called Asus. Told to connect charger & hold volume up & power for 40 seconds. Nothing happened, then press power & volume down. Nothing happened. Then told to hold volume up & power for 60 seconds, and it should come on, which it did.
May 28, 2014 | ASUS MeMO Pad HD 7
Tablet will not charge or come on.
I did this with my Asus memo pad 7 HD and it worked. http://www.youtube.com/watch?v=PXcQgpISSi8
The difference is only in removing the back cover. Use your nails to pop the cover to prevent damage. Do not use knife. Unplug the battery for 15 minutes than plug back in and pop the rear cover back on. After plugging the charger you should have the battery symbol on the screen. Then leave on the charger until fully charged.
Apr 01, 2014 | ASUS MeMO Pad HD 7
Black Screen no battery picture
If you are having this problem with the tablet, but the charger works fine with the cellphone, then mKe sure that you are using the right charger for the tablet, or it could be that the charging port in the tablet is damage, or the battery needs to be replace.
Mar 20, 2014 | ASUS MeMO Pad HD 7
Screen stuck
you can wait until like the batteries go dead, oput it back on the charger and u have to keep it on the charger until it charges, this will reset the whole screen
Feb 28, 2014 | ASUS MeMO Pad HD 7
Will not turn on
check the voly out in you vcd adapter if this exist go to open you pad and rebulding soldering the conector volt in and then ready you pad work again please vote
Dec 03, 2013 | ASUS MeMO Pad HD 7
Cannot install candy crush on asus memo pad hd 7. I get unknown error code "-24".
You will need to do a factory reset on the device. This should clear up this issue & then you should be able to download the Candy Crush application again afterwards.
Oct 25, 2013 | ASUS MeMO Pad HD 7
My Asus memo pad 7 will not download paid apps
Have you tried doing a factory reset? Try doing this under the settings menu, which should clear up any issues & then you can try to download your desired apps again.
Oct 22, 2013 | ASUS MeMO Pad HD 7
Tablets & eReaders Logo
64 people viewed this question
Top ASUS Tablets & eReaders Experts
Alun Cox
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
