Question about Ford Garden
What could be the problem. Any idea will be appreciated. Thank you for your help!
Tractor is a Ford 1210. Worked fine. Parked for a few days. rained on once. Tried to use the tractor. Starter will not make any sound. Thought battery was low. Charged battery overnight. Same problem.
    Problem Solver:
  • 12 Answers
Look for corrosion at battery and starter. Check voltage at both the battery and the starter. Use fine sand paper to polish it up. If all is good, I would probably try replacing the brushes in the starter ( about $25 for parts) and easier to do than it sounds. This will likely fix it, and If this doesn't, you will probably uncover the problem.
Posted on Dec 02, 2014
  • 8404 Answers
SOURCE: my 1949 8N Ford tractor, the starter just spins
My thought is you need a new "bendix" for lack of a better word. The device I speak of spins out and connects with the flywheel. There is the possibility you have electric problems but based on what you say, I think it is mechanical.
Thanks for posting your question at FixYa.com
Pleae vote
thank you
a
Posted on Nov 09, 2009
  • 146 Answers
SOURCE: Tractor wont start
For a small gas engine than won't start, think FAST -- Fuel, Air, Spark, Timing. You've replaced the filters and spark plugs and squirted in some starter fluid, eliminating the simple common fuel, air, and spark problems -- but I because of the backfiring I think your problem is in the timing -- like a sticking valve. Probably more than you want to tackle at home, but might not be as expensive as an engine replacement. Take it to a good small engine mechanic -- best bet is a lawn equipment shop that has been around many years. Drive a little farther to get to one if necessary.
Posted on Jul 03, 2010
  • 1456 Answers
SOURCE: I own a 2210 John
Hello
Unplug the "control wire"at the starter. Using a DC volt meter or a 12 VDC test light perform the following checks. A helper is usually needed. First off, check the battery voltage with the meter and write down the reading (for referrence in following steps). With the control wire unplugged, connect the volt meter positive probe (or test light probe) to the end of the wire and the other probe (or alligator clip) to a good, clean, unpainted ground (starter mounting bolt is good).
Now have your helper turn the ignition switch to the "cranking position". Your volt meter should respond and the reading should be the same (or within a few tenths of a volt) as the referrence battery voltage you got checking the battery.
If you DO NOT get battery voltage (or a "lit" test light) you have an "open" in the control wire circuit. I don't KNOW how your Tractor is configured (in regard to safety switches or "starter inhibitor switches") but you should be familiar with how YOUR tractor has to be started. By this I mean: Are you required to push down and hold the clutch to get the starter to engage (normally)? Are you required that the transmission be positioned in neutral before the starter will engage? If you can answer YES to either (or both) of those questions.....you will now have to locate and test the "Clutch pedal position switch" and/or the Neutral start switch" to determine if one of them has become defective. Because most electrical things like switches have plug-in connectors, corrosion in a connector body can cause an "open circuit" as well.
THANK YOU FOR VISITING FIXYA
Posted on Feb 07, 2011
dcurryn601
  • 60 Answers
SOURCE: Have a Yamaha YT3600 lawn
the starter puts out the amps to charge the battery, you have do an amperage check to find out what its puting
any good parts store will set you up with an inexpensive tester
Posted on Jul 23, 2011
aquaman987
  • 927 Answers
SOURCE: Tractor won't turn over. Replaced Battery,
Is the engine free to rotate? Can you move it by hand? If not, the starter can't.
If so, try removing the plug and starting it.
Gary
Posted on Jul 24, 2011
Bike won`t start after rain/snow
Hello, check your fuel filter, tank, hoses for presence of water.
That's the most common problem, condens water freezing and thus clogging the fuel flow...
Apr 18, 2014 | 2004 Suzuki VS 800 Intruder
My 2011 Ford F150 radio will not work. For a while the radio would pop and go silent, with only the clock display flashing, but would sporadically come back on. It now has not worked in a week. CD will...
Did you ever find out what was wrong? My radio was doing exactly the same. Popped, shut off, came back on later, repeat.... Email me a reply if you wouldn't mind, I only found this site searching for a solution to the radio problem.
Desertracer72@gmail.com
Sep 22, 2013 | Ford F150 Cars & Trucks
I have a 1989 mustang that was sitting for 6 years just got it back on the road and none of my windows wanna roll down and they were working just fine before car was parked fuse is good but dont know what...
If the fuses are OK, I suggest take off the trim panel door and check voltage from/at power windoes motor.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 13, 2012 | 1989 Ford Mustang
My ford 1210 tractor is blowing black smoke. I've
your injectors are set to rich
Jun 06, 2010 | Garden
JD 4020 Row Crop Tractor; No power Steering, No
In regard to the problem - JD 4020 Row Crop Tractor; No power Steering
What was the problem and how did you fix it I'm having a simlar problem
Apr 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Radio
Sounds like the head unit is bad on your audio system. You would need to replace the entire unit. I'd recommend an aftermarket stereo instead of another Ford stereo.
Apr 30, 2009 | 2005 Ford Focus
Garden Logo
71 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
