I disconnected my computer from my printer so I could print something not on the computer and now I can't remember how I did that. I want the printer to again print from the computer.
  • 1,915 Answers
Normally if you had a USB connection you should be able to just plug the printer back into the computer and have it work. If not you may have to run the install disk for the printer again.
Posted on Dec 02, 2014
4 Suggested Answers
  • 232 Answers
SOURCE: hp psc 1210xi all in one printer says refilled
Well, if the electronic circuit on the cartridge has blown, you have no other alternative then to buy a new cartridge. You can remove the cartridge and gently wipe the cartridge contacts. Turn off your printer, wait for a few min, then turn it back on. Put the cartridge back.
If that doesn't work,
  1. Open the cartridge access door.
  2. Remove either cartridge (not both).
  3. Close the cartridge access door.
    • If the computer message is Print Cartridge Error , then the print cartridge that is still in the printer is the problem cartridge.
    • If the computer message is NOT Print Cartridge Error (instead, it says that the cartridge you have removed is ...Either missing, not detected, or incorrectly installed ), then the cartridge you have removed is the problem cartridge.
There is a cmos battery in the printer, and, yes, when you remove it, the printer forgets everything (serial number, number of copies, etc). I have found a clip, but it says it only works for some HP printers. You can try that, but I am not sure that will help solve your problem.
Posted on Apr 11, 2010
Joed911
  • 4338 Answers
SOURCE: Prior to past few days printer worked fine. Now
Sounds like you cover all the bases. I just wonder if you reset the unit via the service mode?
resetting the printer should have cleared the memory.
Hold down select and return while powering on machine, hold until self test comes up on display then press go, this will get you into service mode.
Run the memory diagnostics.
Posted on Nov 23, 2010
  • 10406 Answers
SOURCE: My Dell V505 printer won't
Turn the printer off.
Disconnect the AC power.
On your computer, click Start
Click Control Panel
Click Printers
Select the Dell Printer
Uninstall it
Restart your computer
Turn the printer on
Allow the computer to reinstall the device-device for the printer.
Print a test page.
Posted on May 09, 2011
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
My lexmark s605 doesn't work, but the pinter and copier are all fine
Plug in usb cable from printer directly to computer then print something. If you're successful, try to print something. If you're on wireless connection, disconnect the usb cord and try to scan.
Aug 27, 2012 | Lexmark "interact s605 wireless all-in-one...
My Lexmark z2300 sends to the printer & it says it's printing, but it doesn't actually print. I've tried several file types & programs to print from but none of them work.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Sep 14, 2011 | Lexmark Z2300 InkJet Printer
Lexmark X4650 prints fine & used to scan to computer, now when press scan>scan to computer>downloading application list & seems to freeze.
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
Aug 31, 2011 | Lexmark X4650 InkJet Printer
While having a live chat i was informed the text would go to my print buffer....fine @! But I don't know what that is or how to access it. Can you help me ?
Hi
You don't say which operating system you are using.
The print buffer is an area where the printer stores a small list of the instructions given by the user ahead of what it is doing in real time (for example you can press print for 2 or 3 different documents while the printer is printing the first one and the printer will keep and remember the information for the subsequent documents in its buffer and print them in sequence, when it has finished printing the current document).
Feel free to add a comment to this question to explain the problems you are having with your printer, if this answer does not cover your specific problem.
Your printer has a small memory cache built into it that can store several pages of printing and print instructions ahead of what it is printing in real time. In the event of an error the memory cache can become full and be in a state where it accepts no more instructions.
If this happens:
Start (Contorl Panel) > (category View) > Hardware & Sound > Printer > double click on yhe printer's icon > highlight and cancel any documents pending > power off the printer > disconnect the printer cable > restart the computer > power the printer on > reconnect th eprinter cable > test print.
I hope this helps.
Aug 28, 2011 | Office Equipment & Supplies
I have a Lexmark X1240 that I have tried to use the scanner (never used but 1 time-it was too slow) NOW i can find my manual & don't know how to use it. HELP! I can print, but not scan from it!...
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 26, 2011 | Lexmark C533DN InkJet Printer
My Dell V505 printer won't print documents from the computer, when I press print the printer prints a page of dash's and ticks. there is ink in the cartridges. i've disconnected the power....
Click Control Panel
Click Printers
Uninstall it
Turn the printer on
Print a test page.
May 09, 2011 | Dell AllinOne Multifunctional (v515w)...
I have a 926 photo printer that wouldn't print. Now it will print but no ink is coming out (blank page comes out but acts like it is printing). I have restarted computer and disconnected the cables to...
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Sep 02, 2010 | Dell Office Equipment & Supplies
Hp psc 1210xi all in one printer says refilled cartridge is defective. HP says printer remembers cartridge serial number, counts number of prints executed & after certain number of prints, won't...
Jan 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
20 people viewed this question
k24674
