Question about Humax Televison & Video
Umc 21.6 tv from tesco will not respond to remote or the buttons on the top of the tv, or they may one in a 100 times
The remote works as i can sence ir flashing with digital camera. the controls on set aren,t obeyed either or it may display a menu but wont respond further, it as steadily got worst over last few months, I could do enough with humax freeview to use it as a monitor any one know the fix.
    Top Expert:
  • Humax Master
  • 74,185 Answers
The main board to your TV & the power regulator board should be checked. Your set need a through check-up. Contact any service technician. Electro help
Posted on Dec 02, 2014
SOURCE: Digital TV not working
i had same probs tv 4 monts old new tuner fitted
and yet one more new tuner fitted when 8 months old
it now turns pick off at randod but sound stays on have to unplug mains for temp fix
now warranty has run out philips are not interested
Posted on Apr 05, 2008
jerryg50
  • 1667 Answers
SOURCE: LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Posted on Apr 10, 2009
SOURCE: How do I replace the IR remote sensor on my LG TV?
My LG TV stopped responding to the remote. A very helpful repair technician told me to stick a head phone jack in the sensor jack on the back of the TV a few times to clean out the contacts. Now the remote control works fine.
Posted on Nov 11, 2009
welcomejee
  • 10594 Answers
SOURCE: my KDL sony tv turns
6 times blinking standby light indicates problem with Audio Section in tv
Check AU 15V output of G2 (power supply) board then check AU board as it has sound processor and sound output ICs.
If you are not familiar with electronics stuff repair then call local tv repairman to repair it for you.
Thanks.
Posted on Oct 29, 2010
Testimonial: " I diconnected the power to the AU board but the problem remained. I am assuming that the 15V output is for the AU board only. Any other suggestion?"
SOURCE: Acoustic Solutions LCD26761HDF TV turned
The solution to Acoustic Solutions problems, such as intermittant power off and flashing blue light is very simple: dump it in the trash. This product has lots of problems which are associated with memory and timing. There is no software update available, its just cheap Chinese ****.
Posted on Nov 29, 2010
Cannot register my new UMC tv PURCHASED FROM COMET
Umc do NOT cover any warranty at all from products brought from comet
my TV is 7 days old and broke comet wont do anything UMC wont fix it
Nov 07, 2012 | Televison & Video
I need remote control codes for a UMC 40
Download the user manual for this device. It will have all details. To download it, click here.
Aug 09, 2012 | Televison & Video
Have no remote for my umc-s15/3ng tv . How can i tune it in useing the buttons on top?
In most cases you cannot--do some research with Google to see if the original remote is available--Universal remotes for the most part are a waste of time and money.
Jun 02, 2012 | Televison & Video
Need codes for LG tv from rca remote thank u.
Hi! You can try using these steps for you to program your RCA remote control to your LG TV.
1. Manually turn ON your TV.
2. Press and "HOLD" CODE SEARCH
3. Press and release the TV button
4. Release CODE SEARCH.
5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the TV turns off, press and release ENTER.
7. With the TV on, press any other button. If the TV responds, no further programming is required. If the device does not respond, repeat steps 1-6.
I hope this works for you.
Jul 13, 2010 | RCA Universal Remote Control
Need code for mitsubishi tv
THE codes for programming RCA Universal Remote Control to a Mitsubishi TV are 006, 011, 014, 019, 022, 027, 041, 056, 061 and 068.
But then if it will not work on these codes you can try these steps for you to be able to program your remote control without the code.
  3. Press and release the TV button you want to set up.The TV button will flash once.
  7. With the TV on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Jun 13, 2010 | RCA Universal Remote Control
Remote does not work!
I have a universal remote and I am trying to communicate with my Magnavox TV but I cannot communicate.
Jun 25, 2009 | Sharp 21" Multi System Stereo TV
Pro team remote control
1. Press and hold SET button and press and hold device key at the same time, when l.e.d. lights release both keys.
2. Enter the code for your device.
3. Press power on the remote
If device can be controlled then code has worked if not try another code.
4.Press any device key to quit setting procedure.
Nov 19, 2008 | Big Button TV Universal Remote
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
Thomson top up tv remote codes
need sequence to tune in remote controller
May 13, 2008 | Televison & Video
Televison & Video Logo
49 people viewed this question
Top Humax Televison & Video Experts
Tony
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
