Question about AKG Harman K830bt Wireless Bluetooth On-ear Headphone Black
How do you replace the battery in AKG K830BT headphones? I'm ok with soldering stuff, so if that's what it takes... where do I get the correct battery.
Charging for over 24 hours. Using another charger. Turned unit on/off. Contacted manufacturer...
4 Suggested Answers
Grubhead
  • 5349 Answers
SOURCE: Right speaker is not operating on a set of AKG headphones.
Go in by the part that fits to your ear. You will need to remove the ear pad. Also the foam, you might have to force the foam off, you can glue it back when done. With them gone you should see access screws.
Posted on Feb 17, 2010
SOURCE: Hallo! I have been using AKG IP 1 ( i have own
If you have an account on ebay.com,you can purchase it online. so goto www.ebay.com thanks
Posted on Oct 26, 2010
SOURCE: i need to replace the cable for my AKG 450
Just buy a new one, I got mine from here:
http://www.proaleo.com/replacement-upgrade-headphone-cable-for-akg-k450-k480-q460.html#
http://www.proaleo.com/replacement-upgrade-headphone-cable-with-mirco-for-akg-k450-k480-q460.html#
the cheapest I could find with international shipping,hope it helps.
Cheers.
Posted on Dec 30, 2011
Right speaker not working akg k270
As monitors, I have used either the on-board speakers or headphones worn over the headworn microphone. In both cases, my own voice (as processed through 'Mike Effects' and VH) can't be heard over the music.
This is distinct from the recording on the USB stick where my own (processed) voice is in balance with the music.
Either I need an additional recording gadget to turn up the monitor volume of my processed voice while leaving the monitor volume of the music at a set level, or I have overlooked a setting somewhere. I am hoping for the latter (and I am still looking).
Honda Parts.
May 28, 2012 | AKG Audio Players & Recorders
Brand New AKG GHS1, only getting sound out of 1 ear
If warranty is there, get it exchanged. If replacement is not available try testing using a multimeter for continuity of left driver. If not getting continuity, open the headphones and see if wire is contacting properly. After opening, you can again test continuity of driver and wire separately and determine exact problem. If wire is wrong, you can purchase a cheap headset and take wire from it and replace your headphone's wires. If driver is spoiled, not easy to find spare.
If you use computer for browsing, this may be helpful for you.
https://youtu.be/9C3SRvhUMwY
Sep 27, 2017 | AKG GHS1 Headset
I need to replace the cable for my AKG 450 headphones
Cheers.
Mar 24, 2011 | AKG K 450 navy Headphones
How can i open my AKG k141 studio headphone to repair it ?
I had a problem with my AKG K141 Studio headset. The right side stopped working. Hard to believe but one of the leads to the ear speaker was disconneted from the solder lug. To disassemble, pry the gold AKG emblem using a jeweler's screw driver. You can pry it without damage by locating a small notch on the black plastic rim at the 6 o'clock position. Then unscrew ththe tiny phillips screw and remove black disc. You will see two leads (red and white) feeding through a hole. Disassemble removing a larger screw. This will give you accesss to the solder lugs.
Nov 30, 2010 | AKG K 240 Studio Professional Headphones
I have AKG 141 studio headphones and the right hand side earpiece wont make any sound, i believe it is faulty wiring because if you move it around you can make it work.
take away the glued brandmark with a sharp tool (knife , little screwdriver) and you will find a screw. loosen it and open it. there you will see some cables witch probably have one loose. fix it by solding it.
Sep 12, 2010 | AKG K 240 Studio Professional Headphones
Did i blow my speakeres in my akg 701's
Blown speakers get replaced not repaired. U may have overdriven the units.
Jun 20, 2017 | AKG K 701 Professional Headphones
Wiring code for the jack?
You're right on the code, with the exception of the right and left. I'm an AKG dealer and spoke to their service department. Here goes:
White=Ground
Yellow=Left
Red=Right
To confirm this, I used a multimeter in continuity mode and tested them. This code is 100% correct.
Nov 08, 2007 | AKG K 240 Studio Professional Headphones
AKG Harman K830bt Wireless Bluetooth On-ear Headphone Black Logo
152 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Vito Vacirca Jr.
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
