Question about Dryers
I need to replace a bulb in ceiling fan.The dead bulb is a 30 Watt Slyvania #FC9T9/DSW/RS I need to know the size as no one carries it.
Circular bulb for ceiling fan light,the dead bulb is a Sylvania 30 Watt #FC9T9/DSW/RS need to know what size in diameter it is.
    Scholar:
  • 42 Answers
You should be able to use one of the following as a replacement:
S6505
FC12T9/WW
32W T9 4 Pin Base Warm White Circline Fluorescent Light Bulb
Satco
S6507
FC30/SW FC9T9/SW FCL30LEX
30W T-9 9in 4-Pin
Satco
11085
FC12T9/KB
32W -Bulb: Circline T9 -Base:4-Pin G10q Single-End -
GE
20037
FC12T9/WW/RS
32W -Bulb:Circline T9 -Base:4-Pin
Sylvania
20233
FC12T9/DSW/RP
Sylvania
391227
FC12T9/SOFT WHITE
32W -Bulb:T9 Circline -Base: 4-Pin
Philips
Posted on Dec 02, 2014
  • 4 Answers
SOURCE: Minka aire ceiling fan
This may not apply. There could be an electrical problem. But if you installed the bulb with your hand, the oil on your skin can cause the buld to heat excessively and fail. I suggest you use the packaging or part of it when installing it, taking great care not to touch it.
Posted on Mar 31, 2008
landsend
  • 1066 Answers
SOURCE: Broken glass cover for Hampton Bay Cruiser ceiling fan.
go to Home Depot, not only do they have replacements, but they can order for you what you need.  Hampton Bay is the Home Depot brand.
Posted on Mar 31, 2009
  • 323 Answers
SOURCE: light kit has light bulb size that I cannot find bulbs for
Melanie, you must have gotten a bad batch of bulbs. I have installed over 100 Hampton Bay ceiling fans and I have dropped them from up the ladder and have them bounce across the floor with no damage. I think they must have allowed a substandard batch to go out.
Home Depot is where I buy my replacement bulbs. Hampton Bay make fans exclusively for HD.
You can easily change lighting bases, as the wiring is the same for all Hampton Bay. You may even appeal to Hampton Bay on the internet and they might send you the kits. But I don't think you'd have success in a store.
If you try replacing them with bulbs from another Home Depot you may find them much hardier. I wish you the best of luck, and if you need additional help please write back.
Sirwriter
Posted on May 25, 2009
  • 4 Answers
SOURCE: Chaning a lightbulb on a Turbo Swirl Ceiling Fan
The dome just pulls off.
Posted on Mar 15, 2010
SOURCE: minka aire concept II ceiling fan bulb replacement
The glass dome is tightened firmly in the factory, so removal is difficult. When removal is attempted to, the metal housing to which the dome is attached will spin with it, making removal impossible. To see what I'm talking about, look in the small space between the dome and the bottom of the blade housing - it looks like a metal flange, but this is only the bottom of the reflective metal canister that holds the light. Note that there are 4 "dimples" around the circumference of this housing, facing inward. These dimples are what hold the glass dome in place. The trick is to use a rigid piece of wood or metal about the size of a 12" ruler and place the corner of that ruler in one of those dimples - FIRMLY. Then, a second person can get some leverage on the glass dome and "unscrew" it from the housing (counter-clockwise). The purpose of holding the ruler-sized material against the dimple is to keep the housing from spinning with the dome. This is easier said than done, but it will work.
Posted on Jan 23, 2011
Newly installed Minka aire concept II ceiling fan is poorly lit. Installed in my son's bedroom and it's useless, dim.
probably not the reason for the dim light. It probably has more to do with the installation where you have wired the light before or after the fan so that power so the bulb is reduced by the resistance in the fan.
lights and fans are wired in parallel so that one doesn't affect the other
Might pay to talk with an electrician on the issue
There is a limit on the size of the bulb that can be used and a 100 watt halogen bulb will probably melt the surrounds and set fire to the fitting
get a desk lamp for his homework
May 24, 2016 | Minka Concept II Flush 44 Ceiling Fan by...
Hunter-ceiling-fan light wont work
Make sure your contact in the socket is touching the bulb.
Mar 27, 2014 | Dryers
Can I replace the 3 40 watts bulbs that came with my Hampton Bay Hawkins 44" ceiling fan with 3 60 watt bulbs?
You would be better off getting 3 40watt daylight bulbs.. extreamly bright low cost and wont cause any harm to your fan.. hope this helps :)
Oct 21, 2011 | Dryers
Newly replaced circular light bulbs flicker and strobe in Casa Vieja Ceiling fan and eventually burn out. Do I need to change ballast resistor?if so How do I change that?
Take the light down - a two person job in case you dont know it. Find and remove the ballast. Take it to a electric supply store and get a replacement. Get a new lamp at the same time.
Feb 20, 2010 | Casa Vieja Probe White Ceiling Fan
I am having issues getting bulbs due to the base size. It is in between a reg light base for standard bulb and the small base used for decorative lighting. The base is approx. size of a dime (Hampton Bay...
They actually have bulbs that are just made for ceiling fans, but can also be used for other things as well. You can get these bulbs at Home Depot, Lowes, etc. You might bring the bulbs with you if possible as sometimes it can get confusing after looking at twenty different designs. Hope this helps.
Jan 01, 2010 | Hampton Bay 52 In.Carriage House II in...
Question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
The fan works wonderfully. The problem is to find
You don't say whether they are screw or bayonet. It sounds like they may be "candelabra" size which is about 1/2 inch in diameter (miniature are about 3/8 inch and intermediate are about 3/4 inch. If you look on the bulb there will be a manufacturer's name and part number which you can reserach on the internet.
Aug 21, 2009 | Brookstone Dryers
Light kit has light bulb size that I cannot find bulbs for
Sirwriter
May 25, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Hampton bay Model 23758 replacement bulbs
go to any near home center (if there one). they should have the size bulb you need.
Home depot is authorized dealer form Hampton.
Oct 12, 2008 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
285 people viewed this question
Top Dryers Experts
