Question about Kenmore Washing Machines
Message constant check screening. screen is clean how do i fix?Where is sensor?
You need to reset the fault
turn off the mains hold in either the program select or on off or start stop or a combination of them
and power on at the mains
same thing like a sky or cable box to re-init it
then this clears the fault
Posted on Dec 02, 2014
Message constant check screening. screening is clean how do i fix
The sensor is located inside the plenum where the screen slides into. It will be a small metal probe sticking out to measure temperature in the cavity. Make sure the big metal hose coming off the back of the dryer is clear as well as the vent flap leading to the outside before you go tearing the dryer apart. If no airflow paths are blocked the sensor is likely bad. They almost all fail in the safest condition to prevent vent fires. Sensors are cheap and can be purchased online fairly cheap.
Dec 01, 2014 | Dryers
Message constant check screening. screening is clean how do i fix model 110-82822-102
There is a pressure switch or an electric eye that is plugged with lint or burnt out. Who makes that machine?
Constant red light
it may need a clean as there is a air flow sensor, if the flow is not right then it will have this on also a faulty sensor will read this aswell.
Mar 24, 2014 | Hoover AH60015 Air Purifier Replacement...
Dryer does not heat constantly. It starts to heat then turns off the gas. I need to dissamble it to test the parts.
Sounds like a block in the exhaust. Remove exhaust pipe and clean pipe. This is a huge fire hazard and your dryer is likely saving you from a fire. Remove large back panel on dryer. Clean all passages that handle airflow from lint screen back to exhaust. Restart. If this does not work, be happy that it is now clean :) The issue is likely your flame sensor at this point. Looks a bit like a spark plug. Short term fix. Clean probe with a dollar bill. Seriously, a dollar bill. Replace and restart. Order a new flame sensor.
Jan 11, 2014 | LG DLG0452W Gas Dryer
My Ion treadmill with LCD screen has an error message
1) adjust the speed sensor, clean it, tight the connector or plugs.see the diagram
2) adjust the Reed switch, clean it, and tight the plug or connector.
tight the ribbon cable inside.se the diagram
3) try to RUN the software calibration for diagnostic, troubleshooting, and fix it.
God bless you
Sep 19, 2012 | Bladez Ion 9.9 Fold-up Treadmill
The screen just show "paper
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Feb 16, 2011 | Canon MX300 Office All-In-One Printer
Lately, our fax has not been working and the message 'Check/remove original and press stop key' will appear on the LCD screen. Even after removing the original or clearing any paper, the LCD screen...
Thre is a "finger" sensor on the input tray. It is stuck in the "down" position. The fax machine falsly senses paper on the sensor.
Use compressed air (from a can) to clean the sensor and "work" it to free it. Do not lubricate it (no WD40 or duct tape, please)...
Sep 28, 2009 | Brother IntelliFAX 4100 Laser Fax
Lint filter sensor with Error Code: 01 constantly comes on after the dryer is in use for 5minutes or less. Screen is clean, vent from back of dryer to 3ft of flex hose to outside wall is spotless.
Sounds as though the sensor is dirty of faulty. I would recommend having a service tech out to check and replace. Also if the sensor is going bad, it may be tripping it due to the excessive heat.
Apr 08, 2009 | Bosch Nexxt 500 Plus Dryer
K image drum
The K drum sensor is probably covered with toner residue.
First clean out excess toner spill and see if you can clean the sensor , which should be an opening on the right side wall directly across the K drum. Use a cottonswab with alcohol.
If the sensor is bad, you should have a tech look at it, The sensor board is held in with14 springs!
Joe
Please remember to rate Techs who assist you for free :)
Oct 07, 2008 | OKI C5100n Laser Printer
Washing Machines Logo
24 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
