Question about Exercise & Fitness
The console will not work with the treadmill. Cannot start or change settings but is getting power.
Have reset circuit breaker, unplugged treadmill, replugged in back in and still get the same - console will not work.
    Problem Solver:
  • 6 Answers
Hi Nancy,
If you have tested the power point ~ for example: plugged in a vacuum cleaner and you have power ~ yet when you plug the treadmill in, you have no console display, there is a 99% chance you have a faulty lower control board...
Thank you,
Ben.
#treadmillrepair #treadmillbelt
TreadmillBelts.com.au HealthEquip.com.au GYMWORKS.com.au
Posted on Dec 02, 2014
  • 16 Answers
SOURCE: Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Posted on Apr 14, 2009
  • 8 Answers
SOURCE: treadmill wll not start, have changed the circuit
you have to have the little magnet on the front of the treadmill. If it is an old treadmill, you may just need to get a new one. Hope i helped!!! :D
Posted on Jul 14, 2009
maxtreadmill
  • 832 Answers
SOURCE: where is the circuit breaker or fuse message err 1
That error code mean you motor is not getting the correct signal to operate the drive motor. You will need unplug unit then take the motor shroud off visually inspect all connectors then make sure all of them are seating solid in their connectors. then plug the unit in check an see if the L E Ds have lit on lower electronics board then get on unit and with your foot proceed to move the belt while doing that hit your start button and see if that error code come up. At this point we are checking the speed sensor to see if it is functional. Now if your upper console is registering its showing speed and time moving forward this also tells us that the communication between the two boards are fine. Now stop this process and you should have the error 1 show on the console. If you have a multi meter handy find the two leads coming form the motor going to the board unplug them put the two leads into the connector switch the meter to dcv 100v range and proceed to move the belt in the previous now the motor has become a generator and if function you should be getting a dcv output if not the it telling either worn motor brushes or open winding in the motor now if you get a reading then that lower board is defective. Then call York and get pricing on the defective part.
Posted on Apr 11, 2010
maxtreadmill
  • 832 Answers
SOURCE: will not power on
The lower board has a serious short and what possible happen is that the treadmill breaker fried and open up will properly need replacing also.
Posted on May 06, 2010
  • 3287 Answers
SOURCE: Yesterday while using the Schwinn
This is not sounding good. A reset normally would solve a problem with the logic on the circuit boards that control the unit, but that doesn't sound like it worked.
According to Schwinn, the troubleshooting procedure for a treadmill that won't turn on are as follows: Make sure the outlet is powered, it is plugged into the outlet, the device turned on by the switch and the safety key is in position. pretty elementary stuff - but I included it because that's what the manual says to do.
I can suggest the you try unplugging the power cord from the outlet for a minute or two, then plug back in & try to start the treadmill again. Sometimes that is the only way to be sure that there is no power reaching the circuit board(s) to perform a reset of the logic. If the circuit board(s) remain powered they can be "locked up" and will not allow normal operation of the device.
If unable to get the treadmill to run, you'll probably have to contact Schwinn Customer Support for assistance. You have a choice of ways to contact them as shown here.
I hope this got you going - or at least pointed you in a direction to get help. Please rate my reply. Thank you.
Posted on Apr 06, 2011
No power
Check the reset/off circuit breaker located on the
treadmill frame near the power cord. If the switch
protrudes as shown, the circuit breaker has
tripped. To reset the circuit breaker, wait for five
minutes and then press the switch back in.
Mar 07, 2014 | Proform XT 70 Treadmill
I have a Proform 625 treadmill that I had to move. I unplugged the unit, slid it to where I needed it to go and plugged it back in. When I did so, the console powers on, but the display flickers and the...
You can try the following:
a. Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor
is plugged into a properly grounded outlet (see page 9). Use only a single-outlet surge suppressor
that meets all of the specifications described on page 9. Important: The treadmill is not compatible
with GFCI-equipped outlets.
b. After the power cord has been plugged in, make sure that the key is fully inserted into the console.
c. Check the circuit breaker located on the treadmill
near the power cord. If the switch protrudes as
shown, the circuit breaker has tripped. To reset the
circuit breaker, wait for five minutes and then press
the switch back in.
d. Check the on/off switch located on the treadmill near
the power cord. The switch must be in the on posi-
tion
Nov 25, 2013 | Proform 625 Front Roller Model Pftl62510
I have the 1750 NordickTrack Treadmill and the screen is "froze" on the SD or WiFi screen. I tried pushing the stop button, shutting off the power, and even unplugging the power cord and it still shows...
try this steps and fix it. God bless you
Step 1
Plug the power cord into a UL 1449 single-outlet surge suppressor and then plug the surge suppressor into an electrical outlet that is not GFCI-equipped if the power does not turn on. If the treadmill is plugged in and the power still does not work, make sure the key is in the console and that the Reset/Off circuit breaker has not been tripped. Press the switch to "Reset" if it has been tripped.
Sponsored Links
Gym Equipment Choose from 1M+ Verified Suppliers. Contact Directly & Get Live Quotes! www.alibaba.com/Gym-Equipment
Step 2
Check the Reset/Off circuit breaker if the power switches off while in use. Wait five minutes and switch the button to reset. Check that the power cord is still plugged in securely; pull the plug out and plug it back in after five minutes. Pull out the console key and reinsert to see if the machine will turn back on.
Step 3
Place the chest pulse sensor tightly right underneath your pectoral muscles or breasts for it to operate properly. Position it lower or higher on your chest if it does not work properly. Wet the electrodes with a saline solution. Walk near the walking belt's center within an arm's reach of the console.
Step 4
Remove the console key and unplug the treadmill to loosen the walking belt if it slows when in use. Turn the rear roller bolts counterclockwise with the hex key 1/4 of a turn until you can lift the walking belt's edges 3 to 4 inches from the platform.
Step 5
Remove the key and unplug the treadmill to adjust the walking belt if it is off-center or slips when in use. Loosen the rear roller bolts with the hex key and reposition the walking belt. Tighten the roller bolts. Walk on the treadmill to determine if the walking belt is centered. If not, loosen the roller bolts again and make adjustments until the walking belt is centered.
Step 6
Recalibrate the incline system if the treadmill's incline does not adjust correctly. Press the "Incline" button and remove the console key. Wait a few seconds and replace the console key. The incline will automatically recalibrate by moving to the maximum incline level and then the minimum level.
Step 7
Press the "Stop" button for a few seconds to turn off the demo mode if the console display stays lit after you remove the console key.
Read more: http://www.livestrong.com/article/241157-nordic-track-treadmill-troubleshooting/#ixzz2geWlKdPR
Oct 02, 2013 | Nordic Track NordicTrack COMMERCIAL 1750...
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
A2550 no power at all
Dear Sir:
1)Most probably you did short circuit.
2) Test the fuse or breaker inside.
3) Check if you breaker from your house or building is tripped, since there are No power Must be 90% that your breaker in your building is tripped.Re-started again.
4) Test again the treadmill, and will be working
Of course when you open for to see the fuse or breaker, see if there are something with smell to burn. If there are burn, you must to Test it.
Finally you must not used extension cords. Use directly to outlet with connection to ground +device for power transient+100% stabilizer of voltage.
sincerely.
Nov 22, 2011 | Nordic Track NordicTrack Treadmill, A2550
Error 100 won't connect to network anymore to use ifit live
Check the power cord to ensure it is connected to the power supply and the treadmill if the power does not stay on or does not turn on. Look at the circuit breaker, located near the base of the unit, to see if the circuit was tripped. Push the switch back in to reset the circuit.
  • 2 Take the key out of the console, wait a minute and place it back in the console to resolve issues with the power turning on and off during use or if the console displays are not functioning properly.
  • 3 Remove the console key and press the "Stop" button to turn off the "Demo" mode, which is often the default setting when the treadmill is first purchased.
  • 4 Reset the incline by holding down the "Stop" and "Speed increase" buttons and putting in the console key. Release the buttons and then press the "Stop" button, followed by the down or up arrows for the incline. This step can be taken if errors are occurring with the incline function.
  • 5 Turn the treadmill "Off" and unplug the unit if errors continue. Wait five minutes and then plug the unit back on, insert the console key, and turn the treadmill "On." This will reset the treadmill and should return to normal funcTION
  • Oct 04, 2011 | Nordic Track NordicTrack Elite 9500 PRO...
    Pro form 365 won't start
    Dear Sir:
    I will help you, please do the exact step:
    PROBLEM: The power does not turn on
    SOLUTION: a. Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor is plugged into a properly grounded outlet (see page 10). Use only a single-outlet surge suppressor that meets all of the specifications described on page 10. Important: The treadmill is not compatible with GFCI-equipped outlets. b. After the power cord has been plugged in, make sure that the key is fully inserted into the console. c. Check the reset/off circuit breaker located on the treadmill frame near the power cord. If the switch protrudes as shown, the circuit breaker has tripped. To reset the circuit breaker, wait for five minutes and then press the switch back in.
    Finally: check, the breaker from the home, if there tripped, check this, and Reset.
    I will recomend when you finally set up, install Stabilizer Voltage, is cheaper us$15,00 aprox
    Thank you in advance, sincerely.
    Blessing, if you need additional help, please contact me.
    E.CUADRA MANAGUA, NICARAGUA.
    Sep 26, 2011 | Proform Crosswalk 365 Console Treadmill
    The power is on but it won't run
    Power issues with treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
    If the treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
    Thanks for the rating Good luck
    Dec 22, 2010 | Exercise & Fitness
    It does not turn on says safe
    This message appears when you remove the Safety key.
    Kindly provide me with the make and model of the machine?
    Are you sure that the key is intact? Is it properly placed?
    Thanks!!
    Aug 21, 2010 | Exercise & Fitness
    Bodyguard T240 wont start
    To use these instructions, you need to have a familiarity with electricity and a working knowledge of a voltage multimeter. With all of these tests, USE EXTREME CAUTION!!! Never let the voltage ground directly to any part of the treadmill or your leads ground while you are testing voltage.
    1) To begin, set your volt meter to AC volts. We are going to trace the power from the wall outlet through the treadmill to see where it ends.
    2) With the treadmill unplugged, test the wall outlet. You should have from 115 to 125 VAC. Optimally, you will have at least 120 VAC.
    3) Follow the power leads from the power cord to the lead ends. With the treadmill unplugged, connect your meter to the lead ends. Plug the treadmill in and check your reading. It should be the same as your reading from the wall outlet.
    4) Continue this process with the electrical system, following the leads, as they pass through, breakers, fuses, and the like.
    5) Where the power flow ends is where your problem is. Sometimes it will be in a bad connection, sometimes it will be in a shorted breaker or blown fuse, at times it may be as simple as a safety switch not working properly, or it may be a major problem with a component.
    6) In some cases, components work in tandem (i.e.- a controller may need a signal from the console computer to release voltage to the motor.
    TESTING FUSES, BREAKERS, WIRING, AND SWITCHES
    1) One of the most common problems with power outages is problems with fuses, breakers, wiring, or switches.
    2) If your treadmill is equipped with a safety switch, set your volt meter to continuity. Touch your test leads together to make sure you are getting a closed circuit. With the treadmill unplugged, back the leads off the safety switch, usually near the upper display computer. With the safety key out, test the switch. It should be open. Push the safety key in. Your circuit should be closed. If this tests ok, move to the next step.
    3) While testing for voltage, you can unplug your treadmill and test the fuses, breakers, and wiring harnesses. Sometimes a breaker may have shorted open and not tripped. Test these components individually. You want a closed circuit on all of them
    Jul 10, 2010 | Bodyguard T240 Treadmill
    Exercise & Fitness Logo
    96 people viewed this question
    Top Exercise & Fitness Experts
    Electro Med Services...
    Howard
    Howard
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
