What kind of screwdrive do I need to take off the bottom of a Sgarp EL-2630piii calulator?
    Scholar:
  • 82 Answers
First of all, what are you trying to do? There is a reset button that can be pressed using a ballpoint pen if you just want to reset it. If you want to change batteries, you can take off the battery cover that may be held in place by a small screw. The screwdriver for this is usually a small Philips (cross head) screwdriver like a watch makers type.
Posted on Dec 01, 2014
3 Suggested Answers
drknow
  • 44 Answers
SOURCE: set date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
To set the time Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key twice and the time will be diplayed, key in the info as follows: 12:00pm would be keyed in as "12". "00", the display will show 12.00 then press the clock/calendar key, the correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
Posted on Dec 19, 2007
lbrown1806
  • 488 Answers
SOURCE: change date sharp el-2630PIII
"GT": Grand Total
"•": Neutral
" ": To set up date, time, conversion
rate, and tax/discount rate, place the
switch at the "RATE SET" position.
Date:
• Enter in the order of month, day
and year, then press to
complete the entry.
• Use to separate month, day,
and year.
• When is pressed, the number
entered is evaluated and displayed
as "date" if the value is within the
following range; "Error" is
displayed otherwise, and the
previously set date is restored.
Month: 1 - 12; day: 1 - 31; Year:
2000 - 2099 (in 4 digits) or 00 - 99
(in 2 digits)
Time:
• Enter in the order of hour, minutes,
then press to complete the
entry.
(There is no entry available for the
seconds value. The clock starts at
zero second.)
• If the hour/minute digit is less than
10, it is not necessary to enter the
first digit "0".
• Use to separate hour and
minute values.
as "time" if the value is within the
previously set time is restored.
Hour: 0 - 23 (24-hour system for
the hour entry), Minute: 0 - 59
Posted on Dec 19, 2010
How do I clear a paper jam in my Sharp EL-2630PIII adding machine?
My paper is stuck and jammed in the feeder. I cant add new paper because of the jam. The new paper crinkles up as it feeds. Is there a way to remove the jam of paper that's stuck inside ?
Jun 13, 2014 | Sharp EL-2630P Calculator
I have replaced the ribbon twice now but the print still comes out very light
I'm having the same problem. This is my second Sharp EL-2630PIII calculator and the first one did not have this problem (prior job). I can change the ribbon and the print is still so light I cannot scan it as part of my work papers... which is a huge problem as an accountant.
May 21, 2014 | Sharp EL-2630PII Calculator
CE button doesn't clear on my SHARP EL-2630PIII
CE stands for Clear Entry. It clears the number that one just entered. To clear the results of a previous calculation use the key AC, if calculator has one. Otherwise try pressing the CE key twice or enter 0, because that is what the clear button will do.
Sep 30, 2013 | Sharp EL-2630P Calculator
Sharp el-2630piii calculator setting to two decimal points
Slide the "F 6 3 2 1 0" switch to the "2" position.
Feb 28, 2013 | Sharp EL-2196BL Calculator
Looking for the manual for the Sharp EL-2630PIII
http://www.sharpusa.com/~/media/8C9B594394224D3DABF52671B634DDB1.ashx?cal_man_el2630P.pdf
May 25, 2010 | Sharp EL-2630P Calculator
I want to know what is the fraction equivalent of the following decimals
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=662433c8924616b3264931192aff1225&q=Sharp+EL-2630PIII
Feb 01, 2008 | Sharp EL-2630P Calculator
32 people viewed this question
k24674
jasbo
jasbo
