Question about Ruud Heating & Cooling
Code lights won't light on rheem ruud 1028-928
Replaced circuit board
  • 46 Answers
That board runs on 24v power. I would check to see that you have 24v from C to R at the t'stat wire terminals. Also make sure that the fuse is in place and that it is good.
Posted on Dec 02, 2014
5 Suggested Answers
SOURCE: Ruud 90+
removed the flex hoses from the pressure sensors and reinstalled them. Unit reset and now works perfectly.
Posted on Apr 27, 2008
  • 147 Answers
SOURCE: I replaced my Rheem Ruud
When the purge motor turns on, the controller is waiting for proof that it is running before ignition. On your model I think it a differential pressure switch and it should be in front of the furnace. Should be able to see a pressure or vacuum line running to. If it isnt there there may be a switch inside purge motor. If there is more than 2 wires running to the motor it probable is there. Anyway the controller is waiting for proof.
Posted on Nov 05, 2008
  • 116 Answers
SOURCE: 3 amp fuse blows on ruud silohette II blower. what
if this is a split system unit look for a short in the stat line weed eater damage! mark all wires on stat wire and un hook if still blows board bad if not short in stat wire hope this helps
Posted on Jun 18, 2009
matthew_lipp
  • 46 Answers
SOURCE: what is the blink code for Ruud 2 stage ac/furnace
on the board itself or on the schematic there is a legend that will tell you what the blinks mean. start there. its just a diagram that gives you the fault according to the number of blinks
Posted on Oct 04, 2012
Just installed a Rheem RTG-95DVLN. Tried turning it on but all im getting is the # 82 flashing & beeping incessantly! Anybody know why or have any suggestions? Im completely stumped...
According to Rheem trouble shooting, at the end of page 61, error code 82:
Error Code 82
Explanation: Gas Type Control Data Failure; Printed Circuit Board data failure. The PCB has not
been programmed, lost its programming or has failed.
5. If the unit does not operate on initial installation or after replacement of the PCB, then the
circuit board requires programming with the fuel type and altitude chip.
http://hometips.me/Tls/SVC810-Rheem-Ruud-Tankless-Service-manual-2008.pdf
Feb 17, 2016 | Rheem Water Heaters
Rheem heat pump not coming on in heat mode. Control board has two LED lights # 1 solid, #2 blinking. What does this mean?
Usually wen the led lights are blinking it means there is a problem. If you look on the door or the cover there should be a code that tells you what the blinking represents.
Example - one blink per second - compressor, two blinks - fan motor, etc. The other thing you can do is look up the model number on line for the installation manual and it should have all the info you need.
Jan 08, 2015 | Ruud Defrost Control Board 47-102684-08...
No power
you have a low amp fuse protecting transformer. could be thermostat issues.
Dec 12, 2013 | Ruud Rheem Corsaire Control Circuit Board...
We are getting multiple codes. Can someone help us. Last year we got cod c2 11 which we found out we just have to clean the probes in the unit. So we did that yesterday again and everything worked great,...
Rheem, Richmond, Ruud, and Paloma are all the same manufacturer. After about 9 months, my tankless RTG-74PVN started giving me error code 11 and cold water!. I fixed it by cleaning the burner, as shown in this video:
www.howtolou.com/clean-a-burner
Jul 31, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
Replaced mother board due to error code c2 11 as per rheem tech department. now code 11 flashes after 3 to 4 minutes of use and unit shuts off. WHAT NOW????
Dec 29, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I replaced my Rheem Ruud 62-24084-82 Ignition Module Control Board in my Rheem gas furnace last year. Has worked great until last night. Now blower purge motor starts but does not go into ignitor cycle. ...
Nov 05, 2008 | Ruud Heating & Cooling
Ruud 90+
Apr 26, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
73 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
