Roku LT Logo
L
Linda Freeman Posted on Dec 01, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to add another roku in my house and dose not like my password?
Have as far as the email and dose not like the password, wondering if because have a roku in living room already.
Thomas Stauber
Level 3:
Master:
  • Roku Master 438 Answers
  • Posted on Dec 11, 2014
Thomas Stauber
Roku Master
Level 3:
Master:
Answers
438
Questions
Helped
90644
Points
1054
Temporarily disconnect the Roku in the living room and try to set up the new Roku and then reconnect the other Roku. Hope that helps.
Where can i open a wowtv.sx account??
How To Add WoWTv to Your Roku Channel After you purchase a subscription you will receive an email with account information within 15 minutes to 8 hours. This information is needed after adding the WoWTv Channel to your Roku. After the WoWTv Private Channel has been added to your Roku, on first launch of the Channel you will be presented with an activation code that is needed to link your new Roku Private Channel to your WoWTv.sx account. Below are instructions on how you install the WoWTv Roku Channel. These instructions are for theRoku 3, but same steps are taken on the Roku 1 & Roku 2.
Please add [email protected] to your SPAM Filter allowed list. 1. Have your Roku activation code ready . Log into our account at http://owner.roku.com/Add. Of-course, if you do not already have a Roku account, you will have to create one.
2. Once logged in, click Manage Account > "Add a Private Channel"
3. Insert your New IPTV activation code. Click on "Add Channel" after inserting activation code.
4. Confirm you would like to add the channel shown.
5. Click on "Return to My Account". You will get a confirmation that the channel has been added as shown below.
After installation is complete, check your Roku to verify the channel is showing. The channel should appear shortly after install. If it does not, you can restart your Roku to speed up the process. The first time you launch the channel you'll be presented with an activation code that changes about every 5 minutes. This is the code you will use with the instructions we send you after you subscribe. You can also email the code along with the payment, and we will try to activate it for you. Unfortunately, the code auto changes every 5 minutes, so we might not get the code in time. You can do it yourself following the instructions we provide. But if you need help please let us know.
Your WoWTv has been added to your Roku Channel. Happy Streaming!
Forgot my CODE, CAN YOU HELP?
Open a browser session on a PC or Mac - Go to www.roku.com/link Log into your existing Roku account or create a new Roku account. And enter the code.
If you forgot your password, you can recover it here. A new password will be sent to the email account listed in your account. If you do not see the email, be sure to check your spam filter.
1helpful
Can't get my email & password to let me sign in
The easiest solution is to reset your your Roku and start all over again. Then insert you email address and your password. A reset button is on the back of the Roku.Keep it pressed for 10 sec when you apply power to the device.
Nov 09, 2014 • Roku 2 XD
3answers
How can i retrieve my password for my roku so i can hook up a second roku to another tv ?
I believe that each Roku must have its own password. You can go to the Roku site and deregister your current box, then re-register it and your second box with new passwords. Or you can press the reset button on your current box and that will flush your old password and return the box to factory settings.
How can I enter password in roku 3 I don't know how it connect and not work
I have created this document that will step you through the setup and also enter your password for your network. Hope this helps you.
Follow these steps to setup your Roku player 1. Connect to your TV
  • Use a HDMI cable. Connect one end to the HDMI port of the Roku player, and the other end to an available HDMI input on your TV.
  • Make note of the TV input used.
2. Power up key components
  • Open the battery compartment and carefully insert the provided batteries into the slots, following the correct battery orientation.
  • Power up the Roku player by connecting the provided power adapter to the Roku player and to an available wall outlet.
  • Turn on your TV and select the correct TV input.
3. Connect to your network
  • If you are using a wireless network, select "Wireless" as your network connection:
  • Select your network from the list of available networks.
  • Enter your wireless network password when prompted. (Note: passwords are case-sensitive)
  • If you are using an Ethernet wired connection, select "Wired (Ethernet)" as your network connection.
4. Complete guided setup
  • Get the latest software
  • Your Roku player will let you know if there is a software update available, and will restart after the update
    is complete.
  • Link your Roku player from any Internet browser
  • A link code should be displayed on the TV screen after restart
  • Using an Internet browser, follow the instructions to link your Roku player to a new or an existing Roku account.
Help for common setup mistakes and solutions
Symptom
Possible causes
Try these!
I don't see any picture on the TV
TV is OFF
Cable loose
Roku is OFF
Wrong TV input
Ensure TV is ON (it's more common than you think)
Check all connectors are snugly in place
Check power adapter is snugly connected, and wall outlet is working
Select the correct TV input
I can not connect to wireless network
Weak wireless signal
Wrong wireless name
Wrong wireless password Wireless name hidden
Move Roku player location (even a few inches may help)
Ensure correct network name selected
Ensure correct password entered
SSID can be hidden, use "Add Network" from wireless network screen
My remote does not work
Not in line of site
Batteries weak
Get closer and ensure there are no obstacles between your remote and the Roku player
Try a fresh set of batteries
Resolving wireless connectivity
If your Roku player isn't connecting to your wireless network, try the following:
Description
Do this
Tips
Repeat guided setup • •
Go to Settings>Network>Wireless•
If "Update connection" is available, select it to refresh your connection
If not, just select your wireless network from the list, enter your wireless password when prompted
If you were previously and just lost connection, you may not need to enter your password again
Passwords are case-sensitive
Restart the Roku player and • your wireless network
Unplug the power connector from • the back of the Roku player
Unplug the power connector from the back of your wireless router
Unplug the power connector from the back of your modem
Plug the power connector back into modem (wait a couple of minutes for it to fully boot)
Plug the power connector back into the wireless router (wait a couple of minutes for it to fully boot)
Plug the power connector back into your Roku player, and wait for the image on your TV
Follow repeat guided instructions above
Your wireless router and modem may be combined as one device
Factory reset the Roku player
From the Roku home screen, sele•ct Settings>Factory reset and follow the instructions
Note: You can also reset the Roku• player using the reset button. Find the reset button on your Roku player, press and hold for 15-20 seconds ( the front LED will rapidly blink a few times)
Factory reset should be used as the last resort, if all other steps failed to recover functionality
After a reset, you will need to relink your Roku player to your Roku account, and setup subscribed channels with username and password, if applicable
If you forgot your password, you can recover it here at this URL:
Forgot Password
Top Roku Televison & Video Experts
vince
Paul Carew
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
