Question about Bissell Proheat Upright Carpet Cleaner Roller Brush Assembly With End Caps 210-1128 - Genuine
Machine will not go forward
I took off front clear cover to clean and now the machine will not go forward, as if locked.
    Habit-Forming:
  • 22 Answers
That clear cover you have to put properly. In the midlle you have small noch that needs to be engadged (locket).Try to slide front clear cover on the base and don't forget to put 2 screws
Posted on Dec 02, 2014
Testimonial: "I took off and put on until I thought the screws were beginning to strip. Finally after an all day job of trying,my husband comes home and he took apart twice but finally got everything in that properly position. I guess I just wasn't holding my tongue right. Thanks"
When the shampooer is moved forward to initially to spray the shampoo the plastic guard on the front drags the floor and keeps it from moving forward and shampooing. .
The one's I've used the sprayer is on the back of the suction (suction hood which is kind of clear plastic), you watch that clear part to see if it is picking up dirty water. Recall it's easier to pull it and if caught just push down on handles and that raises front of machine to clear carpet snag. I would walk backward as it sprayed and then picked up the water with dirt. If different machine you could spray moving backward, go back to same starting point go again and don't spray but just hold it near carpet so it picks up the water.
Jun 03, 2016 | Bissell ProHeat Pet Upright Deep Cleaner,...
How do I make the machine easier to push forward ?
Dyson will tell you to remove the gaskets from the cleaning head. I have 2 Dysons, both of which became impossible to push after new carpet was installed. I was skeptical, but it worked.
Nov 29, 2015 | Dyson DC14 Animal Bagless Upright Cyclonic...
How do I attach the upholstery tool for the Royal RY7910 carpet cleaner?
Flip up the little cover on the clear nozzle on the front, insert the suction hose of the tool and twist to lock in place. Push the water hose onto the valve on the side of the machine.
Feb 16, 2015 | Royal Vacuums
I let someone use the cleaner, and it came back dirty. How to I clean the front plastic where the water pulls the dirty water through. It is day and filthy. Help
There are three screws that hold the clear plastic cover in place. Turn the machine over and remove the two silver colored screws at the outer edges of the cover. To remove the third screw, remove the dirty water tank, and you will see a screw at the top center. After the screws are out it should be easy to pull the cover off for cleaning.
Apr 09, 2011 | Hoover SteamVac F5914-900 SpinScrub...
How do u replace belt
Turn the machine over - locate the clamps that hold the cover on and open them. Fold the cover forward toward the front to expose the "belt alley". Lift the roller brush from its cradle. Place the new belt over the pulley on the brush and over the end of the motor. Put the brush back in the cradle. Replace the bottom and re-clamp the snaps.
You may want to clean the hair and string from the brush while you have it out.
Good luck
a
Oct 21, 2009 | Hoover Soft Light Supreme U4262-930 Bagged...
My bissell powerbrush won't **** up the water
had same problem - carpet soaked with dirty water and very little, if any, cleaning fluid used. Easily remedied. Removed water resevoir and found that the rectangular shaped washer at the top of the front cover (the bit you had unscrewed to give a good clean) had become dislodged. It has small lugs on either size which lock on to the plastic opening when pushed down firmly. Resevoir then sits on top and makes full connection, also ensure that grey locking handle is fully pushed down.
Seemed to me that the water wasn't being sucked up as there was air getting in and this has down the trick. Sorry if this is difficult to follow but all will become clear when you look for the black washer! Good luck
Mar 18, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell Proheat 12 amp is hard to push forward(whether on or off). There is a loud clicking noise when pushing forward and it ''jumps'' up on every loud click. It's OK when pulling backwards, sprays and...
I had this same problem and here is what solved it for me. On a previous cleaning session, my wife decided to take the two front screws out of the clear plastic shroud that covers the brushes in order to clean behind it. Upon re-installation, she did not secure the top part correctly. On the end near the water tank, there are two tiny half-moon tabs that absolutely need to be seated in their opposing slots in the chassis.This allows for a good seal which enables the machine to **** up the water. It also keeps the front cover level and from dragging on the carpet when pushing it forward. Both were problems I was experiencing. Hope this helps!
Mar 09, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell ProHeat 7901 will not **** up water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
adfa
Nov 11, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Hi, i have a hoover steam vac agilty. the brushes on the bottom front quit spinning. they are not locked up as i can freely turn them by fingers. is there a belt that i need to replace? if so, how do i get...
The brushes on all hoover steam vacs are air opperated it uses the suction of the vacuum motor to spin a turbine and in turn spin the brushes. Most likely that path of air is clogged with hair or carpet fuzz. On the top of the machine there is a little clear cover undr that cover there is a screen which keeps that hair for entering the turbine kinda like you clothes dryer lint trap. Take the cover off and clean that screen this should help. If you have any other questions or need parts for that machine or any other visit www.stevessewandvac.com
Aug 12, 2008 | Hoover Vacuums
HOOVER STEAMVAC F7425-900
There some screws off from the bottom, remove the top cover, the turbine has 2 screws on the front of it and there 2 long screws you take off from the bottom, remove the tubing and it should come loose. Some times you can take it apart and clean the inside parts and it will work ok, if that doesn't do it then you have to replace it.
Apr 02, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Bissell Proheat Upright Carpet Cleaner Roller Brush Assembly With End Caps 210-1128 - Genuine Logo
83 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
