Zenith. When you power on the tv will click 3 times but will not turn. Red light stays lit.
    Top Expert:
  • Televison & ... Master
  • 14,161 Answers
Don't waste you time, TV's are getting very cheap and better. Save up and go get you a SMART TV. You will be much happier.
Posted on Dec 02, 2014
    Top Expert:
  • 34,733 Answers
This is not a remote control problem. More likely there is a failed power supply.
Posted on Dec 01, 2014
Won't power on
Sounds like a Zenith or LG TV. It is most probably the Y board, when you hear the clicking sound is usually that. I am sharing this with you because it happened to me with a Zenith (POS). The red light (on my TV) is in the bottom right corner. In my case it was the Y Board. Best of luck
May 14, 2017 | LG 50PA4500 50" 4500 Series Plasma HDTV
Hi. I have a Zenith 42" plasma TV - Z42PQ20 that's
I had this exact problem on my TV, everything said it was the power board. It wasnt, luckily i was able to return that board. It was the YSUS board.
I should have done this this first but this is how i verified the old power board was good. Unplug TV, take the cover off and disconnect the wire harness going to the YSUS, plug TV in and turn on. If led stay blue its the YSUS.
Mar 19, 2011 | Zenith Televison & Video
My remote that came the TV is malfunctioning. I think it may have lost the code for the TV. How can I find the code?
Hello
Three digit remote codes for Zenith TV are:-
000/ 001/ 004/ 023/ 038/ 058/ 059/ 064/ 121/ 135/ 136/ 153/ 0016/ 0017/ 0092
Four digit remote code for Zenith TV are:-
0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Nov 19, 2010 | Zenith SY2068DT TV
What are the Zenith TV codes? I have a Universal TV remote.
Hello
Zenith TV has a lot of codes to try. See them. Ok.
[0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001]
Direct Code Entry Procedure
Code Search Method
Nov 06, 2010 | Zenith Televison & Video
Need to control my zenith tv with theDigitallstream -DTX9950
Hello
I've only one code for Zenit TV at this time. It is "0634". It is the code for Zenith HDSAT_420, HDSAT_520, HDSAT_1080. Sometimes this code may work with your TV also I thinks.
Proceedings
Oct 24, 2010 | Philips Magnavox 20MT133S 20" TV
Setup a one for all remote what is the 4 digit code number for my tv I have a 1997 Zenith
Hello
I've only only one digit code with me. It is "0634". It is the remote code for Zenith HDSAT_420, HDSAT_520, HDSAT_1080. Sometimes this may work with your TV also.
Proceedings
Oct 23, 2010 | Zenith C27A24T 27" TV
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
Code needed
The Zenith remote control codes for an Innovage Jumbo remote control are:
000, 001, 004, 023, 038, 058, 059, 064, 073, 121, 135, 136 & 153.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
Dec 24, 2009 | Innovage Jumbo Remote Control
I have a universal philips remote control without codes i need the codes
Some times universal remote controls have an option to find codes automatically.
if not try these 3 digit codes one at a time.
002 008 115 215 405 407 601 701 713 903 916
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
3. Enter the 3 digit code from the code tables. Note:
Dec 14, 2009 | Zenith C27A24T 27" TV
Zenith zn620 universal remote
This may be of help for Zenith codes:
http://www.thompsontv.com/zcodes.html
Jul 20, 2008 | Zenith ZN620 Remote Control
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
