Question about Trisonic New Waterproof Torch Light Flashlight Sporting Camping (Trisonic)
Just wondering about the energizer rechargeable led torch, when we charge it fully,the red light dosent go of?and the green light dosent go on, after a full charge the light seems to be not all that b
Just wondering about the energizer rechargeable led torch, when we charge it fully,the red light dosent go of?and the green light dosent go on, after a full charge the light seems to be not all that bright?,could it be batteries?or some thing more?it cost $100 so should be a professional torch as it says so ?
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
Jan 23, 2016 | Ryobi Garden
I have an Energizer Model CHDC7 battery charger for AA/AAA batteries. I'm not sure how to use it. Specifically, when batteries are inserted and plugged in, it displays flashing green lights over all...
Nickel-Metal Hydride (NiMH) batteries are usually charged in pairs in consumer chargers. The CHDC7 can charge two or four batteries at a time. Their position in the charger is important (see the link at the end of this note). Each battery has a separate pair of green LEDs. There are no other LEDs on this charger. The LEDs light up to show the state of charge. Flashing means it is charging. Solid means it has reached that level of charge (ie, 1 LED = half charged, 2 LEDs = fully charged). The batteries will get warm but not uncomfortably so. After some practice you will be able to tell if they are getting too hot (which may signal a worn-out battery which should then be replaced). Like all rechargeable batteries, NiMH batteries have a finite life (measured in number of times they've been discharged and recharged). IMHO, they should also be used and charged in matched pairs. I mark them when I take them out of the box and keep them paired in use and in charging for maximum life. Yes, the devices that use 3 batteries are a pain to deal with. LOL. All details can be found on this Energiser data sheet: http://data.energizer.com/PDFs/chdc7_instructions_english.pdf
P.S. The CHDC7 remains open for charging. Closing it for storage is optional but minimizes the space it takes up.
Jul 30, 2011 | Vacuums
What does it mean when a household battery charger flashes red then green? The charger is a SYNERGY DIGITAL rapid quick charger. I'm trying to charge new AA Energizer Lithium batteries.
When the charger light is changing from red to green that is a indication that it is charging the battery. When the charge is complete the light will stay green until the battery is removed or the charger is unplugged.
Jun 06, 2010 | Energizer Rechargable Battery with Charger
The LED's on my Energizer charger flash red and green constantly.
If your charging 2 batteries only they must be palced in the following poistions on the charger
1. both side by side in the 2 left slots
or
2. one each in the two right slots.
Otherwise the batteries will not charge.
The users manual can be downloaded here:
http://www.energizer.com/SiteCollectionDocuments/pdf/rechargeable/CHDC.pdf
Thanks for using FixYa.
Kelly
If the batteries are charging the battery indicators
Mar 24, 2010 | Energizer Rechargable Battery with Charger
Lights on Rechargable Lantern.. Swissgear SG66301
I don't know how to solve your problem but, the three lights mean this:
Red LED light indicates the battery is being charged
Green LED light indicates that the battery is fully charged
Amber LED light incidates that the battery power level is low - the battery needs recharge.
Do not recharge you battery over 24 hours.
Nov 03, 2009 | Kitchen Appliances - Others
I have an Energizer E2 Slider battery charger, Is the green light supposed to stay on when charging. Does it shut off when charge complete.
all chargers show a light of some colour when charging , green or red , depending on make of charger , when the battery is fully charged the unit monitor this and automatically switch of to stop from over charging , a safety feature that has to built in for safety reasons ,
Jul 19, 2009 | Energizer NiMH Compact AA/AAA Battery...
What does the charge plus+ light and the green light mean together
replaced.
Jul 11, 2009 | Ryobi Multi-Volt Battery Charger
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
BATTERY CHARGER RADIO SHACK DELUXE 10 CELL
I would go to Radio Shack and have them explain the proper charging procedure as well as inquire about the red and green lights as not all chargers go green when fully charged-Normally red indicates a charging action and if a charger has no fully charged light, then a required charge time period is noted in the instructions. Batteries can be ruined by over charging!
Jan 03, 2008 | Energizer Rechargable Battery with Charger
Trisonic New Waterproof Torch Light Flashlight Sporting Camping (Trisonic) Logo
48 people viewed this question
Top Trisonic Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Trisonic Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
