Question about Building Materials
Where is the learn button on a raynor model FLTSTR
2 Suggested Answers
75trie
  • 20 Answers
SOURCE: We can not find a learn button anywhere on our raynor model 170-7 and we need to reprogram our remote.. help... where do we find the learn button or how do we re-program our remote ? We moved the ope
Your problem poses more questions. I'm not sure about the Raynor model. Since you moved the opener from one door to another, are you positive that the electric eye sensors are lined up? When I do a project like this, the first thing I do is look for the owners manual. If you can't find it look on line. Having that book will save a lot of time and headaches. I have a different type of opener but they should all have a sensor mounted on the jamb on both sides of the sides close to the floor. I lined mine up when it was dark. After both sensors are mounted properly, using two pieces of paper, one dark color and the other a light color. Start by mounting one piece of paper right behind the
receiver sensor. If the light hits the paper, readjust the sending unit. If you can't see the light, try using the other color paper. Also turn off the lights. If you are sure that the alignment is good, try it again. If it works, job done. As I said I'm not sure about your brand of opener. Mine has a small hole in the face of the unit that is screwed to the wall. Bend a paper clip so you can get it into that hole. With the door opener in one hand and the paper clip in the other, and the garage door closed, push the paperclip into the hole for no more that a second or two. If you hold it in there too long you will burn out the door control so be careful! If it doesn't work, try it several times. If the doesn't work, you need a service call.
Posted on Jan 04, 2015
My garage door won't close makes Moab sounds. Needs a manual of raynors model pilot
Hello, Melvin -
If you have not yet thought to contact Raynor Garage Doors directly and ask for help, I suggest you do so. This is the link to the Raynor Garage Door Contact Us web page:
.http://www.raynor.com/contact.cfm
You will find the Consumer Inquires phone number there.
I have no idea what "Moab sounds" are.
Best wishes.
Apr 27, 2018 | Building Materials
I have a Raynor (Flitestar) garage door opener. I am trying to program a universal remote (Brand name Chamberlain). The directions tell me to locate the "Learn" button. I can not find the learn button
you will have to remove the cover from the control unit and there will be a small button to press --probably have learn under it
press that and then program the remote to the controller
Oct 26, 2016 | The Optics
We can not find a learn button anywhere on our raynor model 170-7 and we need to reprogram our remote.. help... where do we find the learn button or how do we re-program our remote ? We moved the opener...
I think you will have to pop off the back of the garage door opener to access the learn button. Once you find it you press it and the garage door opener light will come on. As soon as this happens press the button on the remote and hold it until the garage door opener light flashes.
Jan 04, 2015 | Building Materials
Raynor garage door opener
There is a limited amount of remotes that are allowed, I believe it is six. You could contact raynor suppport for help.
Feb 05, 2014 | Electrical Supplies
Where is learn button on raynor 170-7 garage door opener
I am pretty sure there isnt a learn button. I have this same opener and if it has the receiver that came with it its from the 90's and it was "programmed" with a tone of dip switches. If you lost the remotes a cheap way to get a usable remote is with this:http://www.amazon.com/Universal-Garage-C... To get this to work properly you will need the external 12 power supply which is sold at home depot:http://www.homedepot.com/p/SkyLink-12-Vo... It is normally not carried by the stores so check online first and i would recomend using their ship to store option unless you are buying something else to get free shipping.
Jan 23, 2012 | Home Security
Program a Raynor Garage Door Keypad
You need to locate your learn button. It will be located in the receiver box ( on the back of the motor, with a wire hanging down), Pop off the Nameplate on the receiver box. you will find a green yellow or red button. push the button and an LED comes on for about 30 seconds, during the 30 seconds go to keypad, enter a new 4 digit code. press and hold the enter button on keypad. DONE Note: if you have sensors on your door, you do not want to walk throught them, or the keypad will not program
Raynor Can help
Apr 23, 2010 | Computers & Internet
Reprogram keypad remote
Setting the code:
1. Press and release the "learn" button on the motor unit. The learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal indentification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the button when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
Apr 25, 2009 | Computers & Internet
How do I re-code my Raynor Garage door opener Model 61 rdg (on Remote) Serial # 17592 (on opener) Year 1992?
Open the back of the remote, change the order of the pin switches inside your remote. Then Go to receiver box ( on back on Motor) Open name plate to locate your learn button, Push the learn button, an LED light comes on for 30 seconds. During the 30 seconds, push the button on the remote and you are done
Apr 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a Raynor FliteStar Garage Door Opener that was built in 1999. Our new Prius has a smart button to open the garage door. I cannot program the Prius to open the door because the door security has "...
The flite star has an external receiver ( a box located on the back on the motor), Remove the name plate from receiver box and you will find the learn button on a circut board
Mar 18, 2009 | Toyota Prius Cars & Trucks
Raynor 1245rgd navigator learn button blinks
5 flashes on operator and the short movement on the door indicates a bad RPM sensor. try to unplug the unit for 30 seconds, if this does not reset the motor, replace the RPM sensor
Dec 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
71 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
