Question about Ematic EGL25BL eGlide 4 Tablet
How do I mount my sd card
I went to settings and pressed mount sd card, but it doesnt work
  • 3 Answers
Maybe the SD card is damaged.
Try if it is working on a different device or computer.
Posted on Dec 01, 2014
Testimonial: "No...sorry I mean the internal sd card"
Files on SD card not appearing?
try to unmount your SD card from device storage settings from your phone and re mount it. Also make sure you are seating the SD card correctly, it could be that the SD card reader on the phone is damaged. However you can check this by inserting a different SD card and if that doesnt work. Its likely the SD card reader that has the problem.
Oct 15, 2015 | Android Apps
All of a sudden my dragon touch has lost all of the apps were on my sd card what can i do
Go to Settings>Storage>External SD and look for the *unmount* option. Touch *unmount*. This will electroncally close the SD Card connection so it can be safely removed from the slot. Then remove it from the slot. Then clean the brass contacts with a little piece of toilet paper. Then slide the SD card back into the slot.
The device should automatically *mount* the card. If it doesn't and there is a mount option shown then touch *mount*. If it still doesn't work then chances are your SD card went bad. They do that sometimes.
Jun 23, 2015 | Dragon Touch Tablets & eReaders
In my wildfire s set sd & phone storage the mount sd card option is not working.in this menu total space is unavailable and available space is unavailable while the sd card is workin properly in other...
Delete all messages and call logs.......if still problem persists then probably there are some malware occupying your memory which creap in if u use internet on ur phone......solution is - factory restore ur phone after backing up only important data.....if this does not work then hard reset ur phone.....press vol. up, camera and power button together for a few seconds.......download/boot mode will appear......press menu or vol. down button and scroll down to CFT calliberation ...select using menu button......phone will restart....this should solve ur peoblem..
May 03, 2014 | HTC Wildfire Cell Phone
Sim card not working on xt912
try a soft reset on ur phone then when its done go into ur options and go to mount sd card and then put it back in and see if that works if it doesnt you either have to buy a new sim card if that doesnt work factory reset your phone if that doesnt work your sim card port is probly fried and has to be fixed
Jun 02, 2012 | Motorola Mobility Droid RaZr XT912 16GB...
I tend to get angry alot and I have an HTC Inspire, and I threw it at a wall or something and the frame was bent I got it fixed yesterday and the guy straightened the frame out the best he could, and fixed...
A crack can develop in the circuit board that will cause that. A broken solder joint on the card holder or adjoining components will do it too. Time for a new phone.
Mar 13, 2017 | HTC Inspire 4G Smartphone
Hello. I tried to reset my new Sony Ericsson Xperia X10 in line with he user guide. I went from Settings to SD Card & Phone storage settings, but from there I cant find the 'Factory data Reset' option...
1 From the Xperia 10 Home screen, tap the applications bar.
2 Tap Settings > SD card & phone storage > Factory data reset > Reset phone.
3 Enter your screen unlock pattern.
4 Tap Erase everything.
Done! Now, You can reset your Xperia X10 to its factory default settings.
Mar 25, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Gphone Error
Maybe you can try to reset the phone back to factory settings (you'll lose all your data!!): 'Home' > 'Settings' > 'SD card & phone storage,' then select 'Factory data reset.'
Dec 01, 2008 | Google Android
G1 SD
if reemoving and reinserting the card doesnt help, youll need to have it reformatted....
do this by connecting your phone to the pc and opening your MY COMPUTER icon > right click REMOVABLE STORAGE/DISK > select FORMAT
**if your computer says something like 'no disk available' try disconnecting the device and select MENU > SETTINGS > SD CARD AND PHONE STORAGE > make sure the check bos for 'USE FOR USB STORAGE' is checked****
after that, set the 'file systems' as FAT32 > select START > read the warning > press OK > once complete, disconnect from the pc and try again!
IF that doesnt work, try to test the sd card in another phone to see if the sd card itself is the problem. if you still have the issue but the sd card works, go ahead and reset the phone.
MENU > SETTINGS > SD CARD AND PHONE STORAGE > FACTORY DATA RESET > RESET PHONE > ERASE EVERYTHING
Nov 17, 2008 | HTC G1
My tomtom doesnt turns on. It shows the green led when pressing the power button, but doesnt show anything. It doesnt charge and doesnt show any led while on charge. I tried the reset for 10 sec (and 15...
Remove the micro sd card from your TomTom. Look at the bottom of your unit, where the copper contacts are (where the unit mounts to the windshield mount). You will notice a "cut-out" in the plastic case, just above the contacts. The reset button is there. Use a paper clip and depress this button for 15 seconds. Now press the power button, and it should turn on. Now replace the sd card.
Jun 27, 2008 | Tomtom GO 510 GPS Receiver
Ematic EGL25BL eGlide 4 Tablet Logo
78 people viewed this question
Top Ematic Computers & Internet Experts
David Payne
David Payne
Are you an Ematic Computer and Internet Expert? Answer questions, earn points and help others
