Question about Microsoft Video Game Consoles & Games
How do one move the mouse wheel in the wildlife camp game
I held it do and move the mouse around can not go any farther.
Why am I missing one of the files needed to run wildlife zoo?
This is because with Win 7 and above the kernel was changed again, while I wont try and confuse you with tech talk, if you run a search for the file you are missing you will find it and be able to download it and set it up for your Wildlife Zoo to work.
May 13, 2014 | Dreamcatcher Wildlife Zoo jc
Cursor Jumping Around
****a piece of Scotch tape over a mouse's laser, might make it work perfectly******
***some optical mouse's need a mouse pad and some work
on any surface.***
i use a lot of computers that have mouse's that i have to
list it slightly and let them ride on a finger when they are
off the mouse pad.
a few weeks ago, my good mouse finally frayed its cord and i
had to start using one of my redundant mouse's that needs a
mouse pad.
i noticed immediately that it could work almost normally if
i lifted it 1/4 inch off the table.
I'm not going to deal with this like that though..
i speculated that it must be because the laser sensor is too
sensitive..( since it works better from farther away....)
i wanted to try to put a piece of scotch tape over it to
act as a diffuser to make it less sensitive, but i was too
busy. lol. so like a month later . i finally tried the tape
idea, and it works perfectly!!!. dam
if you get an optical mouse that goes crazy without a mouse
pad, you should try this
Dec 14, 2013 | SteelSeries Ikari High Performance Laser...
Mouse Jumping around
Bad mouse. I've actually had this happen to me.
Dec 14, 2013 | SteelSeries Ikari Laser Gaming Mouse...
Hello, ive just installed wild life park 2 on my windows 7 laptop but on starting the game it said i needed administration priverlages ive tried setting settings to run on administrator but i really stuck...
Instead of left mouse clicking on the icon to start the game, "right" click the mouse and choose run as administrator from the drop down box. Hope this helps you out.
Mar 01, 2011 | 2K Games Wildlife Park 2 for Windows
How to ouse the mouse?
The mouse is used by people to navigate around the operating system like Windows.
There are a number of buttons on the mouse, Left Click, Right Click, Scroll Wheel and Wheel Click.
Your index finger operates the Left Click and you middle finger operates the Right Click and Scroll Wheel.
The mouse, when moved in turn moves whats known as a cursor on the screen, it's that arrow.
Think of the cursor as your pointing finger.
Hope that helps!
damnor01
Jan 08, 2011 | Computers & Internet
I play a game that requires to hold down both buttons to move around but when i do the mouse wont let me move
reinstall all drivers for that mouse and also go to the game website for any patches for issues with your particular mouse.
If all else fails, you may need to call the manufacture and ask what mouse is compatible for the game you are playing.
Mar 05, 2010 | GE Wireless Optical Mouse
Change battery
If you look at the top of the mouse, you'll see left and right buttons, scroll wheel and a big piece that makes up the rest of the top. The back of the top moves farther back and up. You hold it with your fingers under the front of the mouse and your thumb on the center behind the scroll wheel, and gently push back on the large piece of plastic (where your palm normally rests).
Feb 18, 2010 | Logitech Cordless Mouse
How do you use the 21 speeds on the Schwinn ladies coaster bike?
there are 7 cogs on the rear wheel hub; three on the crank hub:
7x3=21 gear change possibilities
large gears move the wheel faster and farther around but, with more effort
small gears move the wheel less distance but, with less effort
i.e. 10 teeth divided by 30 teeth= 3:1 per 360 degree rotation of the bicycle wheel
Sep 07, 2009 | Schwinn Cycling
When I move the cursor to play a game, the whole screen moves too
How are you moving the cursor? Is it time to change the batteries in the mouse, if it's cordless...
Use the scroll wheel and the CONTROL key - spin the wheel back and see if the screen shrinks. Then click elsewhere on the screen to make sure you're not dragging the whole gameboard around.
Nov 11, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Video Game Consoles & Games Logo
43 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
