I have a yamaha rx-v793 5.1 receiver and a Dresden Acoustics Ds.10 speaker set. I'm having trouble configuring it to play through all speakers using the phono ports with a headphone jack(until i get the optical from my xbox). The main left and right run through the subwoofer then into the A switch. The centre, rear left and right are in their corresponding slots on the receiver. What am i doing wrong?
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 166 Answers
Phono input will be a lower line level than other inputs
Posted on Dec 01, 2014
SOURCE: Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
Posted on Jun 24, 2008
SOURCE: I have a Yamaha Rx-v363
this sounds strange, but is true. you need to run your digital audio optical cable from your tv to your receiver (after, of course, connecting tv/receiver via hdmi). so, hdmi from blue ray to rec - hdmi from rec to tv - then optical from tv back to rec. it's round about, but that is how yamaha says (and the only way it works) to do it.
Posted on Jan 04, 2009
  • 163 Answers
SOURCE: Have put an optical cable from optical digital out
You need to do digital input assignment. Go to SETUP, DIGITAL INPUT ASSIGNMENT, set OPTICAL 1 for your input (DVD).
Posted on Apr 09, 2009
SOURCE: No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Posted on Apr 14, 2009
easyq
  • 144 Answers
SOURCE: The subwoofer is not working on our Bose 5.1 surround speakers.
First of all you should never indicate speakers as Large unless they can produce below 20Hz (which is very low), otherwise always set your speakers to Small.
Second, did you also indicate in teh setupmenu that you have a subwoofer? Because if all speakers are set to Large some receivers will omit a subwoofer because Large indicates the speakers can reproduce all sounds even below 20Hz.
So walk through your setup menu, say YES when the sub (SFW) is asked for and that should do the trick.
Posted on Apr 17, 2009
Speakers not playing
The problem can be the cable or speakers or RX-V463 or settings. Need to check one by one.
Set the RX-V on DTS or Dolby Digital
1) Check Cables - connect the 2 (surround) cables from RXV's Centre Out to Centre speaker. If the Centre speaker works, then cables are ok.
2) Check speakers - Connect each Surround speaker to RXV's Centre out. If it works Speakers are ok.
3) Check RXV - Set it on DTS or Dolby Digital
Connect RXV's surround out (one at a time) L and R to the Centre speaker. If there is no sound, the problem could be RXV's settings (I need to read the manual).
Hope this helps.
Nov 20, 2013 | Yamaha RX-V463 Receiver
What are the surround sound settings for a yamaha rx-v461?
It has many, depending on the your speaker configuration, the source hardware and the source material...
Read the manuals...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-RX-V461-Receivers-manual/id/2526ci760/t/2/
May 07, 2011 | Yamaha RX-V461 AV Receiver
When I set my Yamaha rx-v363 amplifier to 5ch Music Enhancer all my speakers (including the sub woofer) work fine except for the center speaker. I can't even adjust the center volume on the amp (but I can...
The receiver automatically pick the best configuration for the source audio. Most music is 2 channels being up-sampled to 4 channels. (Sub-out is separate.)
Mar 22, 2011 | Yamaha RX-V363 Receiver
I have a Yamaha RX-V863 receiver connected to a
Do you have all 5+1 speakers connected? You need to go to the Setup menu of yamaha and set which speakers you have and which you don't. For example if you don't have the Center speaker connected, receiver will redirect and mix the sound to the other speakers.
Blue-ray film over HDMI should automatically output via all your configured speakers (nothing to be configured).
Nov 26, 2009 | Yamaha RX-V863 Receiver
Yamaha RX-V463 Receiver Speaker Setup
That receiver has A and B channels. Look for the Speaker button and press it until B appears on the diplay. The other room speakers will play the same thing as in the main room.
Jul 05, 2009 | Yamaha RX-V463 Receiver
Front speakers no sound!
Most likely you have pressed the speaker AB switch, try pressing it again and see if it works.
Mar 11, 2009 | Yamaha RX-V663 Receiver
Config Problems After Repair
Sounds like they centre has configured your speakers to "none". You need to hook it up to a tV or monitor and go through the menu to "speaker settings" and make sure you select either "sml" or "lrg" for the speaker type. Also ensure on the LFE settings that you select either "swoofr" or "both."
Nov 02, 2008 | Yamaha RX-V800 Receiver
Yamaha RX-V661 polarity problem
There is no "fix" the mic is picking up a lack of bass based on room acoustics and is trying to help. There is nothing wrong. If you are using bi-pole or dipole speakers it will always show out of phase.
Feb 27, 2008 | Yamaha RX-V661 Receiver
Problem: I am trying to Hook up my RX-Z9 and get sound out of MAIN.
Try pressing "Main A" or "Speakers A"-button on the remote-control (slide the shield at the bottom)
Nov 14, 2007 | Yamaha RX-Z9 Receiver
60 people viewed this question
 Grubhead
Grubhead
