Question about Sangean America New-digital Mp3 Recorder - Dar101
Sangean dar-101 earpiece audio quality bad, ringing-echo sound, any fix?
This is the second one, I thought the first one was bad. It has a sort of ringing-echoey sound in the earpiece of the phone.
Media full...........means what? and how do I fix it????
the SD card must be full accupied, try to delete some useless files to get more free storage capacity.
Jul 08, 2013 | SANGEAN-PERSONAL & PORTABLE Sangean...
Yamaha YAS101 sound bar does not work on DirecTV remote control
Try this solution:
http://faq.yamaha.com/us/en/article/audio-visual/digital-sound-projector/yas-101/7598/6609/?current_page_id=1&sort=undefined&type=
Jun 22, 2012 | Yamaha YAS-101 Front Surround Sound Bar...
Sangean ATS-909X Volume control has failed (no longer trims volume). A little pressure on the control will sometimes restore its function. Sounds like a bad solder joint or a cracked board. Any th
A similar problem with SANGEAN ATS-909x I have too.
When you touch the volume control ever hear the full volume.
Tap volume control side, the sound is normal.
Suppose a poor connection on the control volume.
Correction here in Slovakia is not guaranteed.
Receiver has a serial No: 0C000451 is under warranty, purchased through E-Bay from Taiwan, made 1/2011 and purchased in 2012.
It seems that I remains only a decoration.
Milan
Translation by GOOGLE
May 11, 2012 | Sangean ATS-909X Professional Multi-Band...
People i am talking to on my pantech burst cannot hear me because there is an echo on their end
I had the same problem and had tried everything. The noise conceling was turned on and made no difference. I finally put a piece of sctoch tape over the second microphone located beside the flash and the problem disappeared. I think the dual microphone is causing the issue, it picks up the speaker sound and the time delay causes the echo.
Feb 27, 2012 | Cell Phones
My eee pc 105ha audio has a very discernible echo which makes speech almost incomprehensible and gives a ballpark like quality to music.This is unaccepatble. Will the maker take it back?
I had the same problem. Easy to fix:
Start, Control Panel, open Realteck Audio panel and change teh sound effect to none. Mine was set to Auditorium and had a nast echo.
Jan 05, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
What do you recommend to stop phone echoing? I own an AT&T Dect 6.0 cordless. It echos no matter where you are in the house.
Echo is usually caused by the mouthpiece picking up sound from an overly loud earpiece.
if there is a way of turning the volume down try that, if not the only other possible thing to try would be to dampen the volume from the earpiece using a small piece of tape or similar.
Jul 07, 2009 | AT&T 2462 Cordless Phone
CAN I ADD AN ECHO OR REVERB TO INPROVE THE SOUND
Well, I don't think you can add Reverb/Echo Internally but Externally.
External Echo/Reverb unit is available but most of them are AC Operated but Mipro MA-101 is Rechargeble Battery Operated.
You may be able to find Battery Operated Reverb/Echo units but they are usually Line Drive (not a Microphone Drive).
Go to a Music instrument store or a Guitar store.
Usually they have ton of these.
Though, You will not improve the sound much at all by using Reverb/Echo unit since you are very limited by quality of the amplifier itself too.
Jan 30, 2009 | Mipro Audio Players & Recorders
New Phone Causing Echo
It sounds like your microphone volume is too loud. Get someone on a call with you so they can tell you how it sounds as you adjust it. Turn down the mic volume by pressing the + & - buttons on the earpiece together once which puts the earpiece into mic adjust mode. Then decrease the mic volume by pressing the minus button a few times until it sounds right. The earpiece will automatically revert to normal mode within a few seconds.
If this doesn't work it may be that you need to adjust the compatibility setting for the new phone. This is the small black dial on the base station. The most common setting is 'A' but you may need to experiment with other settings for that phone.
Nov 04, 2008 | GN Netcom GN 9120 Professional Headset
Sound Problems
that is a very good awnser go with him
Mar 27, 2008 | Logitech Quickcam Chat Webcam
Motorola H350 - Incoming calls
there is nothing you can do about the delay as it's the time it takes for the bluetooth to send the signal to your earpiece to tell it the call is answered, the only way to stop any delay is to set your phone to auto answer in the bluetooth headphone settings or in the call settings.
Aug 07, 2007 | Motorola Mobility H350 Wireless Headset
Sangean America New-digital Mp3 Recorder - Dar101 Logo
32 people viewed this question
Top Sangean America Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sangean America Audio Player and Recorder Expert? Answer questions, earn points and help others
