Question about Hotpoint Ovens
Hotpoint oven DQ891 not heating up to proper temperature
  • 54 Answers
Check thermostat and or elements
Posted on Dec 03, 2014
  • 93 Answers
SOURCE: Why won't my oven heat to the proper temperature?
All these problem related to temp sensor or thermostat. check your wire harness for proper connection. or change your temperature sensor.
Posted on Jul 25, 2008
Krazytech
  • 725 Answers
SOURCE: No heat
check your elements are they red?
Posted on Aug 17, 2008
  • 338 Answers
SOURCE: oven not heating
you could have lost one of your 120v leads to the machine. that could cause it to work only half way. go turn the breaker off and then turn it back on and see if that corrects the problem.
Posted on Dec 07, 2008
  • 2692 Answers
SOURCE: Hotpoint BU71 tripped my electric last night and
The bottom eliment is most likely burned open and need to be replaced.
Posted on May 19, 2009
espressonist
  • 1711 Answers
SOURCE: I have a Hotpoint dy46
The Main Oven temperature control which is the knob at the right of clock is a thermostat and is working like an electrical switch. So you need to replace the temperature control.
If you have already replaced the element then you can easily remove the temperature control knob. Just take care to note the wire where each one goes and a very simple way just take a photo.
The red light you mention is a pilot light which mean when is on the thermostat control is switch on so power goes to the element.
Posted on Oct 02, 2010
Top oven of hotpoint DE47X/2 not reaching working temperature
could have loose connection somewhere
Nov 19, 2013 | Ovens
Hotpoint SD97PI oven self cleaning funtion and grill not working
The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components. The most common complaint I have had with built in ovens besides the element burning out, is the oven door locked shut. When I get to the house and I ask to tell me a little bit of whats going on the story always starts " well, I was using the self clean option" or some variation of the sort.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 22, 2012 | Hotpoint Ovens
Hotpoint BD 42 Oven, main oven fan turning slowly and oven is not heating up to temperature
Hi you will to have a tester , start off by checking power at the outlet , if you have the 220 volts then we need to check the elements inside the oven, you may a have a bad element and a bad fan , after checking power get bacl to me , also need model number and serial number
Dec 01, 2011 | Ovens
The thermostat light does not stay on during cooking.the cooker does not get hot enough to cook properly.the light goes on and off during cooking.I think it should be constantly on.The cooker is a hotpoint...
Hello there and thank you for choosing fixya.
This is a very common issue with these appliances
Normally the temperature sensing probe is the part that fails and when it does the oven will heat up only some and the probe will indicate that it is at the right temperature thus turning off the light
when in fact the oven is not fully heated up
So i would first inspect the temperature sensing probe/ thermostate and if it looks really old or greasy i would highly suggest replacing it ok normally they are around 45 dollars or so ok?
Keep me posted on how this is going so i can give you any help that you may need
Best regards MIke
Jun 29, 2011 | Ovens
Our hotpoint stove/oven does not stay at a constant temperature
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 14, 2010 | Ovens
Oven not heating
Hello.
If the fan is working, but there is no heat, then it is the fan oven element that needs to be replaced.
It has nothing to do with timer on this occasion.
Remove panel at rear of oven compartment, there you will see the round element.
Undo fixing screws,and remove element, disconnect leads and fit onto new element, refit new elemrnt, replace cover, and job done!!!
Please leave a fixya rating for my solution.
Thankyou
Feb 04, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Oven not heating
Dec 07, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint bottom oven
Cooking is determined by 3 things so let's look at what they are and what they do.
They are:
  1. The Fan Oven Element - This is very much the same as a light bulb only instead of giving off light it gives off heat. Like a light that is switched On or Off by a wall switch, the Element is switched On or Off by a Thermostat according to the temperature required. In short if the element fails your oven will be cold.
  2. The Fan & Motor - This sucks the air in through the centre mesh and circulates it around the Element and pushes the heated air out of the top, bottom and sides of the back-plate. Fan ovens cannot heat properly if the fan is not running OR if the fan runs too slowly as the motor starts to fail.
  3. The Thermostat. - This is basically an On/Off Switch that responds to the temperature in the oven. If The Fan is running correctly and you are achieving some temperature in the oven, then the fault will be with the Thermostat.
I hope this Helps - Terry
ALWAYS ISOLATE THE POWER SUPPLY BEFORE WORKING ON THEI APPLIANCE!
May 06, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Ovens Logo
64 people viewed this question
Top Hotpoint Ovens Experts
ashburton
Colin Stickland
Colin Stickland
Charles T Nevin
Charles T Nevin
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
