Question about Coffee Makers & Espresso Machines
How do i get a new part for my combo coffee maker that ony makes single cups
    Master:
  • 560 Answers
Contact the manufacturer.
Posted on Dec 01, 2014
fwadley
  • 482 Answers
SOURCE: lost the manual for westbend 36 cup coffee maker
2 scoops for 12 cups, that would be 6 scoops
Posted on Dec 24, 2007
  • 2976 Answers
SOURCE: How does it make coffee?
You fill it to the line indicating how many cups of coffee you want to make. Then you add coffee to the brew basket, at least 1 full heaping teaspoon per cup. Put the basket on top of the stem and place the stem into the coffee maker. Put the lid on and plug it in. That's it. Don't plug it in without the lid, it's a percolator. It will squirt the water out the top of the stem and it flows down through the coffee grounds.
Posted on Jan 04, 2009
  • 2976 Answers
SOURCE: West Bend 36 cup coffee maker amounts
It's a percolator. Use about 1 heaping teaspoon of coffee per cup. Each coffee pot is different. You will have to adjust the amount of coffee for what you like.
SOURCE: Senseo coffee maker
Having dismantled and inspected several of this "strange machines" my conclusion is the following:
There is an oscillating-piston pump inside with in- and outlet valve.
It is energized by a microprocessor controlled circuit for a working time depending on the button selected (1 or 2 cups). The pressure and flow are nearly constant for a perfect working pump.
The pod holder restricts the thruput by its central hole. (E.g. you get now an extra pod-holder with a very small hole for expresso type)
So if you don't get enough coffee it may be that
1) the duty-cycle (timing) of the pump has changed.(not often occurring) no repair, you have to undergo electronic and programming work
2) the pump lost efficiency (cylinder of the pump clogged, piston not working with complete stroke, spring force fadening or just one of the 2 valves leaking) ca be "repaired" after dismantling machine ,extracting pump and taking it apart, success not garanteed - grinding valves is already time spending
so my principle before starting this work is to run the machine without the coffee pod to check the water output, use a new holder with clean central hole, if this works it will be nr.
3) the central hole of the holder is clogged, may be not by limestone, but dried coffee extract (grease) clean with needle or even better with micro-drill
Posted on Jan 06, 2009
cmccune04
  • 213 Answers
SOURCE: Missing Keurig part
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
Posted on Apr 13, 2010
I have a cup o matic and it has recently started leaking from the main unit...???? Can I fix it?
you can if you can find where the leak is, and as long as it is just a worn o-ring and not a crack. You could contact Cuisinart for service? There are some articles on your particular problem in the main link at the bottom.
Pt 1: How To Use: Cuisinart SS-1 Cup-O-Matic Coffee Maker - YouTube
? 10:04
https://www.youtube.com/watch?v=jEPf5hXWkB4
Oct 18, 2007 - Uploaded by Jay Brewer
Learn how to use coffee pods and ground coffee with the Cuisinart SS-1 Cup-O-Matic Coffee Maker.
SS-1 - Coffee Makers - Discontinued - Cuisinart.com
https://www.cuisinart.com/discontinued/coffee_makers/ss-1/ Regular or bold, large or small - your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffeemaker, it's easy to brew your cup ...
[PDF]Cup-O-Matic™ Coffeemaker SS-1 - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/ss-1.pdf Cup-O-Matic™ Coffeemaker. SS-1. For your safety and continued enjoyment of this product, always read the instruction book carefully before using.
Amazon.com: Customer reviews: Cuisinart SS-1 Cup-O-Matic Single ...
https://www.amazon.com/Cuisinart-SS-1-Matic-Coffeemaker.../B000RIAIXO Find helpful customer reviews and review ratings for Cuisinart SS-1 Cup-O-Matic Single Serve Coffeemaker, Black and Brushed Chrome at Amazon.com.
Cuisinart® Cup-O-Matic™ Single Serve Coffee Maker - Bed Bath ...
www.bedbathandbeyond.ca/store/product/cuisinart-reg-cup-o-matic.../1014760199 Regular or bold, large or small, your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffee Maker, it's easy to brew your cup ...
Cuisinart Cup-O-Matic Single Serve Coffeemaker Review
www.goodhousekeeping.com/.../cuisinart-cup-o-matic-single-serve-coffeemaker-881/ Rating: 2 - ‎1 review
Unlike coffeemakers that only make a cup at a time, this model can be used with your favorite ground coffee as well as from coffee pods.
Single Serve Coffee Forums
cup matic leaking water Google Search
Sep 03, 2017 | Coffee Makers & Espresso Machines
It will not make coffee in either the Keurig pods or regular ground coffee. It says PURGE, or NEEDLE after I clean it and use paper clip to remove grounds. What else can I do?
Customer Reviews: Hamilton Beach 49995 FlexBrew Single ...
www.amazon.com/Hamilton-Beach...FlexBrew.../B00...
Amazon.com, Inc.All in all, the Hamilton Beach FlexBrew Single-Serve Coffeemaker is an ... exhibit the same exact problems using the K-Cups recommended by Hamilton Beach.
Hamilton Beach FlexBrew Troubleshooting Common ...
? 3:39
https://www.youtube.com/watch?v=yA2dlGKUBKM
Sep 7, 2015 - Uploaded by Ronald Kretz
Hamilton Beach FlexBrew Troubleshooting Common Problemmust see if you ... Hamilton Beach Single ...
Customer Reviews: Hamilton Beach FlexBrew Single-Serve ...
https://www.walmart.com/reviews/product/21130276
WalmartProblem the model I purchased was the only one they made that uses K Cup. ... MyHamilton Beach FlexBrew Single-Serve Coffeemaker was truly a wonderful ...
FlexBrew® Single-Serve Coffee Maker (49995R) - Hamilton ...
https://www.hamiltonbeach.com/all-coffee-maker...
Hamilton Beach BrandsThe FlexBrew® Single-Serve Coffeemaker allows the flexibility of brewing freshly ...Not sure how much coffee grinds to add when brewing your next cup? ... and thenrunning 2-3 cycles of cold tap water before making the next round of coffee. ... 2016Hamilton Beach Brands, Inc. Trademarks by Hamilton Beach Brands, Inc.
Hamilton Beach FlexBrew 49995 - Consumer Reports Online
Jan 05, 2016 | Hamilton Beach 49995 FlexBrew Single Serve...
Bitter taste
You will likely find the bitterness is a function of your coffee bean choice or the 'roast' component of that coffee. Darker roasts tend to taste bitter.
Nov 03, 2013 | Cuisinart Grind and Brew 10 Cup Coffee...
The single cup server runs over and grounds go everywhere.
Bottom needle is plugged...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 30, 2011 | Cuisinart Keurig B50 Single Cup Coffee...
Is it normal for the Cuisinart Keurig to want water whene it appears to be still about 1/4 full?
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Feb 10, 2011 | Cuisinart Keurig B50 Single Cup Coffee...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
