Question about Vizio Televison & Video
Why is my Vizio E370VLE 37 in LCD HDTV recieving no power when plugges in?
I am getting no power to my Vizio tv. The Vizio logo does not even light up. I have been checking the power source with a ohmmeter. When I check the fuses they hold a charge for a moment then drop to zero. A few diodes do this as well. is this normal? I would think that if the fuse was broken it wouldn't hold any charge even for a second. I'm at a loss because everything holds a charge including diodes, transistors and capacitors. I'm starting to think it may be a coil pack if the fuses and diodes holding a charge and then dropping to zero is considered normal.
    Master:
  • 560 Answers
Check to see if there's power to the outlet the set is plugged into.
Posted on Dec 01, 2014
Testimonial: "I guess i should Typed that I preformed trouble shoots too. Sorry about that. Here's what I've done. I've unplugged, waited 5 minutes and plugged back in. I've moved to a different outlet. I've held down the power button while unplugged to reset the power supply in case it was a power supply glitch. I've replaced the power cord that plugs into the back of the power supply with another cord in case there was a short in the wire. After all of that I opened up my tv and started testing fuses, diodes, capacitors with an ohmmeter. There are no burn marks anywhere. No capacitors are bulging at the top or have liquid coming out. What I did notice when testing these parts with an ohmmeter is that both fuses will have a current of 40 or so then drop to zero after about 2 seconds. Some diodes also do this and all capacitors do this too.I think I had a surge and it took out most of my power board but I wanted to be sure whether or not the ohmmeter dropping to zero after a couple seconds is normal before buying a new power board."
  • 84 Answers
SOURCE: Borken LCD Screen on 37" Vizio HDTV
You can have them repaired using a TV Repair guy but often it costs as much as a brand new tv. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
Posted on May 04, 2008
  • 90 Answers
SOURCE: replacement of fuses on Philips 37PF7320A 37 in. HDTV-Ready LCD
5 amp and 1 amp - slow burn fuses -- they have them at radio shack under 3 dollars for a set of three
Posted on Feb 22, 2009
SOURCE: Vizio LCD 37 Inch Turns Off Randomly
I had a similar problem with my 32 inch plasma tv. I called vizio's
1 800 number and the guy said to unplug the tv from the wall and hold down the power button for a minute and then plug the tv back in outlet and turn on. And it works I guess from what I understood from his heavy accent was that the tv retains power and this resets it somehow. hope that was helpfull!!
Posted on Nov 04, 2009
stonephoenix
  • 563 Answers
SOURCE: black shadow on screen vizio 37 in lcd hdtv
There is a part inside the TV that needs to be replaced. If the TV is under warranty—whether the original warranty from the manufacture or an extended warranty purchased with the TV—call the company providing the warranty coverage and they will arrange to have your TV repaired at little, or no cost to you.
Since some brands will pay for your repair even if you're out of warranty, especially if they've heard of your problem before and it's a known issue. You should always contact the manufacture first for your full range of options. If they're willing to fix the TV for free, or at a reduced cost to you, let them!
If the TV is out of warranty, and you have the experience and you know what you're doing, you can fix the TV yourself. Purchase the service manual from the manufacture to get started. However, if you've never done anything like this type of repair before and you don't know where to start, I suggest speaking with an experienced TV repair-person.
If you decide to pay for out of warranty repair by a professional repair shop, the total cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today!
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jan 11, 2010
Testimonial: "it was helpful thank you do you happen to know what this part is?"
walesarumi
  • 6993 Answers
SOURCE: Vizio E371VL doesn't turn on
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Posted on Jan 18, 2012
My TV powers up and shows the Vizio logo on the screen but why no video or backlight?
I had exactly the same problem with mine. Called for warranty repair, as it was only 3 months old. The repair person swapped out the motherboard, and it's been good for 2 years now.
Jun 14, 2015 | Vizio E371vl 37 Inch Class Lcd Hdtv
My vizio E370VLE is getting no power at all. The vizio logo under the screen isn't even lit up. I have tried plugging into new outlets and even switch out the power cord with a new one so i know its n
the problem is probably your main power board.. these can be replaced by yourself.. find the model no and then enquire about a replacement board ..I have had similar problem tv repairman wanted $500+ to fix board only cost $134..make sure to disconnect power supply ..undo all the screws around back of case including wall mount and base follow power lead entry into case do not touch any circuitry as some capacitors store power disconnect the little plugs that run from the boardundo the 4 screws and replace with purchased replacement board and re assemble..
Dec 20, 2014 | Vizio Televison & Video
Mytv has no power the vizio logo does not light at all
You have an issue with the power supply boardif the vizio logo doesnt even turn orange when the cord is plugged in. You can get the replacement power supply board from www.tvcircuitboards.com
Nov 11, 2012 | Vizio VO47L 47 in. LCD TV
Vizio HDTV E3DB420VX wont turn on
If your power indicator isn't lighting up, you don't have your 5vdc standby power. You're most likely looking at a power supply issue. Did this happen after a T-storm???
May 11, 2012 | Vizio 42 Class 120hz - 3d Hdtv Lcd...
Vizio e370vl 37" LCD TV powers off by itself. It comes on, displays Vizio logo white, then turns off and goes to yellow. We tried unplugging everything for 5mins. Tried changing inputs, no RGB cable c
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 25, 2017 | Vizio E370VL 37 in. LCD HDTV
Vizio VW37L no power
Check for bad capacitors in power supply, check voltages coming out of the power supply, if voltages are good, bad main board.. Vizio's are notorious for bad main boards.
Nov 23, 2011 | Vizio VW37L 37 in. LCD HDTV
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
I was watching my tv when my son hit the reset button on my surge protector..now my tv will not turn on. Any ideas?
Turn everything off, the tv the power and make sure the button is not active at the moment. Some surge protectors do come with a fuse but when you turn the surge protector back on itself make sure it is recieving power, there is usually a red light on the switch while recieving power. Then try again once you know there is power to it.
Feb 06, 2011 | Vizio E370VL 37 in. LCD HDTV
Vizio screen went off but power light is still on
may be a mainboard problem. If you can see the orange light it usualy means that there is power running through the TV... usually inverter boards are a problem when you do not see any backlight at all.
May 06, 2009 | Vizio VW37L 37 in. LCD HDTV
Televison & Video Logo
82 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
