Question about Dishwashers
Mend my dishwasher
It has two problems: 1. bottom of dishwasher tray has too much water in it when it finishes a normal wash 2. wash program freezes on either normal or eco or intermittently between the two (making a continuous bleeping noise with the eco lioght flashing on and off). I have tried cleaning the filters, checking if water pipes are restricted and also checked that there is no blockage at the sink end (u pipe)
  • robert ferguson
    robert ferguson Dec 01, 2014
    The second fault is on the upper dishwasher. So two different faults, one for each dishwasher section, this is a dual dishwasher.
SOURCE: Neff dishwasher continuously attempting to pump out water
I have just encountered the same problem on my S5433 XO GB/13. Did you manage to get a solution.
Posted on Feb 01, 2007
zeusfaber
  • 247 Answers
SOURCE: No water filling up in the dishwasher when programme set
My instinct would be to replace the water inlet valve without even trying to prove whether that is the real problem. The valve is the plastic unit on the back wall of the cabinet that your cold water hose screws onto. I think your dishwasher takes a Universal 90 degree Single inlet cold water solenoid valve, which you can find unbranded on the net for under £10. Provided you remember to turn the power and water off before you start, there are no hidden surprises in the replacement procedure: Remove the inlet hose, undo the screws attaching the valve to the cabinet, unplug the two wires, unclamp and remove the hose inside the dishwasher, then reverse the process to reassemble. After assembly, check that the hose to valve coupling is watertight. Granted, the problem might conceivably lie elsewhere, but the valve is so much more likely a culprit, so cheap to buy and so easy to fit that you might as well change it on spec. A.
Posted on Mar 20, 2007
  • 213 Answers
SOURCE: Bosch dishwasher problem
remove the kick plate below the door. youll see a white tray behind the kick plate. theres water in the tray thats activating a overflow switch. with a towel or 2 remove as much water from tray as possible. this will solve problem
Posted on Nov 20, 2007
  • 105 Answers
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Posted on Feb 24, 2008
SOURCE: check water
very possibly you have a faulty water flow switch. If a certain flowrate is not detected within a certain time, that light would come on
Posted on Mar 27, 2008
The dishwasher doesn't finish the 30 min program. The display shows 1 minute remaining but the washer doesn't stop.
It sounds like the d/w has a heating issues. Possible internal failure of the heating relay.
Jun 20, 2016 | Dishwashers
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
Wont finish wash and drain
I would turn off main power then open the controls looking for any burn parts on the power board before calling any one , how ld is this unit before yu spen too much get back to me
Dec 04, 2011 | Electrolux Dishwashers
Water remains in the bottom of dishwasher (in the salt dispenser)after the wash cycle has finished
it is normal for water to be in the bottom of a dishwasher- it forms an air seal to stop odours
Aug 28, 2009 | Dishwashers
My dishwasher is sticks in between washing cycles
These mechanical timer machines have to follow a series of logical steps to complete the program - ie, empty. fill to level 1. wash. heat to temp. etc etc
My guess is the machine is not heating, as you say it works for part of the program - or possibly it is not emptying correctly? check water heating element and drain pump.
Program 4 eco is a separate program from 3, using low temperature washing - the machine does stop between 3 and 4 normally and doesnt carry on through.
Jan 30, 2018 | Siemens 24 in. SE64A630GB Built-In...
Detergent packs are not dissolving
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Apr 21, 2009 | KitchenAid 24 in. KUDS02SRSS Stainless...
Dirt left on dishes on top tray; bottom tray washes fine
The broken bottom arm is probably preventing any water / water under pressure to get to the upper arm.
After you replace the lower arm, you should have much better cleaning in the top shelf.
While you are in there replacing the lower arm, recommend you remove the filter under it and clean the filter and any debris you find. Be careful of broken glass!
Good Luck!
Apr 03, 2009 | Dishwashers
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Hotpoint Aquarius DWF31
to isolate fault,remove bottom front panel,turn off main water,put a tray under machine, remove inlet pipe frompump at front of machine. for a second to see if you have flow that far. If so trouble is in machine. Dig the filter out of th pump entry .It could be blocked
Nov 04, 2007 | Hotpoint 24 in. DWF32P Free-standing...
LG Dishwasher
according to the manual that i have just downloaded from the net,E1 code means.water leakage in Hose connections.
.water is leaked by damages
hope this helps,
keith
Sep 20, 2007 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
